מציג תוצאות 1 עד 13 מתוך 13
מאמר: Hobbyking Minemoa 2M Sailplane Review
    זכרון יעקב
    הודה 163 פעמים ב 125 הודעות
    ברירת מחדל Hobbyking Minimoa 2M Sailplane Review
    Part 1
    Introduction
    The Minimoa sailplane, build in the mid 30's, was one of the first sailplanes build by Schempp-Hirth company, a most famous and largest glider manufacturer in Germany and in the world.
    First flown in 1935, the Minimoa with its amazing silhouette was probably one of the most famous gliders of it's time, It was one of the sailplanes symbolizes the German soaring. Because of it's technological breakthrough it was the glider which helped many pilots quit the slope flying and explore the thermal or even the wave soaring. It was a big step from experimental soaring to pure sport flying. It was the first sailplane to carry water ballast, in a tank behind the cockpit.
    In the late 30's (1938) the Minimoa established the world altitude record of 22,000 foot during a flight in a cumulonimbus cloud.
    Richard du Pont and Chet Decker flew Minimoas to win the U.S. Championships in 1937 and 1939.
    The HobbyKing Minimoa RC glider is 1/8.5 scale of the full-sized sailplane, but of course, an electric motor was added for take off assistance
    Link to the product:
    Kit Contents
    The Hobbyking Minimoa was very well packed, in two cardboard boxes, one inside the other. They use lot of adhesive tape, so nothing could have moved or damage while being on the way. Everything arrived in perfect condition with no damage.
    In the box
    Fuselage with installed motor 1200Kv, 20A ESC, spinner and folding prop', two 9gr servos, landing wheel, pushrods
    two wings with aileron servos, pushrod and aileron horn installed
    Canopy
    Elevator with installed horn
    Rudder with installed horn
    Plastic bag contain
    Four nylon screws - 4M - 2 for the elevator, 2 for the wings Phillips head screw driver
    a foam double sided tape
    spare props
    Y-cable for aileron servos
    Aluminum made wing joiner
    wing bracket
    small Allen key with 2 x grub screws
    A tube of unknown adhesive
    Required for Completion
    Battery - 3S 11.1V 20C (recommended - 2200Mah size)
    Receiver – 4 CH (or more) receiver
    No manual or instructions of any kind were in the box.
    Specification
    Wing span: 2000mm/78.7in
    Length: 980mm/38.6in
    Weight: 923g/ 32.6oz include battery & receiver - ready for flight
    Assembly
    The Hobbyking Minmoa requires very little time to make it ready for flying
    Tail
    You should install the elevator with 2 nylon screws (don’t forget to connect the pushrod to the elevator horn first) and than to glue the rudder hinges to the rear part of the fuselage (again, do not forget to connect the pushrod to the rudder horn first)
    Next you have to install your receiver and battery in the fuselage and connect it to elevator and rudder servos.
    Next thing is to balance the glider to the proper CoG.
    As I mentioned before, there is no manual. After short search in the web I found out that 54 mm from the leading edge is a good place to start with. You have to put the battery just behind the motor and to add lead (if necessary, depend on size and weight of Battery), in order to balance the model.
    In order to minimize the motor warm up, I drilled in the spinner's hub 6 holes to allow air to cool the motor.
    End of part 1
ID:	37219   Click image for larger version.
ID:	37220   Click image for larger version.
ID:	37221   Click image for larger version.
ID:	37234   Click image for larger version.
ID:	37236   Click image for larger version.
ID:	37237   Click image for larger version.
ID:	37291   Click image for larger version.
ID:	37292   Click image for larger version.
ID:	37294   Click image for larger version.
ID:	37295   Click image for larger version.
ID:	37296   Click image for larger version.
ID:	37297   Click image for larger version.
ID:	37299   Click image for larger version.
ID:	37300   Click image for larger version.
ID:	37301   Click image for larger version.
ID:	37302   Click image for larger version.
ID:	37304   Click image for larger version.
ID:	37305   Click image for larger version.
ID:	37306   Click image for larger version.
ID:	37307   Click image for larger version.
    נערך לאחרונה על ידי umbo; 11-01-2011 בשעה 17:52:40.
    זכרון יעקב
    ברירת מחדל תגובה להודעה: Hobbyking Minemoa 2M Sailplane Review
    part 2
    I put strong piece of adhesive tape to minimize damage to the foam's front and tail skids.
    That’s all! You are ready to drive to your flying field
    Connect the two parts wing with the wing joiner, connect the ailerons servos to the right channel of the receiver, and than install the wing to the fuselage with the wing support bracket and the supplied nylon screws, ( I must say that in order to assemble the wing and fuselage it's better to get help of somebody else). Install the canopy in place (I recommend replacing the canopy magnet to a stronger one or secure it with adhesive tape) and you are ready for flying.
