מציג תוצאות 1 עד 13 מתוך 13
מאמר: HobbyKing Pitts EPP review
  1. תאריך הצטרפות
    Jump to Comments
    12 Comments by sharonx Published on 17-10-2010 00:27:44
    Hello.
    This is a review of HobbyKing Pitts EPP.
    Pitts EPP is an electric aerobatic biplane, made of EPP foam which is very resilient to crashes and almost unbreakable, thus very good for beginners.
    Packaging :
    As always - HK does a very good job packing their models. All parts were covered with bubble-wrap and taped to the box so they won't move or break.
    A you can see - nothing was damaged or broken.
    Whats in the box ?
    - EPP wings,fuse and tail
    - 2212 1400KV 50g brushless motor + GWS 8040 prop
    - Linkage hardware
    - Black Fiberglass reinforcement rods
    - Landing gear + wheel pants
    - Instruction manual
    What you will need to complete the model :
    - 1000-1300 3S Lipo
    - 3pcs of 9g servo
    - 20A ESC
    - 4CH RX and TX
    - Building materials : CA glue, CA accelerator, Ruler, hobby-knife
    The Building :
    The instructions in the manual were very clear. Each step is followed by an explanation and a color photo. There are 60 steps. The building took 5 hours.
    Any beginner can build this model with such detailed instructions.
    So let's begin:
    Step 1 - Fuselage reinforcement rod
    By using a ruler, some tape and hobby-knife I install the rod into the EPP. Glued it using CA.
    Step 2 - Firewall asembly
    Make sure you put it together straigt
    Step 3 - Tail servo's installation
    Step 4 - Canopy asembly
    You will need to cut holes for the servo arms
    Step 5 - Tail asembly
    Step 6 - Wings assembly
    One fiberglass rod is enough because we will ad balsa supports later.
    Step 7 - Glueing the airlions servo arm extension
    I added string for better bonding.
    Step 8 - Wings X reinforcement
    You need to reinforce the wings using X shape from fiberglass rods, one X in each side. This stiffens the wings very much.
    Step 9 - Tail skid
    Test Flight :
    This motor has a lot of power. It hovers just over 1/2 throttle, and has a very good vertical power at full throttle. Takeoff from the hand is easy. Takoff and landing on the the runway is very fun - you can takeoff after 5 meters or let it ride and slowly pull up so you get a nice scaly takeoff.
    Taxi is very easy thanks to the surprisingly efficient rudder.
    The rudder, althogh looks very small for a 3D plane, does an excellent job in the air. The Alirons don't have enough throw so I will need to add a carbon stripe so all the ailerons will move and not just the part that is close to the horn. Also I consider changing to a 14g 2.5KG servo. The 9g 1.6KG servo I used can't move the 4 ailerons to their desired end-point.
    I coun't attempt much 3D flight because of this, and after I fix this I will post a 3D flight video.
    Just flying the model was great fun, very stable and easy to fly, thus suitable for begginers and medium-level flyers.
    Landing this model on the runway is so much fun - take a look at the second half of the video.
    In Conclusion :
    This is a very good model both for begginers and for experienced pilots who want a fun 3D park flyer. Building is easy and fast, the price of the model is low and its flying characteristics are very good.
    Just need to fix the airlions problem and it will probably be a great 3D plane .
    תמונות מצורפות Click image for larger version.
Name:	IMG_6181 (Custom).JPG‏
ID:	33313   Click image for larger version.
Name:	IMG_6182 (Custom).JPG‏
ID:	33314   Click image for larger version.
Name:	IMG_6183 (Custom).JPG‏
ID:	33315   Click image for larger version.
Name:	IMG_6184 (Custom).JPG‏
ID:	33316   Click image for larger version.
Name:	IMG_6186 (Custom).JPG‏
Name:	IMG_6187 (Custom).JPG‏
ID:	33318   Click image for larger version.
Name:	IMG_6188 (Custom).JPG‏
ID:	33319   Click image for larger version.
Name:	IMG_6189 (Custom).JPG‏
ID:	33320   Click image for larger version.
Name:	IMG_6190 (Custom).JPG‏
ID:	33321   Click image for larger version.
Name:	IMG_6191 (Custom).JPG‏
Name:	IMG_6192 (Custom).JPG‏
ID:	33323   Click image for larger version.
Name:	IMG_6193 (Custom).JPG‏
ID:	33324   Click image for larger version.
Name:	IMG_6194 (Custom).JPG‏
ID:	33325   Click image for larger version.
Name:	IMG_6195 (Custom).JPG‏
ID:	33326   Click image for larger version.
Name:	IMG_6196 (Custom).JPG‏
Name:	IMG_6197 (Custom).JPG‏
ID:	33328   Click image for larger version.
Name:	IMG_6199 (Custom).JPG‏
ID:	33329   Click image for larger version.
