מנוע SCORPION HK-3026-1900KV V2 חדש
נתוני יצרן:
Specifications
Stator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ........................... 26.0 mm (1.024 in)
No. of Stator Arms .................................................. 9
No. of Magnet Poles ................................................ 6
Motor Wind ............................................ 8 Turn Delta
Motor Wire ..................... 23-Strand 0.25mm (30 AWG)
Motor Kv ........................................... 1900 RPM / Volt
No-Load Current (Io) ................... 1.98 Amps @ 6 volts
Motor Resistance (Rm) ............................. 0.012 Ohms
Max Continuous Current ............................... 80 Amps
Max Continuous Power .............................. 1140 Watts
Weight ........................................ 193 Grams (6.80oz)
Outside Diameter .......................... 37.5 mm (1.476 in)
Shaft Diameter ............................. 5.00 mm (0.197 in)
Body Length ................................. 48.4 mm (1.906 in)
Overall Shaft Length ...................... 74.2 mm (2.921 in)
מנוע חדש 300 שקל לא לוויכוח
0545583249
