מציג תוצאות 1 עד 5 מתוך 5
מאמר: HobbyKing YAK 54 Brushless EPO Plug-n-Fly review
  1. תאריך הצטרפות
    הרצליה
    הודה 92 פעמים ב 60 הודעות
    Jump to Comments
    4 Comments by liorz055 Published on 28-08-2010 11:47:02
    Background
    Recently hobbyKing introduced a new product : "HobbyKing YAK 54 Brushless EPO Plug-n-Fly". This plane is not meant for beginners, it applies to the more experienced flyers for 3D flight and aerobatic flight. According to hobbyKing this plane was designed from scratch making it lighter and
    suitable for 3D flights.
Name:	rear view-2.jpg
ID:	30923 Click image for larger version.
Name:	size veiw-2.jpg
ID:	30924Click image for larger version.
Name:	front-size view-2.jpg
ID:	30911Click image for larger version.
Name:	canopy open-I.jpg
ID:	30909Click image for larger version.
ID:	30928Click image for larger version.
Name:	in front-2.jpg
    Specification:
    Wing Span: 750mm (29.5in)
    Length: 675mm (26.5in)
    Weight: 355g (without battery and receiver) Battery compartment size: 99x39x16mm (Important) center of gravity : 52-60 mm behind the wing leading edge
    Not supplied : Your TX & RX
    7.4V 2S 1000mah lipo battery I used this battery.
    For the advanced pilots - 11.1V 3S 760mha Lipo battery- This will do fine.
    Packaging:
Name:	חלקים מעוגנים.JPG
ID:	30930Click image for larger version.
Name:	טיסן בקרטון.JPG
    The plane arrived in a blank cardboard box. inside the box there were two layers of bubble wrap and beneath, also wrapped in bubble wrap the wings. I should point out that the two wings are made in one piece, what should increase the wings durability. The rest of the pieces were tightly secured beneath the wings. Overall, It seems that Hobby King did their best to secure everything in order to avoid damage during the voyage to the holy land, a good example for this is the horns that came wrapped in a thin sheet of foam to protect them. HobbyKing took the ecologic approach and didn’t
    supplly any hard copy instruction manual .
    Delivery time: It took 14 days from the moment of ordering until the arrival of the plane (Shipping method- Air Parcel (Israel) up to 2kg).
    What's inside the Box:
Name:	שקית המציאות.JPG
ID:	30936Click image for larger version.
Name:	מה בקופסא.JPG
    1. The body of the plane with an ESC motor and two servos already mounted with push rods.
    2. One centreral wing with servo mounted as well.
    3. Rudder and elevator attached with horns .
    4. two 40mm (1.5 inch) foam wheels on landing gear .
    5. Two EPO spinners.
    6.two 8X6 3 blades propeller.
    7. Plastic bag with one Hex key),two spare clevis, two nylon screws (for wing assembly) ,one metal bolt (for elevator assembly) , and one small wrench which I didn’t use.
    First impression:
    The airframe seems of a high standard, all the parts are fit together in harmony. I couldn't notice any defects with my naked eye. Again Hobbyking insist on the minor details The plane seems and was decorated as a real plane and not like flying foam. The body has an air inlet that is not only pretty, but actually cools the ESC. Moreover since trying to give this plane a scale look the accessibility of the motor is impaired (not clear senetece) . What compromised the lack of accessibility is a small hole in belly that allows removing the motor from its base. The hinges of the rudder are very elegant and the rear wheels attachment seem robust. The plane has a very realistic appearance due to the ailerons system that doesn't have any horns. Furthermore the canopy hatch can be easily open and close thanks to the two plastic hinges and the magnetic bolt.
    The electricity of the plane seems to be consisted from a 2409-18T motor attached with 3.5 bullet connectors to the ESC. The ESC- battery plug is JST connector. There are three 5 grams servos, all the servos are accessible and can be replace by removing two small metal screws, in case of
    malfunction.
Name:	מאזנות ללא הורנים.JPG
ID:	30932Click image for larger version.
ID:	30929Click image for larger version.
Name:	motor accsess hole-2.jpg
    Assembly of the plane:
    A 10 minutes movie with the full assembly of the plane:
    The assembly process didn't require Glue and took around 10 minutes.
    Step 1- Attaching the elevator to the main body:
    In the elevator there is a small groove that enters the body to ensure proper orientation. You just need to remember to attach the elevator when the horn is facing down. After you connect it,just screw the metal bolt until the elevator is tightly secure in its place. (Use a proper screwdriver).
