מציג תוצאות 1 עד 14 מתוך 14
נושא: קריאת שירות לcc ice 120 hv
    רמת השרון
    הודה 15 פעמים ב 12 הודעות
    ברירת מחדל קריאת שירות לcc ice 120 hv
    לידיעת כל מי שיש לו cc ice 120 hv, התפרסמה קריאת שירות באחד הפורומים:
    ICE HV 120 NOTICE
    July 25, 2011
    Hello all,
    While Castle takes all controller failures seriously, many have felt that our response to the incidences of failures in our Phoenix Ice 120HV was taking too long. We didn't make any official statements as we couldn't identify any particular pattern or cause for the failures. Our Repair Dept. keeps track of our returns - for any reason -- and the returns of the 120HV were actually very low; less than 3%. We generally see more than that rate of return just from crash damage unrelated to the controllers. Given that we've produced more than 10,000 of these controllers, a low percentage of failure still results in a lot of upset customers.
    We've recently determined that some, again some, setups stress particular components in a way that causes the controllers to fail instantly. The failure mode allows a complete short circuit to occur. Our controllers are designed to carry high currents with as little resistance as possible. This is advantageous when the controllers are operating properly, but this leads to extreme currents and heat when the controllers fail. As the ICE controllers are encapsulated in metal heatsinks, this heat is further concentrated such that physical injuries or property damage may occur.
    Our engineers have tested a hardware modification that greatly reduces the risk of this particular failure. We do not recommend using Phoenix Ice 12HV controllers until they have been modified to this new standard.
    Please return any 120HV controllers that you may have for one that has this modification. There will be no charge for this exchange.
    Please advise anyone using a 120HV controller of this notice.
    REPLACEMENT PROCEDURE
    Click this link and follow the directions to process your return.
    North American customers please ship to Castle in Kansas via a traceable delivery service:
    CASTLE CREATIONS, INC
    120HV SERVICE / Service Department
    540 N.ROGERS RD.
    OLATHE, KS 66062
    European customers may return their controllers via a traceable delivery service to our new European repair center:
    CASTLE CREATIONS EUROPE BVBA
    120HV SERVICE
    GEELSEWEG 80
    2250 OLEN
    BELGIUM
    Please be sure to include a copy of the order confirmation in your package.
    NOTE: For purposes of fast turnaround, you will be sent another Phoenix Ice HV 120 controller. Remove all connectors, etc. from your ESC before shipping as they will not be returned with your replacement controller.
    Our Technical Support and Repair staff do not have any additional information, calling them will only lead to additional frustration for all involved. We will advise you via email of the expected shipment date for your return.
    We apologize for any problems this matter may have caused, and we hope that our candor and willingness to repair these controllers will help maintain your trust in our products and service.
    Thanks,
    Team Castle
    Mikado Logo 6003D 10S, Mikado Logo 600 se "swissrumpf", Tdr, Tdr 600
    הרחק בצפון
    הודה 231 פעמים ב 189 הודעות
    ברירת מחדל תגובה: קריאת שירות לcc ice 120 hv
    זו לא קריאת שרות אלא מה שנקרא RECALL - סוף סוף הם מצאו את התקלה ומבקשים מכל מי שרוצה לשלוח אליהם את הבקר שלו (גם אם אינו תקול) לתיקון.
    זאת חברה רצינית שלוקחת את האחריות שלה עד הקצה ולכן גם לדעתי שווה להיות לקוחות שלהם.
    דרך אגב, גם בארץ יש סנוניות של אנשים רציניים שעומדים מאחורי המוצרים שלהם ומאחורי ההבטחות שלהם עד הפרט האחרון. לאחת החנויות האלה יש פה פורום חדש..
    Henseleit TDR
    DX7
    למכירה:
    מסוק 700 TDR
    Jul 2011
    אפשר לקבל קישור לפורום הנ"ל??
    בסופו של דבר אני רק בנאדם
    Apr 2011
    הודה 112 פעמים ב 65 הודעות
    ברירת מחדל
    תחפש תמצא זה ממש קליל אני מניח שהןא התכוון להובי מאסטרס. ואני מסכים עם כל מילה. +
    Mar 2011
    הודה 58 פעמים ב 36 הודעות
    אני מסכים עם אלעד(wonderd) בכל מילה ומילה
    והשאלה שלי היא האם לשלוח להם את הבקר למרות שהוא תקין כרגע ואין איתו בעיה ???
