עשיתי את כל זה
-RVOSD will make the elevon mixing, so set your R/C controller for normal outputs. Connect Rx elevator output to
RVOSD elevator input, and Rx rudder output to RVOSD rudder input. Connect RVOSD rudder output to one
elevon and elevator output to the second elevon.
-Change the “Airplane type” menu item set to “flying wing”, and make sure rudder and elevator transmitter trims
are to 0%.
-Go to the menu “Set neutrals” and set it.
-Go out of the autopilot menu. Now mechanically adjust the elevons to neutral positions.21
-Make sure that the elevons move both up//down, when you move elevator sticks. If not change the menu item
“Flying wing CH1 reverse”.
-Adjust with the transmitter the correct rudder and elevator channel direction, so climb//dive and bank left/right are
properly executed. At this stage the OSD has strong software limits to the servo throws, so don’t increase those
on the transmitter. One way to check the real servo throws is by changing “airplane type” back to “normal”, each
elevon will become rudder and elevator but, you can check the throws for every channel.
הכל עובד טוב
וברגע שאני מחבר ה THROTTLE מה RX ל THROTTLE IN ב RV OSD הכל מתחרפן
אולי אני עושה טעות בתרגום משהו יכול להסביר לי מה לא נכון שם
לינק להוראות
http://www.rangevideo.com/docs/rvosd3.pdf
