.Okay, we're going to do this in english for a very simple reason - this message will be edited multiple times and I find it much easier to work in English
So - my
Raptor 2000 has arrived finally from R2 .hobbies. Cost with shipping $117
.The glider came in perfect conditions, excellently boxed (double box) and well packaged
.I will add parts pictures slightly later in the day
.The first thing that struck me was the lightness of the box. The box, actually, was picked up from the post office by a friend who told me the box is so light he thought it was empty. Well, the box is indeed very very light
:So - on to weighting the components, initially, no electronics
Fuselage and canopy - 164g
Wing (half) - 124g
Tail unit - 34g
Misc parts (including servo extensions, bolts, etc) - 88g
.Total BEFORE electronics and V-tail pushrods - 534g
.I thought to reuse a motor I had but discovered that it is too wide, so I will need to order a motor unit and some servos. Hmmm
...LONG DELAY - did not have servos and was too lazy to buy
.Ok, updates
.Have freed up servos - two Savox SH-0257MG for the tail and four Corona 922 for the Ailerons/Flaps
.Ordered motor and prop/spinner (yes, I know, suboptimal, but it will hold for the test) combo directly from R2hobbies
.Ordered an Orange receiver from HK
.(I will probably be using a 30A ESC for the motor and and a dedicated BEC for the servos (of there are six, so no go to just hook it up directly
.Still too lazy to do photos
:The time has come, the walrus said
קובץ מצורף 81930
...The servos
.Note that the two Savox servos are very small - just what the glider wants in the little cutouts for the servos in the rear of the fuselage pod
.(Also note - vis-a-vis weight, that I am weighing the servos with extensions (in effect, weighing the extensions a second time around
קובץ מצורף 81931
...The Rx, BEC (3A) and wiring fan
.Note - I think the BEC is too small and will probably be switching to a Castle Creations BEC (5A) - it is small and light and I have one
קובץ מצורף 81932
...The ESC
:Weights
ESC - 51g
Rx and fan - 31g
Servos - 110g
Cumulative total - 726g
(Expected battery - (3S 2200mAh) - 210g worst case (for a very inappropriate 65C heli battery
Cumulative total - 936g
Inserted Aileron and Flap servos into the wings. Now that I have done so - it would have been a much better idea to remove the servo connector from the servo and solder an extension directly, not .using a female/male link and shrine-tubing them together. This is fine (i.e. gets into the wing, etc) but barely. Any bigger and I would have had a to suffer the tortures of Sysyphus
:Update
:Rudder and elevator servos are emplaced
קובץ מצורף 82040
קובץ מצורף 82041
:Adding wing servos
קובץ מצורף 82042
:Wing servos go in
קובץ מצורף 82302
...Servo with its adhesive - ready
קובץ מצורף 82303
...The servo on placed on the servo cover
קובץ מצורף 82304
...A touch of hot glue
קובץ מצורף 82305
.And emplaced. Note - the servo covers/trays are brittle - one corner chipped despite being pre-drilled
Aha! Drat! Adding the V-Tail and... while inserting the guide tubes for the pushrods, the rear fuselage split, gently, right along the back in the very rear. Undaunted, I removed the tubes, rerouted them through the cooling vents and fixed the rear fuselage:
קובץ מצורף 82484
Waiting for the motor to arrive -
קובץ מצורף 82804
Motor has arrived and has been inserted/installed. It is a hobby king/turnigy 2217 1000kv out runner -
http://hobbyking.com/hobbyking/store...idProduct=5690
Total glider weight, including an oversize battery, is 1010g. CG is dead on. It is programmed on a Futaba 9C on GLID 2F-C (i.e. a channel per servo). I have NOT yet programmed in mixes (first time...) We shall see how it all works.
M
