עמוד 1 מתוך 3 123 אחרוןאחרון
מציג תוצאות 1 עד 25 מתוך 51
נושא: בניית רחפן FPV REPTILE 650mm Carbon Fiber
    Mar 2015
    Post בניית רחפן FPV REPTILE 650mm Carbon Fiber
    חדש בתחום, החלטתי לבנות רחפן, אשתף כאן בתהליך הבנייה
    פירוט החלקים:
    Transmitter + Receiver: FrSky 2.4G ACCST Taranis X9D Plus Transmitter With X8R Receiver - 236$
    Frame: FPV REPTILE-550 550mm Carbon Fiber Alien Four-axis Aircraft Quadcopter Frame - 126.60$
    Arms: X55 Extended Aluminium Arm - 4 * 29.18$
    Legs: X5L - Short Leg for X50 and X55 arms - 4 * 7.57$
    Flight Controller: DJI NAZA-M V2 - 267.77$
    DJI BTU Module Built-in Bluetooth for NAZA-M
    ESC: Afro ESC 30Amp Multi-rotor Motor Speed Controller (SimonK Firmware) - 4 * 14$
    Motors: Sunnysky X4108S 690KV High Efficiency Brushless Motor for Multicopter 4S - 4 * 39$
    4X 1448 14*4.8 Carbon Fiber Propeller Prop CW/CCW For T-Motor
    Propeller Quick Detach: Propeller Quick Detach CW&CCW - 2 pairs * 17.4$
    New 14.8V 5000mAh 50C Max 55C 4S 4Cells 14.8 Volt RC LiPo Li-Poly Battery - 44$ *3
    RC LiPO battery 4S 8000mAh 14.8V - 67$
Name:	NEW-UAV-High-power-rc-model-lipo-battery-14-8v-10000mAh-25C-4S-Akku-For-Quadcopter.jpg
    14.8V 6000mAh 50C Max 60C 4S 4Cells Li-Polymer Battery
    Voltage Regulator: Multi-rotor Power Distribution board - 13.29$
    front LED Light: LED Corn Light - 1.63$
    Cell Checker Low Voltage: Cell Checker with Low Voltage Alarm - 3.80$
    Flight Controller Mounting Pad: Gyro / Flight Controller Mounting Pad - 1.99$
    Thread Locker: TL-242 Thread Locker & Sealant Medium Strength - 0.99$
    Gold Connectors: PolyMax 3.5mm Gold Connectors 10 PAIRS - 1.83$
    wire mesh guard: 10 meter Snakeskin mesh guard wire mesh - 6.55$
Name:	20meters-lot-10mm-Knitted-net-snakeskin-network-font-b-wire-b-font-font-b-mesh-b.jpg
    GPS Folding Antenna mount: GPS Folding Antenna mount frame metal carbon - 7.90$
Name:	Free-shipping-GPS-Folding-Antenna-mount-frame-metal-carbon-for-DJI-YS-X4-X6-multicopter-quadcopt.jpg
    Charger: 2015 IMAX B6AC Digital LCD RC Lipo NiMh Professional Balance Charger /Discharge - 34.99$
    Parallel Charging Board Charge Plate: Parallel Charging Board Charge Plate For IMAX B6 B6AC B8 Charger - 7.90$
Name:	Parallel-Charging-Board-Balance-charge-Plate-Up-to-6-packs-2-6s-Lipo-LiFe-Lion-Battery.jpg
    gps tracker: TK102B 4 band gps tracker - 17.20$
Name:	Mini-GPS-Tracker-Car-Vehicle-GPS-GSM-GPRS-Tracker-TK102-Mini-Global-Real-Time-4-bands.jpg
    gps tracker: GSM 850/900/1800/1900MHZ 4 frequency globally applicable
    רשימת תדרים
    ** לא עובד על הרשתות בארץ לצערי **
    Solutions for finding lost RC aircraft
    fmkit RF beacon
    דיון ב rcgroups
    Screw Driver Tools: 4 in 1 Hex Screw Driver Tools Set Kit 1.5 / 2 / 2.5 / 3mm for RC Helicopter - 5.74$
    Propeller Balancer: Multi-axis Aerial Carbon Fiber Magnetic Propeller Balancer Blade Prop Good - 6.5$
    Heat Shrink Tubing: New 150pcs 2:1 Polyolefin Heat Shrink Tubing Tube Sleeving Wrap Wire Kit Cable - 5.63$
    Hot Air Shrink Tubing Heat Gun: Gas Torch Hot Air Shrink Tubing Heat Gun K37 - 8.99$
