נושא: מוצר חדש HobbyKing Go Discover FPV Plane EPO 1600mm PNF
    Nov 2012
    Usa
    magreiftVE
    הודה 6 פעמים ב 5 הודעות
    ברירת מחדל מוצר חדש HobbyKing Go Discover FPV Plane EPO 1600mm PNF
    http://hobbyking.com/hobbyking/store...00mm_PNF_.html
    http://hobbyking.com/hobbyking/store/catalog/38072.jpg
    http://hobbyking.com/hobbyking/store...38072s3(1).jpg
    http://hobbyking.com/hobbyking/store...38072-1(1).jpg
    http://hobbyking.com/hobbyking/store...38072s7(1).jpg
    Take your FPV experience on the path less traveled, with the new Go Discover FPV plane from HobbyKing.
    The Go Discover was designed from the start to be a great FPV platform with a massive center bay, straight forward layout and superb, predictable, yet sporty, flight characteristics. The 1600mm swept reflex wing provides great lift and slow, predictable behaviors, yet under power has the agility and feel of a combat wing. The power system with the 800kv motor and 40A esc matched to a 10inch folding prop, provides ample power for big loops and epic FPV climb outs, but can just cruise along happily just sipping power at quarter stick for FPV endurance. Designed to use a 4cell 3000-4000 Li-Poly battery the Go Discover can stay afloat for ample FPV fun.
    What makes the Go Discover stand out is the integrated pan and tilt system in the nose, giving an un-obstructed bird’s eye view of the world below. The pan and tilt system uses 2 gear driven engagements for a smooth solid camera platform. The pan and tilt system was designed to perfectly house a GoPro 1, 2, 3 or 3+ as well as any other board or cube FPV camera with an easy swappable back mounting plate, all housed behind a clear acrylic dome. The front dome provides a great view, while protecting your FPV gear. The Go Discover has replaceable domes, as well as a few light reflective optional ones as well.
    Purposely designed and perfectly sized the HobbyKing Go Discover can help you discover the world from a different point of view.
    Specs:
    Wingspan: 1600mm
    Length: 737mm
    Weight: 1800g
    ESC: 40A
    Servo: 9g x4 (2 for the flight elevons and 2 for the pan and tilt)
    Radio: 3ch for flight ( 5ch or more recommended for Pan and tilt use)
    Motor: 800KV 35mm
    Battery: Li-Poly 14.8v (4s) 3000-4000mah 25c
    Included:
    800kv motor
    40A ESC with BEC
    4 9g servos
    Pan and tilt mechanism
    10inch folding prop
    Hardware and glue
    Instructions
    Required:
    4ch radio (6ch recommended)
    Battery 14.8v (4s) Li-Poly 3000-4000mah and charger
    FPV equipment (optional)
    PRODUCT ID: 9310000119
    Jan 2011
    חיפה עיר עם תחתית
    הודה 246 פעמים ב 191 הודעות
    ברירת מחדל תגובה: מוצר חדש HobbyKing Go Discover FPV Plane EPO 1600mm PNF
    בקיצור... חיקוי RVJET
    No good deed goes unpunished
  1. הזמנת טיסן מ HobbyKing - מוצר הגיע שבור!
    על ידי ceyal74 בפורום פורום משלוחים, מכס וחנויות מחו"ל
    הודעה אחרונה: 19-05-2011, 17:17:45
  2. HobbyKing Coota R/C Sea Plane Plug-n-Fly
    על ידי ilan_l בפורום סקירות טיסנים
    תגובות: 12
    הודעה אחרונה: 05-01-2011, 17:26:10
  3. סקירת מוצר HobbyKing YAK 54 Brushless EPO Plug-n-Fly
    על ידי liorz055 בפורום סקירות טיסנים
    הודעה אחרונה: 30-08-2010, 13:58:09
  4. סקירת מוצר HobbyKing YAK 54 Brushless EPO Plug-n-Fly
    על ידי liorz055 בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 32
    הודעה אחרונה: 30-08-2010, 10:54:13
