מציג תוצאות 1 עד 4 מתוך 4
מאמר: Hobby King Gemini 600 review
  1. תאריך הצטרפות
    Aug 2010
    Jump to Comments
    3 Comments by Published on 03-01-2011 16:42:05
    [LEFT][LEFT][LEFT][LEFT]
    When I was asked to review the Gemini 600 catamaran I grabbed the chance immediately, a catamaran is defiantly the fastest and most fun way to sail.
    Huge sails area low weight/draft/drag the catamaran concept introduced to the sailing world what the jets offered to aviation.
    As RC sailing implements same principles of full size sailing boats, I was very happy to enjoy all catamaran benefits over my RC keel boat (HK Monson).
    Packaging:
    un typical for HK packing was not done properly, the bows of the boats penetrated the cardboard protection and this have resulted in damaging the left bow.
    Kit Contents
    Hull (Length: 600mm, Width: 285mm)
    Boat stand
    Mast (Height: 1100mm)
    Rudders and centerboards sets
    Sails set (Sail area: 1700mm2)
    Hatch lids set
    Required for Completion
    2~3S 7.2~11.1V lipo battery
    Radio System (3ch) & Receiver
    Assembly
    The Hobby-king Gemini 600 will require some assembly work to have it complete. This Almost ready to sail was ready with about 2 hours of work
    Done by the factory
    Motor installed
    All servos installed
    main and jib shits installed
    Shrouds installed
    The builder needs to
    build the boat stand assembly
    Install the rudders
    Install the centerboards
    Install radio system
    Attach the main sail to the mast
    Assemble the rig
    Building review
    • Builder needs to attach mainsail to mast by method of rope loops which isn’t that neat.
    • Although specifically mentioned and refer to in the manual the hexagon wrench wasn’t supplied in the kit.
    • The rudders axis slots in the hulls were clog up and had to be re-drilled
    • The left rudder's hexagon securing screw was missing (I have used a screw I have taken for an old propeller hub).
    • The rudders control rod was too long and I had to bend it in order to fit to length
    • The railing holes do not fit the railing
    Conclusion
    The fiberglass hull is beautifully built with many scale details like: wooden deck, fore-deck net, windows, etc.
    Very nice sails including sail battens and fingers load patches, got a blue colored jib which was very refreshing comparing to the common white.
    The Gemini sails like a dream, very easy to handle even in gusty condition as the catamaran configuration is very successful in limiting the boat from getting to high heeling angles.
    Big advantage over keel boats as there is no need for ballast lead shots. Also, the model has very small draft and can be sailed in very shallow ponds.
    Last but not least: that 380 motor give you extra confident (I have used it with a 3 cell battery), now any day is a good day for sailing, no more mid pond drifting till wind will resume, just turn on the motor and your Gemini will be back ashore before dark.
    Pluses
    Excellent looks
    very stable and easy to handle boat handling
    motor backup
    Low draft
    Minuses
    tacking to wind could be somewhat tricky.
    Electronic hatch quiet small
    Light wind maneuvers are difficult
    Boat might capsize by sudden gust.
    Sail control servo isn’t strong enough to handle the sail loads in strong wind conditions
    Sail control servo doesn't have enough travel to allow the sails to by fully released for downwind sailing.
Name:	on shore 2.jpg‏
ID:	36862   Click image for larger version.
ID:	36863   Click image for larger version.
Name:	damege close.JPG‏
ID:	36864   Click image for larger version.
Name:	hull bottom.JPG‏
ID:	36865   Click image for larger version.
Name:	boat stand.JPG‏
ID:	36867   Click image for larger version.
ID:	36868   Click image for larger version.
Name:	rudders and centerboards.JPG‏
ID:	36869   Click image for larger version.
ID:	36870   Click image for larger version.
Name:	main attachment .jpg‏
ID:	36872   Click image for larger version.
ID:	36873   Click image for larger version.
ID:	36874   Click image for larger version.
ID:	36875   Click image for larger version.
ID:	36877   Click image for larger version.
ID:	36878   Click image for larger version.
ID:	36879   Click image for larger version.
Name:	on shore 3.jpg‏
ID:	36880   Click image for larger version.
Name:	on shore 4.jpg‏
    נערך לאחרונה על ידי אבו חומוס; 03-01-2011 בשעה 17:56:41. סיבה: הוספת סרט
  2. Total Comments 3
    תגובות
    Or Yehuda, Israel
    הודה 5 פעמים ב 3 הודעות
    ברירת מחדל תגובה להודעה: Hobby King Gemini 600 review
    Great review!
    I enjoyed reading your review, hope to see you write some more
    Shay
    Nice review and looks like fun boat.
    I see it was manufactured especially for Israel with our flag colors...
    איזור השרון
    התמונות מקסימות ,
    נסה לייצר וידאו יותר מעניין , יש לך סירה כל כך יפה בידיים .
    אתה חייב לממש את הפוטנצייל הניהולי שטמון בך
    תודה על הסקירה בכל אופן .
Similar Articles
  1. תל אביב והסביבה שלט Hobby King 2.4Ghz 6Ch Tx & Rx V1 Mode 2
    על ידי liorz055 בפורום רדיו, אלקטרוניקה וציוד נלווה
    הודעה אחרונה: 12-06-2010, 18:09:31
  2. [דיון] Hobby King 2.4Ghz 6Ch Tx & Rx
    על ידי OneLink בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 22-05-2010, 11:28:55
  3. Hobby King Piaget EPP-CF 3D
    הודעה אחרונה: 04-05-2010, 13:25:17
  4. בעיית שרות ב HOBBY KING
    על ידי amiteini בפורום פורום מסוקי דלק
    הודעה אחרונה: 03-02-2010, 08:52:47
  5. ספר הוראות ל HOBBY KING 4 OR 6 2.4
    על ידי k_aviv בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 20-05-2009, 12:42:45