    או לחכות שיקרה משהו לבקר אם בכלל יקרה! ואז לשלוח להם? וכמובן אם בכלל הם יקבלו אותו במידה והבקר ישרף או שיקרה לו משהו אחר ?
    Logo 700 extreme
    Futaba-12FG
    Futaba-6XH
    רמת השרון
    אלעד, ״recall״ = ״קריאת שירות״ בעברית (אפשר להגיד גם קריאה חוזרת).
    לירון- המטרה היא שלא לחכות שיקרה משהו אלא לתת להם לבדוק את הבקר לפני שישרף על מנת למנוע סיכון מיותר ולפתור את הבעיה שקיימת.
    נערך לאחרונה על ידי nirgo; 26-07-2011 בשעה 03:52:47.
    הרחק בצפון
    אם הטסת עם הבקר כמה פעמים והכל בסדר - סביר שאין אצלך את הבעיה, אני עברתי כבר כמה ICE120 ולא היתה לי בעיה, דרך אגב לא כולם תקולים, יש אנשים שנשרף להם כי הם לא עושים סטאפ נכון..
    בכל מקרה, אם אתה חושש ויש לך זמן או בקר חלופי - תשלח אותו, שלי עובד תקין, אני לא מוריד אותו מהמסוק.
    nirgo - קריאת החזרה ולא קריאת שרות, זה באנגלית - service call.
    Henseleit TDR
    DX7
    למכירה:
    מסוק 700 TDR
    Nov 2009
    הודה 57 פעמים ב 39 הודעות
    רמת השרון
    תכנס בבקשה ללינקים הבאים:
    http://www.musach.co.il/forum/showthread.php?p=2940
    http://www.toyota.co.il/recall/
    הרחק בצפון
    אני מכיר את רפי לין ומעריך אותו מאוד מפורום אחר, אבל עדיין אנגלית זו אנגלית וצריך לתרגם נכון ולא בעברית עילגת.
    בכל מקרה, דרך אגב, קסטל אומרים ששיעור ההחזרות של הבקרים האלה עומד על כ 3% בלבד!
    Henseleit TDR
    DX7
    למכירה:
    מסוק 700 TDR
    Mar 2011
    ברירת מחדל Re: תגובה: קריאת שירות לcc ice 120 hv
    איןןןן לייי זמןןןן אם אני מוריד אותו אני משבית את החשמלי שלי ולא בא לי.
    נתפלל לטוב
    Logo 700 extreme
    Futaba-12FG
    Futaba-6XH
    הודה 331 פעמים ב 222 הודעות
    זה אומר רק דבר אחד.
    רק 3% מהמטיסים עם הבקר הזה הבינו נכון את המסר וחבל שכך.
    רמת השרון
    זה אומר רק דבר אחד.
    +1
    Mar 2011
    ברירת מחדל Re: קריאת שירות לcc ice 120 hv
    טוב אז ככה לכל המעוניינים שלחתי מייל לCASTEL לגבי הבקר ונאמר לי ככה:
    "Hello Liron,
    If you are happy with it, please keep using it. Like our announcement says, this issue only affects a few applications.
    If you have an "off" season, Then send it back .
    Thanks
    Lee
    אז זה אומר בעצם שאם יש בעיה למרות שהבקר כרגע בסדר אז אין בעיה לשלוח אותו חזרה לחברה
    נקווה לטוב
    Logo 700 extreme
    Futaba-12FG
    Futaba-6XH
  1. איזה שירות
    על ידי משה שמואלי בפורום פורום רדיו ואלקטרוניקה
    הודעה אחרונה: 29-09-2010, 22:16:21
  2. [מדריך] איך בונים מסילת רכבת?
    על ידי tomer_inbar בפורום לא להבים ולא כנפיים
    הודעה אחרונה: 19-09-2010, 14:06:47
  3. [מדליק] "רכבת לילה לקהיר..." + תמונות - ענק!!
    תגובות: 85
    הודעה אחרונה: 10-12-2009, 22:49:33
  4. נווט? קריאת מפות? GPS? ..כמה טיפש אפשר להיות...
    על ידי guyrud בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 06-10-2009, 16:46:02
