הנה ציטוט המתאר את הבעיה - ואת פיתרונה.
*Sync loss occurs when an ESCs CPU cannot control the 3 connections quickly enough to continue synchronization with the motor. Often described as a screeching noise, sync loss will cause a sudden loss in power until the ESC can regain timing with the motors poles and fall back into Sync. This phenomenon is not an esc fault, rather an incompatibility with the ESC, Motor, number of cells and prop speed and usually only ever occurs on very large motors.
The TURNIGY 100A Sentilon now runs a 12Mhz CPU, the fastest in the market! Ensuring perfect sync with the fastest of motors and snappiest of throttle movements!
