מציג תוצאות 1 עד 25 מתוך 25
מאמר: HobbyKing Aero L-39 Albatros Jet Plug-n-Fly Review
  1. תאריך הצטרפות
    Jump to Comments
    24 Comments by guyst Published on 17-10-2010 16:08:35
    Introduction
    The screaming sound of an EDF along with a jet scale shape in the sky makes every RC addict turn his head and imagine himself in the cockpit performing maneuvers alongside Maverick in Top Gun
    The Aero L-39 Albatros is a high-performance jet trainer aircraft developed in Czechoslovakia. It was the first of the second-generation jet trainers, and the first turbofan-powered trainer produced, and was later updated as the L-59 Super Albatros and as the L-139 (prototype L-39 with engine Garrett TFE731). The design is still produced in an evolved state as the L-159 ALCA, while more than 2,800 L-39s still serve with over 30 air forces around the world. The Albatros – the most widely used jet trainer in the world – is versatile, seeing duty in light-attack missions as well as in basic and advanced pilot training
    Kit Contents
    The packaging was very good as expected from HobbyKing
    In The Box
    Fuselage
    Wing and tail surfaces
    EDF 64 mm – installed
    Motor (3900kv Brushless Outrunner) – installed
    30A ESC
    4 9gr/ servos, installed
    Pre cut canopy
    Factory hinged ailerons
    (Hardware (Push rods, horns, clevis, tires and nose wheel assembly
    Decals and markings already installed
    Y-connector for ailerons
    Epoxy glue
    Allen key
    Picture assembly guide and text instructions
    Required for Completion
    Battery 1300mah 11.1V 3S 25C
    4CH receiver
    Servo extension for the ailerons
    Included for Review
    Optima 6 receiver
    Aurora 9
    3S 1300 mAh 20C and 3S 2200mAh 25C lipo
    Assembly
    The Hobbyking L-39 will require some assembly work to have it complete. This ARF was ready with about 3 hours of work
    Done by the factory
    Ailerons hinged and glued
    Motor installed
    All servos installed
    Paint and markings
    The builder needs to
    Glue the tail and elevator stabilizers
    Install the wings to the fuselage
    Install radio system
    Install the nose of the plane
    Fuselage
    You need to glue the elevator and vertical stabilizer to the fuselage which match perfectly
    The vertical stabilizer does not have functioning rudder
    To ensure that the clevis will not open I have used simple shrinks
    Power system
    The fan and motor were installed at the factory but the ESC was not connected to the motor and to my good surprise there is a hatch to the motor (locked with 2 screws) in case you would replace the motor in the future
    Landing gear
    The main gear has this nice “clips” to simply lock them in
    The nose gear was assembled using the supplied key. It is steerable for better ground handling
    Wing
    The wings have molded pockets that fit the installed 9gr servos perfectly. This allows for short linkages that go directly from the exposed servos to the aileron control surface horns. Each aileron uses a separate servo
    You need to glue the “fuel tanks” to the main wing
    When testing the aileron servos I realized that one of the servos was defective and will not operate as it should. I then decided to replace both servos (to have the same speed and torque) to the HXT900
    Amp draws
    When tested this 3900kv motor on ground it draws around 23-24 Ampere and provides ~240w, though in the air it seems to draw more current as the batteries dried out rather quickly
    Battery
    I fly the L-39 with this base recommended power system (3S 1300mAh) and with 3S 2200 mAh, and it provides nice sport power. It is not the fastest EDF in the sky but it flies well on the stock system. Next I will try a higher C rate than 25C to check of any difference to the watts number
    Flying
    With the 3s battery pack placed in the tray the model was significantly nose heavy. Make sure that you check your CG (75mm from the leading edge where it connect with the fuse). I placed the pack in the nose area the most backward position I could, to achieve the recommended CG
    I used my trusted Aurora 9 transmitter for this plane. Rates were set as to maximum with the horns for high rates. I found the high rates on elevator and ailerons to be much too high so setup 80% dual rates. I used 50% expo for all the primary flight controls. I should note while I liked these rates control surface throws are a very personal preference
    I set the flight timer to count down from 4 minutes of mixed flying and used the telemetry which warned me even before (after less than 4 minutes with the 1300mAh I got ~3.7v per cell)
    The quite large L-39 Albatros is very attractive and an impressive model both on the ground and in the air
    Takeoff and Landing