    Takeoff
    At the Latrun flying field there was light wind, excellent for test flight. After checking all the controls I turned on the motor half way and gave a medium forward throw just slightly above level. I got my left hand onto the transmitter and move the throttle some more up. Climb with 3/4 motor was good but you must give some down elevator to prevent the sailplane climb steeper and steeper. It is a good idea to use throttle\elevator mix to control the climbing angle. You can easily get many good climbs with 3-cell 2200 battery pack.
    Flight
    Once at altitude it handles very well. No trim was needed for level flight. The glider is very stable and you don't need to "fight" the controls. Turns are easy but you must use the rudder (lots of) for nice coordinated turns. (It's a good idea to use ailerons/rudder mix). Once in a turn, you can almost leave the controls – it keeps turning without the pilot do anything. I caught a weak thermal and it was very easy to keep flying in it and even earn some height. To summarize briefly my impression of this model airplane – the Minimoa glides wonderful.
    Stalls were straight foreword with no wing drop and the Minimoa lost just a
    little amount of height, picked up speed and resume normal flight without me doing much of anything. On the other hand, power-on stalls (during climbing) were much more aggressive, the wing tip had dropped and the glider changed rapidly its flight direction (because of the large propeller effect).
    This is a thermal glider and not a plane designed for sport acrobatics. But mostly because of the Aluminum made wing joiner, supplied with the model, (that seem to me not strong enough) I didn't fly any kind of aerobatic maneuvers
    Landing
    Very easy to get ready for landing and to fly the pattern, it flies slowly and you have plenty of time to get ready for touchdown, but it is good idea to plan carefully your glide path because the sailplane refuses to touch the ground and just keeps flying. You can feel the lack of airbrakes or spoilers. It might be a little tricky to land the Minimoa in a very limited area
    Touchdown is very smooth with the installed wheel
    Is this for Beginners?
    There are other planes and gliders better suited for a beginner. This glider would be better for the one with at least some experience or intermediate pilot. I would not recommend for a beginner to fly this glider as the very first model.
    Conclusion
    I really love the look of the gull wings while watching the Minimoa in flight! Everything worked as it should and the plane showed no bad habits so I only have good words to say about this glider. Using the recommended balance point and original controls throws, the plane performed fine on all flights. The 3s 2200Mah Battery balanced the plane perfectly. Purchasing this sailplane is a very good deal
    Thanks to Yosi Ringler for his help in making the video for this review
ID:	37251   Click image for larger version.
ID:	37252   Click image for larger version.
ID:	37253   Click image for larger version.
Name:	Minimoa 13a .JPG‏
ID:	37254   Click image for larger version.
ID:	37260   Click image for larger version.
ID:	37261   Click image for larger version.
ID:	37262   Click image for larger version.
ID:	37263   Click image for larger version.
ID:	37265   Click image for larger version.
    נערך לאחרונה על ידי umbo; 12-01-2011 בשעה 13:49:33.
    הודה 80 פעמים ב 65 הודעות
    Real nice one,
    Did you notice motor overheating as reported on RCG?
    I'm using an 8" prop to avoid it and it gives sufficient pull.
    A good tip is to wrap the wing tips with fiber tape to avoid wing tip breaking and friction with the landing strip.
    A mix of ~15-20% between throttle and elevator would give unbelievable acceleration and flying speeds that will allow rolls and inverted flight.
    נען
    הודה 548 פעמים ב 227 הודעות
    3 הודעה/ות
    Very nice review! i love the landing!
    איזור השרון
    אני לא יודע להסביר את זה , אבל משהו ביופי שלו גרם לי להפוך אותו לכלי הראשון שאני
    רוצה להטיס , אתה יותר מדי מרחם עליו , הוא מסוגל לצלילות ובאזים שאין לך מושג .
    תודה על הסקירה המפורטת .
    זכרון יעקב
    ציטוט נכתב במקור על ידי ilan_l צפיה בהודעה
    אני בהחלט לא מרחם עליו. אבל לדעתי כל טיסן והמטרות שלו. לצלילות ובזים אני לא משתמש בטיסן עם מחזק דיהדראל מאלומיניום (שאני אפילו לא יודע מאיזה סוג) ואשר אני לפחות לא רוצה להשמיד אותו בטיסה הראשונה או השניה - צריך היה לפחות לגמור לצלם אותו ולנחות שלם.
    מה שאתה עושה איתו - יתכן שהוא יחזיק כמה זמן מעמד - זה לא אומר שזה הדבר שאליו הוא מיועד.
