ok
from the rc forum out there:
Here's a script I use all the time (I didn't write it). It doesn't shut the camera down at the end of the sequence but does allow you to change the number of shots, start delay, interval etc. just copy the code into notpad and save as a file with a .bas extension
rem Author - Keoeeit
rem Written for S-Series
rem Should be okay on others
rem Use Endless mode with caution
rem See documentation for important info
@title Ultra Intervalometer
@param a Delay 1st Shot (Mins)
@default a 1
@param b Delay 1st Shot (Secs)
@default b 0
@param c Number of Shots
@default c 600
@param d Interval (Minutes)
@default d 0
@param e Interval (Seconds)
@default e 3
@param f Interval (10th Seconds)
@default f 0
@param g Endless? No=0 Yes=1
@default g 0
p=a*60000+b*1000
t=d*60000+e*1000+f*100
if c<1 then let c=5
if t<100 then let t=100
if g<0 then let g=0
if g>1 then let g=1
if p<0 then let p=0
z=t*c
y=p+z
print "1 Cycle Time:", y/60000; "min", y%60000/1000; "sec"
goto "interval"
:interval
if p>0 then gosub "pause"
print "Shot 1 of", c
shoot
for n=2 to c
sleep t
print "Shot", n, "of", c
shoot
next n
if g=1 then goto "interval" else end
: pause
n=(a*60)+b
for m=1 to n
q=n-m
print "Intvl Begins:", q/60; "min", q%60; "sec"
sleep 930
next m
return