    The L-39 with the stock power system required about 30 meters of ground roll out on a hard surface to reach flying speed. It was very manageable and stable in pitch and roll authority on take-off
    Landings were also very easy as this model with the quite large fuselage slows down very well. With most EDFs you will need to keep some power on but this one glides pretty well when shutting down the motor, and then it touches the ground very nice and soft
    Special Flight Characteristics
    The L-39 is actually quite simple to fly. It is not overly responsive in pitch, thus loops are not so easy require full power (you can see in the video that I almost stall when I reached the end of the loop). The model stalls very predictably for a light model with this size fuselage. When pushed to a stall (common phenomenon on turns if not flying hard on the throttle) the model slows down considerably and then drops the nose. I noted very little wing tip drop if at all but when turning on slow speeds it needs to be under control
    Rolls are picture perfect with the high rate aileron throws
    Video
    http://www.youtube.com/watch?v=Z-zIJ3m1i9s
    http://www.youtube.com/watch?v=neMbispStCA
    Recommended power system
    The stock power system provides nice sport power but do not expect a rocket ship. I would go for 4S to achieve high speeds and vertical climbs
    ?Is this plane for a beginner
    Although not terribly difficult to fly EDF models are not where beginners need to start. This L-39 was very well mannered and will not cause any surprises to a pilot with just a bit of experience, however the long run for take offs, “nearly stalls” on turns and coming quite hot for landings is something you need to know. This is not a trainer obviously
    Conclusion
    This HobbyKing L-39 seems to be great flying EPS foam model and has no bad habits noted. EDF pilots will love its looks and behavior
    Assembly of this ARF was straightforward and could be less than 2 hours if the aileron servo was not defective and required extra gentle work
    CG was not achieved with the dedicated battery tray even when using the 1300mAh recommended lipo
    It seems this motor is not the strongest while it draws high current and provides 3-4 minutes flying with 1300mAh battery and 4-5 minutes with 2200mAh
    For those who want a power up, note the 4s power systems that will make this model a stunning performer and real attention getter
    Pluses
    Excellent looks
    Flight stable performance
    Lightweight
    Minuses
    No functional rudder
    Motor could be more powerful to my taste
    Considerably low flight times with recommended battery
    תמונות מצורפות Click image for larger version.
Name:	IMG_7159 (Large).JPG‏
ID:	33382   Click image for larger version.
Name:	IMG_7160 (Large).JPG‏
ID:	33383   Click image for larger version.
Name:	IMG_7161 (Large).JPG‏
ID:	33384   Click image for larger version.
Name:	IMG_7162 (Large).JPG‏
ID:	33385   Click image for larger version.
Name:	IMG_7163 (Large).JPG‏
Name:	IMG_7164 (Large).JPG‏
ID:	33387   Click image for larger version.
Name:	AERO%20L-39%20ALBATROS (Large).jpg‏
ID:	33390   Click image for larger version.
Name:	IMG_7115 (Large).JPG‏
ID:	33391   Click image for larger version.
Name:	IMG_7116 (Large).JPG‏
ID:	33392   Click image for larger version.
Name:	IMG_7119 (Large).JPG‏
Name:	IMG_7120 (Large).JPG‏
ID:	33394   Click image for larger version.
Name:	IMG_7124 (Large).JPG‏
ID:	33395   Click image for larger version.
Name:	IMG_7139 (Large).JPG‏
ID:	33396   Click image for larger version.
Name:	IMG_7136 (Large).JPG‏
ID:	33397   Click image for larger version.
Name:	IMG_7137 (Large).JPG‏
Name:	IMG_7144 (Large).JPG‏
ID:	33399   Click image for larger version.
Name:	IMG_7145 (Large).JPG‏
ID:	33400   Click image for larger version.
Name:	IMG_7146 (Large).JPG‏
ID:	33401   Click image for larger version.
Name:	IMG_7153 (Large).JPG‏
ID:	33402   Click image for larger version.
Name:	IMG_7141 (Large).JPG‏
Name:	IMG_7143 (Large).JPG‏
ID:	33404   Click image for larger version.
Name:	IMG_7155 (Large).JPG‏
ID:	33405   Click image for larger version.
Name:	IMG_7156 (Large).JPG‏
ID:	33406   Click image for larger version.
Name:	IMG_7154 (Large).JPG‏
ID:	33407   Click image for larger version.
Name:	IMG_7158 (Large).JPG‏
Name:	IMG_7147 (Large).JPG‏
    נערך לאחרונה על ידי guyst; 23-10-2010 בשעה 17:45:56.
  2. Total Comments 24
    תגובות
    פרשתי מהתחביב...
    הודה 180 פעמים ב 100 הודעות
    ברירת מחדל תגובה להודעה: Aero L-39 Albatros Jet Plug-n-Fly Review
    Looking awesome!!!
    הודה 62 פעמים ב 50 הודעות
    נראה מעולה
    אני מת על הצורה של הטיסן הזה..
    נשמח לסרטון כמובן
  5. #4
    ציטוט נכתב במקור על ידי RonenTal צפיה בהודעה
    נראה מעולה
    נשמח לסרטון כמובן
    יש סרטון (אני מבין שלא קראת את כל הסקירה....) אבל משום מה יש רק לינק ולא תמונה -דרימר...?
  6. #5
    גר בפלורנטין
    מושקע ויפה...
    נראה טיסן מצויין! תהנה ממנו!