ID:	30915 Click image for larger version.
Name:	hole in plastic-2.jpg
ID:	30914Click image for larger version.
Name:	elevator screw driver-2.jpg
    Step 2 horizontal stabilizers:
    Just push the horizontal stabilizer into two plastic hinges until you here click! You will need to take care while inserting the wired loop into the plastic cavity (I really liked this method, its gives the back wheel the toughness to
    endure hard landings.
Name:	hinges-cloose look-2.jpg
ID:	30913Click image for larger version.
ID:	30912Click image for larger version.
Name:	plastic groove-2.jpg
ID:	30922Click image for larger version.
Name:	metal loop-2.jpg
    Step 3: wheels assembly.
    For our convenient the cover of the landing gear is marked with R and L to ensure proper assembly, just attach it to the plastic socket in the underbelly
    of the plane.
Name:	מגרעת פלסטיק.JPG
ID:	30933Click image for larger version.
Name:	wheels assembly-2.jpg
    Step 4 : propeller assembly.
    Make sure the two side stickers are facing forward to the direction of the flight. After the propeller is secure peel the cover of the sticker and attach the EPO spinner firmly.
Name:	פרופלורים + ספינר.JPG
    Step 5 wing assemblies:
    Carefully enter the wings into the wing slot in the main body. Screw the two nylon bolts all the way. Make sure that the Esc lead plug is nowhere near the wing socket or you will have a dent in the wings.
    That`s it you just need to add a receiver battery and into the field.
Name:	wing assembly-22.jpg
ID:	30927Click image for larger version.
Name:	wing assembly 2211.jpg
    Flying report:
    Flight review with 2 cells battery (link)
    The airplane was tested twice with 2 cell battery and with 3 cells battery as well.
    2 cell setup:
    Relatively long distance for takeoff , very aerobatic plane can't do 3D , very agile and sharp but not very fast.even thought it small size it Doesn't affect by the wind at all . By using 1000mha battery there are about 7-10 minutes of aerobatic flying. The landing required some skill, but the plane itself very resilient to crush, I crushed it twice from low altitude and I could not notice any damage.
    3 cell setup:
    Here this plane comes to the big league ,and you should be in the big league as well. It is a fast and spicy little devil, very aerobatic, Extreme agile and kicks as well. Can do knife but not hover in place. This plane will definitely give you adrenaline boost but beware, you have to be intermediate or expert because you won't have second chance.
    conclusion:
    the assembly process was a piece of cake, it’s a good thing that this plane require only 10 minutes to assemble, especially for busy people like me.
    Due to its weight and this airplane is not a 3d very capable one but rather a F3A aerobatic airplane. You should start with the 2S setup and then move to 3S setup. This plane will give adrenaline shoot to the intermediate-expert flyer but will be very frustrating for the beginners-novice pilots.
    Its look and appearance belongs to much expensive airplane. I can reassure you that whereever you go ,this plane will definitely catch the attention.
    נערך לאחרונה על ידי liorz055; 29-08-2010 בשעה 02:28:46.
  2. Total Comments 4
    תגובות
    ברירת מחדל תגובה להודעה: HobbyKing YAK 54 Brushless EPO Plug-n-Fly review
    Very good review!
    Jan 2010
    הודה 167 פעמים ב 126 הודעות
    Excellent review Lior, thanks for sharing!
    Enjoy
    מרשים
    נערך לאחרונה על ידי ניסן וצחי; 28-08-2010 בשעה 14:58:28.
Name:	IMG_7737 (Medium).JPG‏
ID:	30987   Click image for larger version.
Name:	IMG_7738 (Medium).JPG‏
ID:	30988   Click image for larger version.
Name:	IMG_7742 (Medium).JPG‏
ID:	30989   Click image for larger version.
Name:	IMG_7740 (Medium).JPG‏
Similar Articles
  1. סקירת מוצר HobbyKing YAK 54 Brushless EPO Plug-n-Fly
    על ידי liorz055 בפורום סקירות טיסנים
    הודעה אחרונה: 30-08-2010, 13:58:09
  2. סקירת מוצר HobbyKing YAK 54 Brushless EPO Plug-n-Fly
    על ידי liorz055 בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 32
    הודעה אחרונה: 30-08-2010, 10:54:13
  3. סוף סוף במלאי - Yak 54 1.5m Monster 3D Brushless Plug-n-Fly
    על ידי MRDATA בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 05-07-2010, 19:46:20
