תגובה להודעה: מקלט corona
אמנם יש לפעמים איזו שהיא בעיה בנעילה של מקלטי Corona Synthesized עם 6 או 8 ערוצים. מכוון שגם לי היתה פעם בעיה כזו מצאתי ברשת שתי אופציות לפתרון הבעיה. מכוון שהמקלט נמצא אצלי כבר הרבה זמן אני לא לגמרי זוכר באיזו שיטה השתמשתי - מעט סבלנות ומספר נסיונות - לבסוף זה ינעל.
ציטוט העצות:
Corona Synthesized Dual-Conv Receiver 8Ch 72Mhz
הצעות לנעילה של המקלט
פתרון 1
Spent over 2 hours today trying to lock my TX frequency and want to share what eventually worked for me. Initally, nothing, as I followed the steps described in the PDF manual.
Tried several other variations I found on the web and finally the following worked for me:
(1) Hold down the scan button. LED Light will flash 3 times.
(2) after the 3-flash sequence finishes, immediately press the button again for 1sec or more.
The light will start flickering fast - the Rx is in the scan mode. Then it will pause and flash, and then stay ON (continuing red). At this point it is found and locked the TX. You should see the servos responding. You can disconnect the battery, reconnect and check that the frequency was remembered.
פתרון 2
I bought the Corona Synthesized Dual-Conv Receiver 8Ch on 72Mhz to go with my Futaba F10CAP 72Mhz Synth TX module.
For the money this RX is great however the button pressing while counting to 2 can be a bit confusing at first often failing to get the '3 flashes'.
Here is what I found worked best.
Hold the button down for two seconds
Case 1:
if you get 3 flashes you are good to go (in scan mode) so just press the button once more to scan - once locked the RX will remember the TX frequency (no need to re-scan everytime).
Case 2:
if you get only 2 flashes, immediately hold the button down for more than 4 seconds - on releasing the button you should get 3 flashes and are good to go (in scan mode) so just press the button once more to scan.
If you still only get 2 flashes then hold the button down for much longer (5~6 seconds) and you should be ok.
Setting up for failsafe is similar to above - once you get the 'mode 1' 3 flashes you have to wait until you are in 'mode 3' (mode 1 is scan - mode 2 is disable failsafe - each mode is indicated by a different flash pattern).
DON'T forget to power down - power up the RX once done setting the failsafe!
DON'T forget to switch your TX mode from PCM to FM/PPM!!! else you won't get a lock on your TX at all.
Adam.D
צריך את עזרתכם בקשר לשלט והמקלט
יש לי מקלט corona
כזה . לפי ההוראות אני scan במקלט כשהוא מחובר לסוללה דרך הבקר. המקלט מהבהב 3 פעמים (התגובה הרצויה שאומרת לפי המדריך שיש חיבור) ואז הפסקה ואח"כ עוד 2 הבהובים רצופים. אחרי זה המקלט עדיין לא מותאם לשלט. כשניתקתי וחיברתי את הסוללה עוד פעם המקלט היבהב שוב, אבל רק פעמיים (תגובה לא רצויה, המקלט לא מגיב לשלט).
השלט הוא futaba t7cap .
אשמח אם תוכלו לעזור לי בנושא הזה... הטיסן המוכן גם הוא מחכה;)
לדעתי אתה לא מגיע למצב סריקה בכלל.
מצב סריקה הוא כאשר הלד מהבהב ממש מהר למשך כ5 שניות.
כדי להגיע לזה צריך לחבר חשמל למקלט, לאחר מכן לחיצה ארוכה של 2-3 שניות, ולאחריה לחיצה קצרה.
כשהמקלט ינעל אתה תשמע את הסרוואים זזים למצב הסטיקים
umbo
בינגו!
תודה רבה הצלחתי לסדר את המקלט.
עוד שאלה קטנה, אחרי שהעברתי ל ppm נתקלתי בבעיה קטנה, במסוק שלי(מקלט אחר מקורי של פוטאבה) כשאני נשאר על ppm ומחבר סוללה למסוק, הוא מפסיק לעשות את הצפצופים שפעם עשה כשמחברים סוללה, הוא עובד כשורה אבל לא עושה את הצפצופים. אני די בטוח שקודם לכן המסוק עבד על pcm ולא ppm וכאשר העברתי את המצב ל- pcm (כדי לבדוק את המסוק בפעם הראשונה אחרי העבודה עם המקלט קורונה) הסרווים השתגעו בקיצור לא עבד.
השאלה שלי היא כזאת, למה כעת המסוק פועל על ppm כשלפני כן היה רגיל לעבוד עם pcm ?
שוב, תודה רבה על העזרה.
עריכה: נפתרה הבעיה .. המנוע לא היה מחובר לכן לא היה צפצוף