    אני ממש לא בעד לקחת טיסן איטי וחלש ולהרכיב עליו מנוע חזק כדי לראות איך הוא טס או מתפרק באויר.
    אצלי לפחות, כל טיסן והביצועים שאליהם הוא מיועד, והטיסנים שלי מחזיקים מעמד לא רע והרבה שנים.
    כשרציתי, לפני שנים, טיסן מהיר - בניתי Team racer עם מנוע Eta 15, כשאת כל הטיסנים מסוגו בארץ אפשר היה לספור על אצבעות יד אחת (גם היום זה כך ) היום, מהירות לא עושה לי את זה. דווקא לתפוס טרמיקות ביום חלש יותר מענין.
    יום טוב לך.
    נערך לאחרונה על ידי umbo; 09-01-2011 בשעה 19:55:32.
    לב השרון
    הודה 541 פעמים ב 361 הודעות
    5 הודעה/ות
    Thanks for the nice review
    liked the detailed photos
    I have a question regarding the EPP it's made from,
    Is it durable? will it last more then a few flights?
    נען
    3 הודעה/ות
    ציטוט נכתב במקור על ידי Hagay צפיה בהודעה
    זה עשוי מ ELPOR.. סוג אחר של חומר מוקצף - זה שילוב של EPS ו EPP. די עמיד אבל לא כמו EPP
    If I'm wrong may I become a cheerleader with a mustache
    WRONG - its EPO
Name:	cheerleader with a mustache.JPG‏
    נערך לאחרונה על ידי Boogle; 09-01-2011 בשעה 22:59:12.
    זכרון יעקב
    לפחות בפרסום שלהם כתוב EPO. אני מבין קטן בניואנסים של החומרים המוקצפים, אבל הגימור של הטיסן הזה טוב. הוא חלק מאוד ונראה כאילו יש עליו שכבה דמוית לכה.
    שרון
    אלישמע: מנחת שאישרתי ברת"א.
    הודה 150 פעמים ב 98 הודעות
    איזה יופי של סקירה, ממש תענוג.
    מזכיר בצורה שלו את "ציפור הזמן" ( Bird of time ).
    איציק
    תקלה שהתגלתה אתמול אחרי הטסה בצוק - הגה הכוון מחובר בשני צירים בתצורת פין המודבקים בנעיצה לתוך הקלקר. אחרי כ40 דקות טיסה כשנחתתי שמתי לב לחופש קל בהגה כוון ומבחינה מהירה (משיכה קלה) מסתבר שהציר העליון השתחרר מאחיזתו בגוף.
    בתחילה חשבתי שזה מהנחיתה, אך הציר התחתון מחובר היטב כך שזה לא סביר שהעליון יתלש מחבטת נחיתה (מזל גדול - אפילו רואים את תחילת התקלה בתמונה שצילם גיא)
    עברו על כל הצירים שלכם כל הזמן.
    אני מתכוון כפעילות מונעת לחזק את האזור , כציר נוסף, עם סרט טסה.
    נערך לאחרונה על ידי Boogle; 26-02-2011 בשעה 10:59:27.
    Jun 2010
    הודה 11 פעמים ב 9 הודעות
    ברירת מחדל Re: Hobbyking Minemoa 2M Sailplane Review
    יופי של סקירה מופתע לטובה מהמוצר עברתי מספר פעמים על דף המוצר
    ופסתי אותו בגלל החומר ממנו הוא עשוי .
    כנראה זו היתה תגובה אוטוטית ונמהרת מדי הסיני מפתיע לטובה .
    "don't forget to write the manual"
    פתגם סיני עתיק....
Similar Articles
  1. Review of the ARF Cessna400 from HobbyKing.com by FMSModels.com
    על ידי Up&Away בפורום סקירות טיסנים
    הודעה אחרונה: 11-05-2011, 12:40:35
  2. HobbyKing Aero L-39 Albatros Jet Plug-n-Fly Review
    על ידי guyst בפורום סקירות טיסנים
    תגובות: 24
    הודעה אחרונה: 23-10-2010, 18:05:03
  3. HobbyKing Pitts EPP review
    על ידי sharonx בפורום סקירות טיסנים
    תגובות: 12
    הודעה אחרונה: 18-10-2010, 21:50:05
  4. HobbyKing YAK 54 Brushless EPO Plug-n-Fly review
    על ידי liorz055 בפורום סקירות טיסנים
    הודעה אחרונה: 28-08-2010, 15:01:05
  5. [שאלה] מישהו יודע אולי מה ההבדל בין sailplane לglider?
    הודעה אחרונה: 13-01-2010, 07:01:41