Name:	IMG_6200 (Custom).JPG‏
ID:	33330   Click image for larger version.
Name:	IMG_6201 (Custom).JPG‏
ID:	33331   Click image for larger version.
Name:	IMG_6202 (Custom).JPG‏
Name:	IMG_6203 (Custom).JPG‏
ID:	33333   Click image for larger version.
Name:	IMG_6204 (Custom).JPG‏
ID:	33334   Click image for larger version.
Name:	IMG_6205 (Custom).JPG‏
ID:	33335   Click image for larger version.
Name:	IMG_6206 (Custom).JPG‏
ID:	33336   Click image for larger version.
Name:	IMG_6207 (Custom).JPG‏
Name:	IMG_6208 (Custom).JPG‏
ID:	33338   Click image for larger version.
Name:	IMG_6209 (Custom).JPG‏
ID:	33339   Click image for larger version.
Name:	IMG_6210 (Custom).JPG‏
ID:	33340   Click image for larger version.
Name:	IMG_6211 (Custom).JPG‏
ID:	33341   Click image for larger version.
Name:	IMG_6212 (Custom).JPG‏
    נערך לאחרונה על ידי sharonx; 18-10-2010 בשעה 20:53:32.
  2. Total Comments 12
    תגובות
    פרשתי מהתחביב...
    הודה 180 פעמים ב 100 הודעות
    ברירת מחדל תגובה להודעה: HobbyKing Pitts EPP review
    BEAUTIFULLY DONE!!!
    יפה מאוד! עכשיו הלחצת אותי לסיים את שלי מהר....
  5. #4
    באר טוביה
    מגניב!!! תתחדש.
  6. #5
    גר בפלורנטין
    אחלה סקירה! ננסה לשפר את המאזנות, ואז יהיה מעניין יותר
  7. #6
    נען
    הודה 548 פעמים ב 227 הודעות
    3 הודעה/ות
    שרוניקס! סקירה מעולה. מישהו כתב ב RCG שכדאי לפריד את המאזנות.. אולי זאת הבעיה.
    אנחנו שמחים שמצאת זמן בשביל הסקירה תודה! ותהנה מהצעצוע החדש שלך
    צוות eFly
    נערך לאחרונה על ידי MDreamer; 17-10-2010 בשעה 23:23:13.
  8. #7
    תודה רבה דרימר ושאר החברים.
    נהנתי לבנות את הטיסן, פעם ראשונה שאני בונה דו-כנפי וזה שונה במקצת מכנף בודדת.
    אני אנסה את הפטנט של המאזנות. חשבתי בהתחלה להוסיף סטריפ קרבון לאורך במאזנת אבל לא בטוח כמה זה יעזור וגם יוסיף משקל.
  9. #8
    אנחנו סמים שמצאת זמן בשביל הסקירה תודה! ותהנה מהצעצוע החדש שלך
    צוות eFly
    אולי כדאי שתפסיק קצת עם הסמים ?
  10. #9
    ירושלים והסביבה
    הודה 118 פעמים ב 106 הודעות
    יופי של בניה וסקירה שרון...נהנתי לקרוא.
    .Itay.
  11. #10
    רמת גן / הוד השרון
    הודה 24 פעמים ב 17 הודעות
    שרון,
    סקירה שלא הייתה מביישת את אדריכלי RCGROUPS!
    כל הכבוד! נהניתי מאד לקרוא ולראות.
    תודה,
    שחר
    ---Mayor of Happyville---
  12. #11
    תודה חברים טובים. מקווה שלי ולשאר חברי הפורום הפעילים יהיו עוד הזדמנויות לנסות מוצרים חדשים.
    הקישור לסקירה בRCG
    : http://www.rcgroups.com/forums/showthread.php?t=1323863
    וב RCU
    http://www.rcuniverse.com/forum/m_10...m.htm#10073816
  13. #12
    זכרון יעקב
    הודה 163 פעמים ב 125 הודעות
    סקירה יפה מאוד.
  14. #13
    נען
    3 הודעה/ות
    כבר יש כמה הזדמנויות בדרך אחת מהן מאוד מאוד קרובה
Similar Articles
  1. HobbyKing YAK 54 Brushless EPO Plug-n-Fly review
    על ידי liorz055 בפורום סקירות טיסנים
    הודעה אחרונה: 28-08-2010, 15:01:05
  2. Product review- V- Plus 2650mAh 45C lipo - impressions from the sheet and from field
    על ידי bendisar בפורום סקירות רדיו ואלקטרוניקה
    הודעה אחרונה: 21-07-2010, 12:48:19
  3. Review ל Swift 2 + מערכת FPV Fatshark RCV230T
    על ידי MDreamer בפורום פורום אתרים מסחרים
    הודעה אחרונה: 20-02-2009, 19:03:29