    יוסי
  7. #6
    הודה 56 פעמים ב 31 הודעות
    נהניתי מאוד. תהנה.
    גיל ברקאי
  8. #7
    נען
    הודה 548 פעמים ב 227 הודעות
    3 הודעה/ות
    איזה סרטון ואיזה סקירה! גיא שיחקת אותה איזו השקעה!
    לגבי הוידאו נסה לערוך את ההודעה למחוק את הלינק לשמור אותה להדביק מחדש.
    אני לא רוצה לקלקל הפתעה אבל אמורים להיות לנו עוד כמה טיסנים בדרך ואחרי סקירה כזאת אני בטוח שעוד חברי פורום יהנו ממוצרים נוספים!
    חברים אנחנו על המפה!
  9. #8
    ניסיתי ולא עובד...
    ד"א, איך עורכים את הכותרת?
  10. #9
    Jan 2010
    הודה 167 פעמים ב 126 הודעות
    Looks great, the fact that it can glide makes it very attractive choice (at least for me).
    ושיהיה לכולנו רק טוב
  11. #10
    ואם תהיתם איך הוא טס עם מנוע משופר ו-4 תאים (או יותר ) אני מניח - מטורף! יותר מהיר מפאנג'ט!!
  12. #11
    הודה 3 פעמים ב 3 הודעות
    יום שישי אני מביא את ה F20
    נעשה מטס
    נערך לאחרונה על ידי אריה הלפרין; 18-10-2010 בשעה 00:28:45.
  13. #12
    נען
    3 הודעה/ות
    רק מנהל פורום יכול לערוך את הכותרת.. שלח לי מה אתה רוצה שיהיה כתוב לגבי הסרטון אני אשמחק עם זה מחר
  14. #13
    רק להוסיף את המילה Hobbyking בתחילת הכותרת
  15. #14
    זכרון יעקב
    הודה 163 פעמים ב 125 הודעות
    Thumbs up תגובה להודעה: Aero L-39 Albatros Jet Plug-n-Fly Review
    יופי יופי של סקירה.
    אבל כדי שיהיה מושלם צריך לזרוק את הסרטון שלמעט הפתיח, מצולם רע ! להחליף אותו ומהר !!
    (לא לצלם בערב כי התאורה לא טובה, לא רואים כמעט את הטיסן באויר כשהצליחו לצלם אותו בכלל, מה זה צילום הנחיתה הזוועתי וכו')
    אנא להתיחס לזה כביקורת בונה - ולא משהו אחר
  16. #15
    הודה 80 פעמים ב 65 הודעות
    ברירת מחדל תגובה להודעה: HobbyKing Aero L-39 Albatros Jet Plug-n-Fly Review
    פשש מה שאני הפסדתי בשבוע האחרון...
    איך היה לעלות לאויר בלי בקר טיסה צמוד מאחוריך
  17. #16
    Nov 2009
    הרצליה
    הודה 92 פעמים ב 60 הודעות
    יופי יופי של סקירה.
    כן, פיכסה של צלם!!! , לפטר אותו במיידית
  18. #17
    נען
    3 הודעה/ות
    תותחוס! הסקירה התפרסמה
    http://www.rcgroups.com/forums/showthread.php?t=1324664
  19. #18
    מגניב....
    מה עם Rcuniverse ?
  20. #19
    שפירא, המשרה שלך....
  21. #20
    נען
    3 הודעה/ות
    מגניב....
    מה עם Rcuniverse ?
    אתה קשה
    http://www.rcuniverse.com/forum/m_10...m.htm#10076933
  22. #21
    סתם אוהב לראות את השם שלי....
  23. #22
    יופי יופי של סקירה.
    לבקשת עמירם היה "תירגול חוזר" היום...
  24. #23
    דרימר, הסירטונים שוב רואים ואינם נראים בסקירה עצמה.
  25. #24
    פרשתי מהתחביב...
    ולפעם הבאה תארגן לו סט אפ 4 תאים וחמישה צלמים שינסו לעקוב אחריו בשמיים.
  26. #25
    אפשר להתספק ב5 תאים וארבעה צלמים, אייל אחלה תעוד של הקרחת שלי
Similar Articles
  1. [מדריך] פירסמתי סקירה - Aero L-39 Albatros Jet Plug-n-Fly Review
    הודעה אחרונה: 23-10-2010, 18:48:55
  2. סקירת מוצר HobbyKing YAK 54 Brushless EPO Plug-n-Fly
    על ידי liorz055 בפורום סקירות טיסנים
    הודעה אחרונה: 30-08-2010, 13:58:09
  3. סקירת מוצר HobbyKing YAK 54 Brushless EPO Plug-n-Fly
    על ידי liorz055 בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 32
    הודעה אחרונה: 30-08-2010, 10:54:13
  4. HobbyKing YAK 54 Brushless EPO Plug-n-Fly review
    הודעה אחרונה: 28-08-2010, 15:01:05
