щъй аефцйеъ моретйн:
геод моеомх - TR 28-30B 14A 1050Kv
Model: TR2830-1050
Max Eff: 12A
Max Load: 14A
Kv: 1050
Weight: 57.9gr
Pull: 400~900gr
Prop: 10x5 or 10x6
Voltage: 6~10v
No Load Curr: .9A
зжч йеъш - Turnigy2836 Brushless Outrunner 1000kv
Dimension: 28mm x 37mm, 55mm(with shaft)
Weight: 80g (kv1000) (not including connectors)
Diameter of shaft:ВЃF4mm
Length of front shaft:ВЃF14mm
Lamination thickness: .2mm
Magnet type: 45SH
Max performance;
Voltage: 3S
Prop: EP10x5
Thrust: 1000g
Power: 300W
For;
800-1000g 3D
1200g+ Trainer