    M3x8 Round Hexagonal Screw: XAircraft X650 Value V4 M3004 M3x8 Round
    Hexagonal Screw x8
    - 2.56$
    20pcs Black Thread M3 Alloy Steel Hex Socket Head Cap Screw Bolts 8mm
    Battery Balance Charging Extension * 5: 4S Lipo Battery Balance Charging Extension Cable 20cm - 14$
    New Frsky FLVSS Lipo Voltage upgrade Sensor & Display for 2-Way Telemetry System - 27$
    הסבר 1 הסבר 2
    Male XT60 connectors - 1.94$
    4Pc Round Anti-vibration Rubber Damper Ball f/ Brushless Camera Gimbal FPV Black
    DAL 2A Single Channel LED Light Controller Switch for RC Multicopter Night Flight
    2CH Output Remote Controller Electronic Switch Module TDF Compatible for RC Airplanes
    FPV SETUP
    RCTimer IMP 3-Axis Gopro Brushless Gimbal w/Motors&AlexMos Controller - 150$
    החלפתי את הגימבל שהגיע עם ה frame לגימבל הזה
    Foxtech M800 8" monitor - 83$
    YKS 11.1V 2200mah 25C Max 40C 3S Lipo Battery
    Fatshark 600TVL CMOS V1 Fixed Mount FPV Camera NTSC PAL - 41.89$
    FPV 5.8G 600mW 32CH A/V Transmitting (TX) Module TS832 RP-SMA - 34$
    FPV 5.8G 32CH A/V Receiver (RX) W/ LED Channel Display RC832 RP-SMA - 39$
    Fatshark ImmersionRC SpiroNet 5.8GHz RHCP Antenna TX RX Set
    TS832 Telemetry Transmitter Special Gopro AV Cable Power Cable DJI Phantom Vision Compatible
    Hobbyking 3-Channel FPV Video Switcher - 4.92$
    DJI iOSD mini Module Naza-M Compatible - 58$
Name:	DJI-IOSD-Mini-BTU-Module-Built-in-Bluetooth-for-Wookong-M-NAZA-V2-Supporting-iPhone-iPad.jpg
    הדגמה
    223mm FPV Video Transmitter Lead Cable with 5 Input for GoPro Hero 1/2/3/3+/4 - 1.5$
    FPV Ground Station Aluminum Retractable Tripod
    מארז קשיח לרחפן + שלט + מסך FPV
    Pelican StormCase IM2875
ID:	122122   Click image for larger version.
ID:	122124   Click image for larger version.
ID:	122127   Click image for larger version.
ID:	122132   Click image for larger version.
ID:	122138   Click image for larger version.
ID:	122176   Click image for larger version.
ID:	122541   Click image for larger version.
ID:	123656   Click image for larger version.
ID:	124286   Click image for larger version.
ID:	124287   Click image for larger version.
ID:	124288   Click image for larger version.
ID:	128670   Click image for larger version.
    נערך לאחרונה על ידי liortt; 07-11-2015 בשעה 15:39:25.
    Sep 2012
    הודה 218 פעמים ב 170 הודעות
    ברירת מחדל תגובה: בניית רחפן FPV REPTILE 650mm Carbon Fiber
    תשמע, מוריד את הכובע! לא אחד ה... אל הסטאפ הכי טוב ומושקע שראיתי ממתחיל בהתחשב בזה ששום חלק כמעט לא סטנדרטי, שאפו!!!
    אם היית מתייעץ שנייה לפני הייתי ממליץ על שלט מ-readymaderc, טיפה יותר זול מגיע יותר מהר.
    הימור גדול עם הפריים, שמתי עליו עיניים מזמן, למה רשמת 126$ ובלינק רשום 190$? בעיה גדולה של כל הפריימים האלו (גם המקורי) אלו הזרועות, ופתרת אותה יופי עם זרועות האלומיניום. יש רגליים דומות ב-Goodluckbuy בחצי מחיר, לא יודע לגבי האיכות ולא לגבי הרגליים לרגליים
    http://www.goodluckbuy.com/dji-f450-...ck-2-pack.html
    הבטריה, קצת לא ידועה (אולי חקרת), קצת יותר מדי C אולי וקצת כבדה אבל זה לא קריטי בסטאפ הזה, אלה אם אתה תתפרעה ועם המנועים הללו היא לא חזקה מספיק, בשיא יש לך סביב 8 קילו דחף על כלי של סביב 2 קילו - מפלצת!!!
