עושה רושם טוב מאוד במחיר מעולה
Just received my glider and i have to say that upon first inspection I'm very impressed. the Phoenix 2000 is well built and the structural support inside the wings was great, aluminum square rod tubing with a 3x2x25mm carbon fiber rod inside. The Blown plastic body is as advertised and seems near indestructible. As for power there is plenty of it, i thought that the included motor wouldn't be enough so i ordered a second higher 2800 kv motor and a 30 amp hk blue series esc but when flying the glider for the first time and pulled a complete loop without using full throttle i knew it wasn't a necessary upgrade. So far I have no complaints but would recommend a few retrofits like adding a foam front wheel to the existing bulge on the bottom of the body for better landings so that nosing into the ground on rougher surfaces isnt a problem. The propeller is good.. but shatters easily so order extras with your purchase I'll get back with the correct size and the differences when I install the new motor and esc for kicks, I am also running a 2200 3s and the cg is a little front heavy but can be compensated with a little finesse and relocation. With my current setup I got concurrent 25 min flight times. Also be sure to order cf or fg rods to reinforce the outer 8 inches of the wings as they take the most beatings in a crash, and have no reinforcing like the rest of the wing
