מציג תוצאות 1 עד 15 מתוך 15
מאמר: HobbyKing park flayer EDF "Rafale
    ברירת מחדל HobbyKing park flayer EDF "Rafale"
    Few weeks ago I got an offer from our beloved Moderators Maayan and Izik Click image for larger version.
ID:	37404to do a Review on one of the products distributed by our sponsor HobbyKing
    This was a kind of an offer that can't be refused, it took me almost 10 seconds to accept
    The chosen plane was the Newly Park Flayer EDF "Rafale" which comes in a form that I call MRF - "Mostly Ready To Fly
    The kit is manufactured by FMS - Shenzhen Famous Electronic Tech Co. LTD
    Specification:
    Wing span 660 mm
    Length 1000 mm
    Weight 610 gr (with 1300 mAh battery)
    Channels 4
    Servos 9g 1.3 KgxCm 0.12S/60 Deg
    More data can be found in Hobby King site - http://www.hobbyking.com/hobbyking/s...dproduct=12484
    As the kit is 97% pre built (according to the site) it takes short time to Assemble and setup
    The box came in shortly after
    The Box is big, but the weight is surprisingly light, Mail handling of the box made some dents
    but the inside was in tucked : Click image for larger version.
    Unpacking the box:
    Opening the box reviles a nicely packed almost finished plane
    All parts were nicely packed and guarded by EPO cage and nylon wrapping.
ID:	37441Click image for larger version.
    The body of the plane was locked to place by a block of EPO that locked the nose to the side,
    Lift it up to loosen the body from the box (see attached picture)
    The plane was divided into fully built sub Parts:
    fuselage:containing the installed EDF, ESC ,1 servo and extension cables for the elavons servos
    Pre built wings and rudder were packed bellow
    Landing gear, plastic Canopy and nose cone were laying in the side of the box
    Also in the box was a small Build and operating manual in a pictorial brochure clearly describing the building process and installation
    First Impression:
    The kit looked fabulous, all parts were nicely build and had painting and decals. the kit looked very realistic, resembling the real fighter
    I Was impressed!!! (and in love from the first sight)
    Building:
    The process of assembling the plane can hardly be called "building
    mainly, all you have to do is glue some parts, install the radio and go flying... I like it
    First step:
    Check all parts are in and nothing is broken or bent or missing
    Second step:
    Review parts connecting method, peel off guarding parts attached to the leading edge of the wings
    Make sure alignment and matching of the wings and the rudder to the body by positioning the parts in place
    Note: the Rudder connecting rod has a small tube installed in order to safeguard the rudder during installation
ID:	37443 Click image for larger version.
    Make sure you know how to insert the rudder and don't forget to loosen the rudder hinge bolt so the rod will enter it during installation
    check wings alignment and matching - if needed sand a little bit. check nose cone position and alignment - note: the cone is not symmetrical
    Third Step:
    Gluing: Straight forward, follow the steps as seen in the brochure
    use the Epoxy glue that came with the kit, the glue is fast hardening (5 Min) so be quick and keep it light - use a little glue
    Landing gear installation: Main gear - put in place and lock the latch
    Front - put in place (note the notch) and lock with the Allen wrench supplied
    Forth Step:
    Installing the Receiver and connecting the electronics
    I used the Berg light receiver which I prefer for its ability to withstand noisy environment, and has a failsafe feature
    Check servo movement, centers and travel
    note: mechanical center of the nose wheel/Rudder servo should be as in the following picture
    This is the end of the "Building" part, it should take about 30 min. to finish
    Now it is the time to do all programming needed on your transmitter
    I use the good old Futaba 9CHP so some travel adjustment and Exponential assigning is needed
    Jet or Ducted fun is being flown in 70-100% throttle mostly, so an exponential of 50% was put on the motor channel
    Elevator exponential was initially put on 25% and Ailerons on 35%
    Pre Flight checks:
    CG was checked to be found in the exact position noted on the manual
    Weight was checked to be found 605 gram (a little lighter then the anticipated 610 gram)
    Engine static thrust was checked (by measuring weight and then total weight and thrust)to be around 440 gram, not bad, but will not make nice verticals
    Current draw and battery time was checked on ground to be found around 20-25 Amp (250-300W) at about 5 min flight time, battery used during the tests were 1300 and 2200 mAh 20-25C
    no significant noise or heat were shown during the ground tests
    >>>> Flying Time >>>>:
    The big day arrived almost two weeks after finishing the plane. As the manual says a clear paved 20 meter runway is needed
    so a landing strip that will allow such long takeoff was found and weather was king enough, all was GO
    With the help of my good friend Ilan and my son Ido, we constructed the test team 'that included me as the pilot and a crew of two rolling cameras
    As the runway is not paved and had small granular stones the take off roll was somewhat bumpy
    I let about 10 meters of accelerating before applying slight elevator only to find myself in the air without enough energy to stay airborne
    having to let the plane sink, I hit lightly the ground, this was enough to detach the right main gear from the wing
    but still airborne I continued gaining enough speed to start climbing
    At a secured altitude some minor trims were made and a few flyby over the runway were done
    The battery run down at about 5 min. flight, Power was drastically low and a quick landing was needed
    Landing gently and easy on the left gear, no harm done or scratches on the plane
    Attaching back the right main gear to place with sticky tape... and rock n' roll again
    The maneuverability was found to be excellent, ability to fly at low and high speeds,no tendency for abrupt stalls
    canards and delta wing combination was found to be stable easy and fun to fly
    Eventually, 4 batteries later and at sun dusk, Alas, we had to return home but with a big smile enjoying a happy day in the field
    Learned Tips:
    Initial setup of the elevator is de-cambered a little (about 1 mm Up)
    Exponential is a must, the plane is very sensitive on the roll axis, and sluggish at pitch axis
    Be patient,Let the plane build up speed before pulling up at take off
    The following movie filmed and edited by Ilan:
    Conclusion:
    This Kit is aimed to the intermediate flyer that can handle fast maneuvers and unstable platforms
    The kit is built in a good quality and has a good real like visual view,I also likes the Jet Turbine like sound
    Requires small time and expertise to build and comes almost RTF
    Good build instruction and operating Manuel
ID:	37409 Click image for larger version.