    הלוח חלוקה עם שני ה-bec לא מומלץ, גם אני אציתי אותו מאד, יש דיווחים שה-12V נשרף... נראה לי קטן מדי בשביל שיהיה טוב.
    בריחוף רגיל ב-2קילו נראה סביב ה-21דקות...
    **רשמתי כבר אז אני לא אמחוק, רלוונטי למי שירצה גם - עכשיו שמתי לב שהזמנת בזמן ההנחות ב-Banggood, אחת הקניות היפות שראיתי!
    כדאי לך אולי להוסיף Alexmos 32 Mini במקום זה שמגיע, לא חיפשתי מאיפה, אפשר להוסיף אח"כ
    ** מצאתי את הפריים, נראה יותר טוב מהלינק ששמת!
    http://www.goodluckbuy.com/fpv-repti...bal-combo.html
    הרבה מחשבה הושקעה כאן.
    Mar 2015
    אחלה תודה.. התכנון הוא באמת לסטאפ לא סטנדרטי, לכן גם הלכתי על הזרועות אלומיניום, טיפה יותר יקר אבל נראה לי איכותי.
    החלטתי לפני חודש להיכנס לתחום, ולאחר חפירות של שבועיים ברשת הגעתי לסטאפ הזה והתחלתי להזמין חלקים.
    תיקנתי את הקישור לפריים.
    לגבי בקר לגימבל. מה דעתך על זה..? 2-Axis Brushless Camera Gimbal Stabilization Control Board
    איזה לוח חלוקה אחר מומלץ יותר?
    לגבי הסוללה 4S, הכי זולה שמצאתי עם משלוח לארץ. אנסה אותה וארשום לגבי הביצועים שלה בהמשך.
    לגבי הנתון של הדחף, רציתי להגיע לייחס של 1 / 4. אבל בטח לא אנצל את זה..
    FPV אשלב בהמשך
    נערך לאחרונה על ידי liortt; 03-03-2015 בשעה 09:52:34.
    Sep 2012
    הוספת דברים
    לא משתמשים ב-Thread Lock חזק, רק מדיום ורצוי לא מהוביקינג, בשאר העולם הסטנדרד הוא שהמדיום הוא כחול והחזק אדום.
    לא צריך ספוגים בשביל Naza, לנזה יש שיכוך בפנים.
    המוט GPS שלקחת מאד כבד, סביב 50גרם מיותרים, אפשר למצוא בסביב 15 גרם,
    לי תמיד נראה שהסיכוך כבלים למרות שהוא יפה זה ביזבוז גרמים מיותרים.
    חיסכון משקל זה לא קטע של כח לסחוב אלה חיסכון בצריכת בטריה, כל 50גרם יכול להיות איזו דקת טיסה, למרות שבסטאפ שלך כנראה פחות.
    מנועים מומלץ להלחים בשביל השקט הנפשי ולא מחברי bullet. נתקלתי גם בכאלו שעשרות בניות מאחוריהם שהתנתק להם המחבר בטיסה.
    זה לא מובן מתאור המוצר שאין בקר לגימבל.... אם אין, בטוח כדאי לך להוסיף את ה-32bit.
    אל תיקח את זה שרשמת מהוביקינג.
    הנה ה-32bit בזול מאד יחסית:
    http://www.aliexpress.com/item/NEWES...268711477.html
    הנה אחד קטן 8bit שאומרים שאפשר לשים עליו גרסה רשמית, למרות שמישהו מזהיר שם מלשים יותר מ-2S:
    http://www.goodluckbuy.com/hmbgc-mic...ware-v2-2.html
    זה 8Bit הכי זול ובטוח עם גרסה מקורית:
    http://www.goodluckbuy.com/bgc-3-1-m...st-sensor.html
    Mar 2015
    מעולה. תודה על התגובות.
    הזמנתי בקר לגימבל 8Bit נתחיל איתו נראה איך מתפקד.
    ממתין בינתיים שהחלקים יתחילו לטפטף
    Mar 2015
    רכשתי gps tracker שיוצמד לרחפן במידה ויחליט להטיס את עצמו לייעד לא ידוע
Name:	2014-New-Arrival-TK102B-4-Band-GPS-Tracker-With-Car-charger-And-Battery-State-Tracker-For.jpg
    Mar 2015
    איזה סים מומלץ ל gps tracker?
    Mar 2015
    הכל הגיע. לעבודה ..
ID:	122902 Click image for larger version.
    נערך לאחרונה על ידי liortt; 20-03-2015 בשעה 09:10:04.
