מציג תוצאות 1 עד 15 מתוך 15
נושא: כרטיס תכנות של yep או yge
    Sep 2012
    הודה 84 פעמים ב 70 הודעות
    ברירת מחדל כרטיס תכנות של yep או yge
    אני מנסה לתכנת בקר של yep .
    YEP80
    הפעם האנגלית הסינית שברה אותי ולא הצלחתי לפענח את מה שכתוב במדריך שלהם.
    אני רוצה לבטל soft start,
    עובד על זה כבר שעתיים ללא הצלחה.
    למישהו יש כרטיס תכנות?
    אלו ההוראות למי שבא לו לפענח
    Basic-Setup:
    The basic setup goes relatively quick. You should read this Manual thoroughly before running it.
    Otherwise one may not be able to keep up with the pace!
    1. Verify that the ESC is off, and then switch on the transmitter with the throttle stick at full
    power(make sure the full power position with fine trimming).
    2. Hold the Model, Connect the ESC with motor and battery pack => a monotonous continuous
    beep should be heard. ♪♪♪♪♪♪…: Multiprogramming is activated!
    3. Move the stick to the desired neutral position; if the Brake is not needed, the throttle stick is on
    the “full back” position. If the Brake is needed, lower the stick to one fifth away from the lowest
    point (not fully back), you will hear two beeps (these high pitch and low pitch)to make sure
    the position of throttle stick. Then the throttle process was saved.
    4. Now, do not move the throttle stick and hear the sounds , it comes the setup of the Soft
    start to wait for the acknowledgement of the sounds ,
    The Soft Start was saved.
    The Soft Start with Brake, if activated, will also use this value!
    5. For extremely fast response (NOT FOR HELI USE!!!!), the same operation as (procedure 1-3)
    the Basic-setup, after the 3 procedures, please make sure to push the stick back to full power and
    wait for acknowledgement . Then come back to full back position swiftly and the ESC is
    ready to run and wait for the acknowledgement
    => Quick Start is saved.
    => Quick Start with brake, if activated, will also use this value!
    Sent from my SM-N900
    נערך לאחרונה על ידי rotemshan; 01-08-2014 בשעה 16:13:14.
    FUTABA 9CAP
  1. [עזרה!] כרטיס תכנות
    על ידי rossg1 בפורום פורום מסוקים חשמליים
    הודעה אחרונה: 18-04-2014, 16:42:41
  2. כרטיס תכנות לבקר
    על ידי yaron78 בפורום פורום מסוקים חשמליים
    הודעה אחרונה: 19-02-2011, 20:31:39
  3. [עזרה!] כרטיס תכנות בקר CC PHONIX 45
    על ידי Oron Werner בפורום פורום מסוקים חשמליים
    הודעה אחרונה: 14-08-2010, 17:01:14
  4. מה תפקיד כרטיס תכנות לבקר ?
    על ידי seadoo בפורום פורום מסוקים חשמליים
    תגובות: 13
    הודעה אחרונה: 06-02-2010, 04:34:41
  5. [שאלה] תכנות בקר TURNIGY ללא כרטיס תכנות
    על ידי marik_911 בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 12
    הודעה אחרונה: 15-02-2009, 07:46:40
