נושא: O.S. 91HZ-R 3D Speed Black 61G Heli Engine
    הודה 7 פעמים ב 7 הודעות
    ברירת מחדל O.S. 91HZ-R 3D Speed Black 61G Heli Engine
    יצא מנוע "חדש" עם נתונים מרשימים..ומחיר לא מרתיע במיוחד, מה אתם אומרים ? מישהו ניסה??
    O.S. Speed 91HZ-R 3D Black Ringed w/ Pump, 61G Crab 2-Stroke Engine for F3D Helicopter NEW!
    Following the popularity of the 91HZ-R with On-Demand Regulator, O.S. has now taken high-performance, high-speed helicopter engines to the next stage of evolution. Introducing the 91HZ-R Speed Engines - based on the 91HZR, factory-tuned at the O.S./Japan facilities and guaranteed to blow you away!
    Features found in both versions include:
    Lightweight, machined heatsink head
    Big-bore carburetors best-suited for the intended use (F3C or 3D)
    Best precision advanced exhaust cylinder timing (for F3C or 3D)
    Newly designed combustion chambers, shaped to match the big bore carburetors and advanced exhaust cylinder timing
    Lightweight, forged steel crankshaft counter weight to lower vibration for higher speeds
    Improved back plate shape, to accommodate Futaba's BPS-1 RPM Sensor and increase primary pressure for greater stability
    The cover plate has a cell to accept a sensor designed to install in the cover plate from Futaba GY701 / CGY750 Governor
    Pilots who slam the sticks will be very impressed with the 3D version. This engine develops all the high performance required for stable horsepower at any attitude. The big bore carburetor (11.2mm) is specially designed to develop stable horsepower at 70~80% throttle which is widely used in 3D flight. The matched cylinder exhaust timing has been advanced to 165 degrees.
    Package Included:
    O.S. Speed Tuned .91HZ-R Helicopter Engine with Pump, 61G Carb
    #8 Glow Plug
    Check Valve
    Head Gasket 0.2mm
    OS Speed Decal and English Instruction manual
    SPECIFICATIONS:
    Stock Numbers: OSMG1982 91HZ-R 3D Speed Black 61G
    Displacement: 0.91 cu in (14.9 cc)
    Bore: 1.09 in (27.7 mm)
    Stroke: 0.98 in (24.8 mm)
    Output: 3.6 hp @ 15500 rpm
    Practical RPM Range: 2,000-16,500
    Weight (w/o Muffler): 21.2 oz (603 g(
    http://www.rc711.com/shop/os-91hzr-3...?cPath=134_135
    נערך לאחרונה על ידי ערן אפרייאט; 19-09-2012 בשעה 10:19:41.
    בברכה,
    אהרון ערן אפרייאט,
    בקרו בגלריה שלי : http://www.runryder.com/helicopter/gallery/37202
    "Feed the Need to 3D"
  1. באר שבע והסביבה סט הסבה למנוע OS 91HZ-R
    על ידי שחר לזרוב בפורום מסוקי דלק
    הודעה אחרונה: 04-07-2011, 07:55:51
  2. תל אביב והסביבה מנוע o.s 91HZ PS w/pump
    על ידי משה שמואלי בפורום מסוקי דלק
    הודעה אחרונה: 03-04-2010, 00:13:57
  3. [מוצר חדש] מנוע חדש OS 91HZ-R
    על ידי ziki בפורום פורום מסוקי דלק
    הודעה אחרונה: 26-02-2010, 16:44:22
  4. O.S. Engines 91HZ + MP6 90 חדשים בקופסא
    על ידי guyro בפורום מסוקי דלק
    הודעה אחרונה: 21-12-2009, 10:39:55
  5. למכירה: Trex700N+91HZ+8717's
    על ידי גל דרורי בפורום מסוקי דלק
    הודעה אחרונה: 15-08-2009, 10:36:18
