אז גם ספקטרום משחררת שלטים חדשים לשוק:
DX8
ו-DX10t שמתאים יותר לשוק ה"גרמני" - שלט מגש כמו המולטיפלקס
DX8
נתונים על ה-DX8:
SPM88001EU range DX8 Set, Mode 1
SPM8800EU range DX8 Set, Mode 2
What's inside:
• Spectrum DX8 Channel
• Spektrum 8 Channel Receiver
• Spectrum telemetry transmitters
• Sensors
Description:
The DX8 is a better range of hand-held transmitter for the aspiring model pilots. The investment follows a modern design with an impressive ergonomics. All controls are within comfortable reach,
even if you have smaller hands. Course
DX8 is the spectrum with the unique
DSM2 transmission system facilities. It offers a fast and secure link to the model. Of course, this also includes remote control system
in the range of equipment used to make Bind and Fly fly models of Horizon.
The facility is equipped with telemetry. This permits real-time monitoring of flight log data and the power supply and
Data from other external sensors. The facility has a modern and very ergonomic
Software that is fast and intuitive. Extensive functions for area pilots,
as well as for helicopter pilots from the software feature.
Internally, the system stops at 30 model memories. The built-in SD card reader, however, allows an approximate
unlimited number of model memories. In addition, software updates can be easily performed.
The spectrum DX8 is supplied with 4 languages.
It can be set to 3 service areas
- EU, France and U.S.. Furthermore, the investment in Mode 1 can be flown to 4. DX8 The spectrum needs are met almost all of the dedicated model airplanes.
Kit contents:
Features:
Real-time telemetry
Strength
Recipient or flight battery voltage
Flight Log data
Sensor data
SD / MMC card for storage / software update
30 model memories
large backlit LCD
Electronic Maximalwegbegrenzung
8-channel receiver with telemetry interface
Stopwatch on gas activated
adjustable Language
Alarm
Examination of the transmission data
Mode 1-4 selectable
Special flight functions:
Delayed flap
Free switch allocation
Alerting capabilities for selected joystick
Special helicopter functions:
Electronic E-Ring
active attitude of the gyro gain
Swashplate Timing
selected alerting
Required accessories:
The facilities of other models, the telemetry modules and boards / Sesoren are also available separately.
Each spectrum receiver with a data port is compatible with the telemetry module.
SPM9548
Telemetry Module
SPM9560
Air Speed Sensor Telemetry Board
SPMA9569
Air speed sensor
SPM9561
Aircraft telemetry battery power board
SPMA9570 battery voltage
Sensor
SPM9562
Aircraft Telemetry Temperature Sensor Board
SPMA9571
Aircraft
Temperature Sensor
Connecting in series of connected boards are available in lengths.
6 "= 15.24 cm SPM9563
9 "= 22.86 cm SPM9564
12 "= 30.48 cm SPM9565
Other Accessories:
DX8 16MB SD card SPMA9649
נראה מוזר ש-Spektrum מוציאים שלטים חדשים על בסיס השלטים הקודמים שלהם, אבל יפה.
תודה על הפירסום.
שלטים מכוערים רצח!!!
בסגנון של DX6/ DX6i - לא הייתי קונה אותם גם בחצי מחיר של DX7
גרג
נ.נ.
שוב זה דעתי האישי שלי.
פשוט שיא הכיעור
במלה אחת...
איכזבו.
לא משהו בכלל !! לא השלטים ולא רמת היופי שלהם!!
גיא יצא לך להחזיק את השלט של JR כבר ה11X ?
הוא בהחלט נראה מליון דולר אך בעיינין הכבד והגדול אין לי מוסג!
בכל זאת הכל אותו דבר הכול תלוי בנו
באצבעות שלנואך למה להתווכח שאלן זאבו מטיס עם ספקטרום DX 7 ? לא JR לא הייטק ולא המולטיפלקס
בברכה
גל אסולין....
Trex 700
Trex 250 se
protos 500
scaedu 50 evo
katana
cassna
hitec Aurora 9
rd 8000
מספיק לא?
בתור אוהד של ספקטרום פשוט אכזבה ה-DX8
גם מבחינת העיצוב וגם מבחינת הלחצנים !
מזכיר מאוד את ה-DX6 וזה זכרון לא טוב![]()
בכבוד רב,
שגיא אדיר
T-Rex 700N LE
V-Bar SL Pro
Ys 120 3D
DX8
הם כנראה בכוח מחפשים לפשוט רגל... חבל שהם לא מבינים שה"לוק" החיצוני לא פחות חשוב מהתוכן, אני עדיין אאחל להם בהצלחה!
קצת מבאס הרי הוא נראה כמו הDX6...
הDX7 מדהים ולא משתווה ביופי לידם!
ברסמי אם הם היו משנים ומשפרים את היופי זה היה עוזר להם מאוד.
נערך לאחרונה על ידי Amir-Cosworth; 07-02-2010 בשעה 06:33:13.
http://http://up197.siz.co.il/up3/lcgtdyy4hyjo.jpg
מחפש מטען ליפו פשוט שיהיה סבבה לא משהו חללית אבל יפה ודיגיטלי(רצוי)
ובמחיר טוב קנייה מיידית!
לפנות לפרטי!
כולם מתרכזים בקנקן ולא במה שיש בתוכו.
חכו קצת, יתכן שתג המחיר ואיכות השלט ישנו את דעתכם.
ציקי
ברור שאתה צודק אבל מי יקנה שלט מכוער .... אז מה אם הוא טוב והוא מציע מספר שיפורים מעניינים אך זה לא תמיד ימשוך אנשים לקנוות אותו !(אותי בכל אופן ...)
אני לא היייתי קונה כזה שלט גם אם הוא היה הכי טוב !~ לא בהכרח צריכים לקנות את הכי טוב !
אני עכשיו צריך לקנות שלט ואחת החשיבות שלי (שברור שהחשובה ביותר היא הפונקציות שיש בתוכו והנוחיות ) אך הייתי הולך גם טיפה על היופי !
כי אם שלט לא יפה אין די "בהנאה" להטיס איתו !
ציקי שלא תבין אותי לא נכון זו דעתי ומקווה שלא תעלב או תפגע
בברכה
גל אסולין....
Trex 700
Trex 250 se
protos 500
scaedu 50 evo
katana
cassna
hitec Aurora 9
rd 8000
מספיק לא?
ולגבי תג המחיר יתכן שאתה צודק יכול להיות שזה ימשוך אנשים
כמו שקודמו ה DX 6 וה DX6I משכו אנשים לקנייתם ...![]()
בברכה
גל אסולין....
Trex 700
Trex 250 se
protos 500
scaedu 50 evo
katana
cassna
hitec Aurora 9
rd 8000
מספיק לא?
אני נוהג להטיס את המסוק ולא את השלט לכן היופי צריך להתמקד לדעתי במסוק ולא בשלט.
אם שלט מכוער,נוח לי פונקציונלית, ארגונומית, בעל תג מחיר טוב ובנוסף יגרום למסוק שלי לטוס בטוח יותר מאחד אחר אטיס איתו גם אם הוא לא יהיה היפה ביותר
חכו בסבלנות, לא הייתי מספיד כל כך מהר את ספקטרום.
