עמוד 5 מתוך 8 ראשוןראשון ... 34567 ... אחרוןאחרון
מציג תוצאות 101 עד 125 מתוך 179
נושא: F-14D
  1. #101
    Dec 2009
    הודה 46 פעמים ב 44 הודעות
    ברירת מחדל תגובה להודעה: F-14D
    L/E Slats installed and running
Name:	F-14D Project 043.jpg‏
ID:	33606   Click image for larger version.
Name:	F-14D Project 044.jpg‏
ID:	33607   Click image for larger version.
Name:	F-14D Project 046.jpg‏
ID:	33608   Click image for larger version.
Name:	F-14D Project 047.jpg‏
ID:	33609   Click image for larger version.
Name:	F-14D Project 049.jpg‏
  2. #102
    Dec 2009
    A minor disaster struck today when I found that the starboard wing is misaligned with the port wing in means of dihedral (both lateral and incidence), the problem lays with the fact that the wing is supported by a large bushing that is secured within the inner structure itself . After some thought I finally came to a conclusion that there is no other way to fix this but to cut open the wing and get access to the mentioned part , cutting it loose and reposition it in the right angle by means of securing the wing in it's correct position while the glue sets. After some tedious work the results are more than satisfying ....now what is left is to further reinforce the area with carbon rovings and close back the cavity...
Name:	F-14 Twin project misc' pics 041.jpg‏
ID:	33785   Click image for larger version.
Name:	F-14 Twin project misc' pics 042.jpg‏
ID:	33786   Click image for larger version.
Name:	F-14 Twin project misc' pics 045.jpg‏
ID:	33787   Click image for larger version.
Name:	F-14 Twin project misc' pics 044.jpg‏
  3. #103
    Dec 2009
    Just to explain ...the pictures show the status prior the fixing.
  4. #104
    An impressive job, a well done work !!!
    All you need now is a flight control computer... you have to manage aircraft wing position,flaps,slats, air brakes
    augmented lateral and longitudinal stability
  5. #105
    Dec 2009
    First, I do have one.....Second, I don't need it
  6. #106
    Dec 2009
    Here are pictures of the fix
Name:	F-14 Twin project misc' pics 047.jpg‏
ID:	33846   Click image for larger version.
Name:	F-14 Twin project misc' pics 048.jpg‏
ID:	33847   Click image for larger version.
Name:	F-14 Twin project misc' pics 049.jpg‏
ID:	33848   Click image for larger version.
Name:	F-14 Twin project misc' pics 050.jpg‏
ID:	33849   Click image for larger version.
Name:	F-14 Twin project misc' pics 052.jpg‏
Name:	F-14 Twin project misc' pics 051.jpg‏
  7. #107
    Dec 2009
    Comparison pictures....
ID:	33852   Click image for larger version.
  8. #108
    Dec 2009
    Wings finally done ......
Name:	F-14D Project 055.jpg‏
  9. #109
    Or Yehuda, Israel
    הודה 5 פעמים ב 3 הודעות
    מתי יהיה סרטון של המערכת בפעולה?
  10. #110
    Dec 2009
    המערכת היא אבטיפוס ואינה ברת שימוש בעת טיסה במתכונתה הנוכחית .... לאחר ניסויי טיסה בסיסיים היא תוחלף באחרת שעימה יבוצעו הטיסות עם שינוי גאומטריית הכנפיים.
  11. #111
    Dec 2009
    Swing wing mechanism....
  12. #112
    הודה 186 פעמים ב 131 הודעות
    LIKE!
  13. #113
    הודה 12 פעמים ב 4 הודעות
    שאלה שהכנפיים במצב סגור אין מאזנות ושאלה נוספת האם במצב סגור הטיסן הרבה יותר מהיר
    פרויקט מאלף ללא ספק כל הכבוד
  14. #114
    Dec 2009
    לטיסן כמו המטוס אין מאזנות כלל.....המטוס שולט על ציר הגלגול עם מייצבי הגובה משולבים עם פעולת מחבלי אויר שעל הכנף......ובמצב משוך לאחור רק מייצבי הגובה.
    הנך מוזמן לעיין בכל השרשור מתחילתו.
  15. #115
    Dec 2009
    ראה תמונה חמישית בהודעה מס 101.
  16. #116
    ציטוט נכתב במקור על ידי MCMF צפיה בהודעה
    אוקיי מובן מה לגבי מהירות הטיסה במצב כנפיים משוך לאחור האם זה יעשה בטיסה ואך תופעה זו תשפיע על הטיסה
  17. #117
    Dec 2009
    מן הסתם המהירות הסופית תגדל כמוכן הרגישות בציר הגלגול.
  18. #118
    הגיאומטריה המשתנית נראית מאוד יפה, תבוצע באויר ?
    יש סכנת פרפור גדולה יותר עם צורת החיבור הזו
  19. #119
    Dec 2009
    ידוע אך מיקום הציר חושב...והוא זהה לחלוטין לאח הגדול.
  20. #120
    Dec 2009
    לא יבוצע שינוי גיאמטריה עם המערכת הנוכחית.
  21. #121
    Dec 2009
    זהו קישור לחומר כתוב על המטוס......
    http://www.anft.net/f-14/f14-detail-wsm.htm
  22. #122
    Dec 2009
    More reinforcement to the wing joiner and it's surrounding area....
Name:	F-14D Project 056.jpg‏
ID:	34423   Click image for larger version.
Name:	F-14D Project 057.jpg‏
  23. #123
    Dec 2009
    Finally the spoiler actuator control horns are ready.... and so are the brass wing bushings with ball racers.
Name:	F-14 Twin project misc' pics 057.jpg‏
ID:	34935   Click image for larger version.
Name:	F-14 Twin project misc' pics 058.jpg‏
ID:	34936   Click image for larger version.
Name:	F-14 Twin project misc' pics 059.jpg‏
  24. #124
    Dec 2009
    And this is my "scrible" form of precision drawing from which the actual part was done after
Name:	F-14D Project 007.jpg‏
  25. #125
    Dec 2009
    Spoiler Servo.
Name:	F-14 Twin project misc' pics 060.jpg‏
ID:	35253   Click image for larger version.
Name:	F-14 Twin project misc' pics 061.jpg‏
