קיימות שתי שיטות (2 דגמים למצלמה) למצלמה של הסיני השיטה ה 2 עובדת אצלי
* HOW TO SET THE DATE TIME
The camera keeps the date and time as long as the battery is not dead. It stamps the date time in the upper left corner of all video, and the date time property of all AVI and JPG files.
If you don’t set the date time, 1980 Jan 1 will be used.
For example, to set the date time to May 13 2009 at 3:10pm:
Connect the USB. Create a time.txt file in the flash root with one line inside in this format:
2010.03.20 15:12:00
Disconnect the USB. The camera will read the file, change the camera date time, and delete the file.
The Micro SD Camera (Methode 2)
For some cameras – settime.txt and time.txt files don’t work at all. It has to be a file named tag.txt reading EXACTLY this way:
[date]
2010/03/20
03:45:00
There must be a space after the first line AND AFTER THE SECOND LINE.
The time stamp will start when the key chain camera is powered on with this file on the root ( not when it’s crated) so create it with a time a minute ahead and then disconnect it from the USB (the proper way) and power up the keychain cam at that time.
ד"א .. שגיאות האנגלית כך במקור ...
אלון.
