PRICE LIST-----PRICE LIST-----PRICE LIST-----PRICE LIST
January 2011
MODEL RETRIEVE BEACONS AND TRANCEIVERS.
Locating your model with a model retrieve beacon (transmitter/tracker) is today essential. If you have a small transmitter in your model, you can locate your model at distances of 500-1000 meters. Lost models are unknown for model retrieve transmitter users. An exception is of course a total "fly-away" although models have been located at distances of 50 km. or more. Retrieving models can be done up to two weeks or more depending on the type of battery you use (BR435).
"If you start to use a model retrieve beacon, you know how much you suffered before!"
BEACONS
• Flat, fit F1B models Andrukov and Vivchar, with battery holder for BR425/435 3 volt Lithium battery.
Size 13 X 17 X 6 mm. (WxHxT) without battery. Height with BR435 Battery 37 mm. With BR425 battery 27 mm.
Battery plugs into Beacon. Weight 3.0 gr. with battery (BR425)
Battery life at least 14 days continuous operation (BR435).
• Round, fit Russian models. With battery holder for BR425/435 3 volt Lithium battery
Size 9 X 21 mm. (RXH) without battery. Height with BR435 Battery 45 mm. With BR425 battery 35 mm.
Weight 3.0 gram with battery. (BR425).
• Without battery, with wires for separate battery connection
Size 8 X 16 X 6 mm. Weight 1.3 gram without battery can also be used for further encapsulation.
Prices: per beacon:
1 beacon, incl. 2 batteries (BR435) € 85,--
2 - 4 beacon at the same freq. Incl. 1 battery per Beacon (BR435) € 80,--
5 or more at the same freq. Incl. 1 battery per Beacon (BR435) € 75,--
I keep beacons with new frequencies in stock, also Starter kits.
Orders for Beacons at a specified frequency take 4-6 weeks for production.
Please specify with order your frequency and the type of Beacon you need. If type of Beacon not specified, the standard “flat” type with integrated battery holder will be send.
If you never had an assigned frequency I will assign one. Be aware that all frequencies between 140 and 160 MHz. are assigned. If you need a new frequency I will assign you a frequency, which is shared by a flyer far from your area. I maintain a list of all by me and Doring assigned frequencies
• Repair and exchange : Beacon small repair, replacement antenna, batt. holder etc.
and exchange for an other frequency or other type (round or flat) € 20,--
including packing, postage and 2 batteries BR435.
Defective electronics and crystal will be replaced at cost price.
Prices for Beacons above include package and postage..
All items listed below the line do not incl. postage
BATTERIES
Lithium battery BR-435" blister package of 2 2 for € 2,-- Postage € 2,-- up to 18 batt.
3.0 volt, cap. 40mah. 4 X 35mm. Weight 0.75gr. Postage € 3,-- up to 42 batt.
Lithium battery BR-425" blister package of 2 2 for € 2,-- Postage € 2,-- up to 18 batt.
3.0 volt, cap. 20mah. 4 X 25mm. Weight 0.5gr. Postage € 3,-- up to 42 batt.
TRANSCEIVERS
HORA C150 (Standard C150) Transceiver, with dry battery case € 195,-- + Postage € 15,--/€ 25,--
Transmitting and Receiving 130 MHz. – 174 MHz., 5 Watt max. (12 volt)
20 channel memory. Leatherette case incl.
Sensitivity less than 0,16 microvolt
Transceiver has a dry battery case for 6 AA type batteries
Dimension 55(w) x 31(d) x 124(h) mm. With battery case
Transceiver modified for extended frequency range and “S” meter for short pulses
HORA C150 with extra 7,2 volt Nicad pack and 220 volt charger € 220,-- + Postage € 15,--/€ 25,--
ALINCO DJ-195 Transceiver € 245,-- + Postage € 15,--/€ 25,--
Transmitting and Receiving from 130 MHz. – 174 MHz., 5 Watt max.
40 channel memory
Sensitivity less than 0,2 microvolt
7,2 volt Nicad batterypack and wall charger included
Dimension 56(w) x 40(d) x 124(h) mm. With Nicad batterypack
Accessories for the HORA C150
Nicad battery 7,2 volt , 700 Mah. Incl. charger 220 volt € 35,-- Ask for Postage
Dry battery box € 25,-- Ask for Postage
For new starters with model retrieve systems I offer so-called Starterkits.
HORA C150 Transceiver with one beacon € 270,-- + Postage € 15,-- / € 25,--
HORA C150 Transceiver with two beacons at one frequency € 340,-- + Postage € 15,-- / € 25,--
HORA C150 Transceiver with three beacons at one frequency € 410,-- + Postage € 15,-- / € 25,--
Alinco DJ-195 Transceiver with one beacon € 320,-- + Postage € 15,-- / € 25,--
Alinco DJ-195 Transceiver with two beacons at one frequency € 390,-- + Postage € 15,-- / € 25,--
Alinco DJ-195 Transceiver with three beacons at one frequency € 460,-- + Postage € 15,-- / € 25,--
Additional freq. per Beacon € 5,-- Included with order
Each additional beacon € 70,-- Included with order
ANTENNAE
Telescope “Long Ranger” € 25,-- + Postage € 7,-- / €12,--
Rubberduck replacement € 30,-- + Postage € 2,50 / € 3,--
Yagi HB9CV with cable and plugs € 75,-- + Postage € 15,-- / € 25,--
Packing and postage not included for articles on this page.
Postage indicated in second column for outside Europe.
I prefer to deliver and payment at the flying site.
If you order by (e-)mail you have to pay the P&P (registered).
All orders pre payment, or delivery at flying site (no postage) !!!!
Please pay with:
• Cash in a letter, use a (good sealed with tape) registered letter.
• PayPal (Add 4% to the Invoice) Use my e-mail address as beneficiary.
• Into my ING Account with IBAN, Financial Plaza, Amsterdam.
P. Ruyter, Hoevelaken, Netherlands
IBAN: NL05INGB0006708256
BIC/SWIFT: INGBNL2A
Using the IBAN number and BIC code will give you a bankcharge free money transfer within the Euro currency area (use SHA for cost sharing).
For Bank checks and personal checks outside Euro currency area add. Euro 20, - for bank charge or at “OUR” (your cost).
Pim Ruyter
Kantemarsweg 36
3871 AP Hoevelaken
Netherlands
Telephone: +31 33 2581459 E-mail:
pim.ruyter@planet.nl
