מכירים את הביטוי- לא ניתן/אי אפשר וכו' .. אלא אם כן מחפשים ומחפשים ולא מוצאים ...
בקיצור, כן ניתן לבצע THR-CUT לטיסנים חשמליים בשלטי פוטאבה (אני ביצעתי זאת ב- 9CAP) ...
הדבר מתבצע ע"י מיקס פשוט ... ע"מ להגיע לשני כיווני ה- RATE יש להזיז מעט את סטיק המצערת למעלה ולמטה
להלן ההוראות :
Setup Process For the Spektrum DX7 Transmitter:
From your selected plane setup menu (pressing scroll and select simultaneously) move to one of the mixing channels (I prefer to set this as mix 1 however any of them should work).
Select source and destination for the mix to be THRO (short for throttle), the display should show:
THRO -> THRO
Now move to the rate section and set both sections to -100% (you will be able to set one of them with the throttle stick down and the other with it up).
Move to the SW: section and set it to MIX
Move to the OFFSET section and set it to -100%.
If you toggle to switch at the top right of the transmitter you should see the text to the right of the THRO -> THRO change from OFF to ON, when this reads ON the throttle is disabled (this should be with the switch pulled toward you). Your mix screen should look like:
[PROG.MIX1]
THRO->THRO ON
RATE: -100%
-100%
>SW:MIX
OFFSET:-100
Carefully try this out with your model turned on, with the switch toward you it should not be possible to start the motor at all (even helis should be disabled despite the position of the idle up switch).
All that remains now is to cultivate the habit of ensuring the switch is in the disabled position whenever you pick up the aircraft and whenever it is not on the flying field.
Another way :
- Select one of the P-MIX
- Set High Rate = -100
- Set Low Rate = -100
- Set X Offset = +0
- Set Y Offset = - 100
- Set as LINEAR
- Set Act = ACT
- Set SW = SF
- Set MASTER = THR
- Set MASTER LINK = OFF
- Set MASTER TRIM = OFF
- Set SLAVE = THR
- Set SLAVE LINK = OFF
