ϊτψξθ ιωιψεϊ ςμ δξεαιερ, μΰ γψκ δξηωα.
In-Camera Formatting
The Camera contains a built-in formatter which may be used to format the SD card. In- Camera formatting is best done using mSetup.exe (see below) but can also be done as follows:
Connect the camera to an External USB power supply or to a PC as a Removable disk (see above).
Press and hold down the Mode button. DO NOT RELEASE the button until after the next steps are completed.
Disconnect the camera from the power supply or the computer.
The yellow LED will blink for a few seconds followed by three blinks of the red
LED, after which the camera will turn off. You must wait until you see the red
LED blink three times.
Release the Mode button.
►In firmware versions up to v2.03 cards with a capacity greater than 32GB will be formatted with exFAT. All other cards will be formatted as FAT32. See the note about using exFAT in older operating systems in the Description.
ξχεψ:
http://www.mytempfiles.info/mobius/MobiusManual.pdf
