היי
מעוניין לקבל SETUP עדכני מהסיני עבור הטיסן הנ"ל (כל הקישורים בקטגורית סטאפים לא עובדים)
מציין שרוצה לעבוד עם SETUP של 3 תאים בלבד,
מה יהיה ה SETUP המהיר ביותר ?
אשמח לקבל ליניקים
תודה מראש לעונים !!!
היי
אשמח לקבל ליניקים
Hi, these are links to the original MPX*UK and Sweden
Hope it works out for you, motor has to be approx. 2900 KV
http://www.modelmaniacsonline.co.uk/...ManCode=332657
http://www.autopartner.se/multiplex-...ternalsearch=1
The Swedish krona exchange rate to the Shekel is: 2.2 Swedish Krona = 1 Shekel
Hobby king version
http://hobbyking.com/hobbyking/store...arehouse_.html
http://hobbyking.com/hobbyking/store...trSearch=prope
you might want a 6x5" prop instead
נערך לאחרונה על ידי Ronny Cohen; 27-01-2015 בשעה 14:51:23.
תודה רוני
אתה יודע כמה יתן הסטאפ הסיני ?
Here is what the MPX setup gives in term of power, check the link. If you buy a complete set you get all the mounting
extras needed for you Funjet Ultra, other wise you need to buy those separately
(the current drain with a 6x5.5" prop will be approx. 65A-70A , the Himax motor offered is a 2980 KV (103 Grams and a maximum of 90A
You will need this as well: Multiplex engine mount FunJet ULTRA
If you do not already have one
http://www.multiplex-rc.de/en/produc...65ebbef2028034
Specification
kV: 2980
Cell count NiXX/LiPo: 6-9/2S-3S
Optimum working point: 55 A - 70 A
Max. Current for 15 s: 90 A
״: 35 mm
Length: 37 mm
Weight: 103 g
Shaft ״: 4 mm
Mounting : ״ 16 mm/4xM3
The Hobby king setup is not as powerful, It is a 3000 KV max 55A, approx. 750W 3 pole motor
Specs:
Model: NTM Prop Drive Series 2836 3000kv
Kv: 3000rpm/v
Poles: 3
Motor Wind: 5T
Max current: 55A
Max Power: 396W @ 11.1V (3S) / 755W @ 15V (4S)
Shaft: 4mm
Weight: 87g
ESC: 35~45A
Cell count: 3s~4s Lipoly
Bolt holes: 16mm & 19mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
Prop Test Data:
4.5x4.5 - 11.1V / 334W / 30.1A / 0.82kg thrust
4.5x4.5 - 14.8V / 755W / 51A / 1.31kg thrust
4.75x4.75 - 11.1V / 396W / 35.7A / 0.836kg thrust
and you need some extras,
this motor setup comes from European wear house.
If you have the budget for it: I Would say
buy the original setup with the HiMax motor from MPX, it would fit directly and
most likely be more fun to put together and fly, see the link below
http://www.multiplex-rc.de/en/produc...2664c2c55dbbf8
נערך לאחרונה על ידי Ronny Cohen; 27-01-2015 בשעה 23:55:53.
הטיסנים שלי
park master 3D
velocity 2 thunder tiger
המכונית שלי:
traxxas son uve digger with brushless
http://traxxas.com/products/models/e...igger-features
At least to me, I use these internet sites. sorry it took awhile to respond.
