1 קבצים מצורפים
למכירה מקלט ppm לרחפנים של mikrokopter שאפשר להטיס אם שלט פוטאבה
Receiver R6107SP 2,4 GHz RASST
Very lightweight (6g) and small 7-channel 2.4 GHz RASST receiver with end-mounted servo sockets.
With serial output, perfectly suited to controlling helicopters and quadrocopters.
Switchable for analogue or digital servos, although the signal sent for digital servos is faster, giving a shorter reaction time.
Usable in all sectors of modelling, the 14 cm antenna for this antenna can be positioned on the outside of hulls or chassis made of carbon-fibre reinforced plastic or metal.
Not recommended for large-scale models and jets.
Range: > 1000 m
Oneserial output on the receiver requires special building blocks in the model which can read the stream of signals and process them accordingly, such as e.g.theHC 3-Xtreme or Mini-V-Stabi.
Traditional servos cannot be connected directly.
No crystals, no frequency selection, and highest protection against same-channel interference by means of 2,4 GHz FASST technology.
The best possible protection from interference by rapid frequency hopping. High interim frequency of 800 MHz, therefore insensitive to Electrosmog.
Simple binding using integrated EASY-Link button. Simple binding using integrated EASY-Link button.
Specification:
Channel spacing: 7
Channel spacing: 2048kHz
Voltage: 3.3-8.5V
Current: 45 mA
650 שקל זה חדש ללא שימוש
0527280088-שרון