ID:	37435 Click image for larger version.
    ! ! ! An Excellent Value for the money
    Zvika
    ארר.. זו כבר פעם חמישית שהפיירפוקס קורס אחרי ששיניתי והוספתי הרבה חומר... אצטרך
    להעלות ולעדכן בקטעים, עמכם הסליחה...
    לא עוזר כלום, הפיסוק בסוף המשפט קופץ להתחלה...
ID:	37405   Click image for larger version.
ID:	37410   Click image for larger version.
ID:	37414   Click image for larger version.
ID:	37415   Click image for larger version.
ID:	37419   Click image for larger version.
ID:	37420   Click image for larger version.
ID:	37422   Click image for larger version.
ID:	37424   Click image for larger version.
    נערך לאחרונה על ידי ZvikaF; 17-01-2011 בשעה 16:38:03.
    Or Yehuda, Israel
    הודה 5 פעמים ב 3 הודעות
    ברירת מחדל תגובה להודעה: HobbyKing park flayer EDF "Rafale
    סקירה יפה!
    איפה הסרטון?
    בדרך...יש צילומים יפים.
    אני עוד מתקרטש עם העריכה של הסקירה והקריסה של העורך .
    היא עדיין רחוקה ממה שהתכוונתי לו.
    איזור השרון
    כתוב בצורה מקצועית .
    EDF מהיר לי מדי , אבל , כמעט גרמת לי לקנות .
    כל הכבוד
    נייס
    Israel
    הודה 31 פעמים ב 26 הודעות
    המוצר לא My cup of tea אבל סקירה טובה ומקצועית. עריכה טובה יותר רק תשפר את הטוב.
    סחתין!
    בברכת נחיתות טובות,
    אבי סירוטה
    סקירה מצויינת. בקהילה פה אוהבים סרטונים... של הטיסן כמובן..
    זכרון יעקב
    הודה 163 פעמים ב 125 הודעות
    Very nice review
    מקווה שגם תהנה ממנו מעבר למלחמה בקשיי ה"עברית \ אנגלית" של הפורום.
    הוספת סרטון שצולם ונערך בידיו האמונות של אילן :
    אחלה סירטון ועריכה!
    LIKE
    פששש.. איזו נחיתה! אחלה הטסה, אחלה סרטון אחלה עריכה. אילן, צביקה - שיחקתם אותה! יאללה Copy&Paste ל RCGoups ו RCUniverse
    easy said.... תודה
    יופי של סרטון,נראה טוב הטיסן.
    קריית חיים
    כפר גלים
    הודה 22 פעמים ב 18 הודעות
    מצטרף לברכות , מדהים - עושה לי חשק ...
    בברכה ,
    שחר ג.
    ההבדל בין מי שאתה ,
    לבין מה שאתה רוצה להיות ,
    הוא במה שאתה עושה ...
Similar Articles
  1. תל אביב והסביבה Park Master למכירה
    על ידי GAD77 בפורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 02-11-2010, 07:15:45
  2. [מדליק] 3D Rafale indoor
    על ידי hai בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 11-08-2010, 02:26:07
  3. [מדליק] Park Master 3D
    על ידי exetion בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 12-07-2010, 16:09:34
  4. [שרשור בניה] Park Master 3D
    הודעה אחרונה: 11-07-2010, 19:20:53
  5. למכירה Funny Park של GWS
    על ידי danile80 בפורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 25-03-2010, 19:30:05