    Sep 2012
    Apr 2014
    הודה 10 פעמים ב 10 הודעות
    עבודה נעימה ובהצלחה
    Mar 2015
    הגימבל הוגדר עובד יפה מאוד.
    לא מצליח להגדיר את האפשרות לשלוט מה terranis על ה pitch ו- roll של הגימבל.
    הגדרתי בשלט את ערוץ 5 ו-6 LS ו-RS על מנת שאוכל לשלוט על ה pitch ו- roll.
    חיברתי את ערוצים 5 ו-6 מהמקלט לקונטרולר של הגימבל. אך זה לא מגיב .
    יש הצעות?
    בשלט אני על Mode d16
    נערך לאחרונה על ידי liortt; 21-03-2015 בשעה 16:26:41.
    Sep 2012
    תתחיל בלי הגימבל, יש לך עוד המון לפניו....
    הגדרת את הפרמטרים לשלט בתכנה של הגימבל? (תיזהר לא לשדרג אם זה לא גימבל שתומך גרסה מקורית)
    Mar 2015
    כן הוגדר. אוליי בגלל שמחובר למקלט רק ג'מפר אחד (Mode d16)
    שאר הערוצים לא יעבדו כי הכל רץ ל naza בערוץ אחד..?
    Mar 2015
    סוף סוף מוכן.. נראה אם יעלה לאוויר
    Apr 2014
    Mar 2015
    הרחפן באויר
    נערך לאחרונה על ידי liortt; 30-03-2015 בשעה 22:11:33.
    Mar 2015
    הסוללות על הפנים בקושי מחזיקה 5 דק'
    Battery: Winmax 5200mAh 14.8V 80C MAX 4s Lipo Battery Pack - 2 * 33.90$
    יש המלצות?
    4S 5000ma
    Jan 2011
    חיפה עיר עם תחתית
    הודה 246 פעמים ב 191 הודעות
    הווידאו פרטי ...
    סוללה ממולצת לרחפן בגודל כזה:
    http://www.hobbyking.com/hobbyking/s...arehouse_.html
    (השתמשתי על רחפן TBS Discovery Pro בעקבות המלצה של חגי וגיא - מתאימה יופי ונותנת כ 9 דקות אם אני זוכר נכון)
    No good deed goes unpunished
  19. המשתמשים הבאים אמרו תודה לAmitB על הודעתו:
    guyst (30-03-2015)
  20. #19
    Sep 2012
    ציטוט נכתב במקור על ידי liortt צפיה בהודעה
    יש המלצות?
    4S 5000ma
    פרטים? מה המשקל המלא הכולל ?
    מתי ירדת עם הבטריה, מה הראה המד בלי עומס או עם עומס?
    מה עשית בטיסה?
    כמה הטעין המטען את הבטריה אחרי?
  21. #20
    Mar 2015
    המשקל המלא כולל gopro
    2.1 קילו.
    היום הצלחתי להטיס 5 ד' לאחר טעינה מלאה.
    חייב לרכוש סוללות 7000 לפחות, איכותיות.
    נערך לאחרונה על ידי liortt; 31-03-2015 בשעה 15:16:30.
  22. #21
    Mar 2015
    להגדיר ב naza מתח מינימום 3.4 וולט זה נכון?
    נערך לאחרונה על ידי liortt; 31-03-2015 בשעה 15:25:54.
  23. #22
    Mar 2015
    איזה כיף לך. אני מתחיל לבנות את שלי. הסטאפ שלך מאוד איכותי ומאוד יקר.
    אני מקבל את הרכיבים עכשיו.
    איך הנחיתה שלו?
    איך היו הרוחות באותו יום?
  24. #23
    Mar 2015
    אתה בונה כזה? דומה?
    הנחיתה שלו מצויינת רכה.
    הייתה רוח באותו יום של הסרטון.. ריחף במקום בסדר גמור.
    הסטאפ מושלם רק כרגע צריך לשפר את נושא הסוללות.
    ייתכן ואצמיד לו 2 של 5000ma
  25. #24
    Mar 2015
    הסטאפ שלך באמת נראה טוב. שלי יותר פשוט.
    מבוסס מנועי 1000kv ו-micro hklilot.
    אני עובד בינתיים על קינפוג בקר הטיסה.
    חושב שאפרסם פוסט עזרה...
  26. #25
    Mar 2015
    הורדתי את ה gopro החלפתי לפרופלורים 12x4.0" מעמיס פחות על הסוללה.
    באויר 10 דק' בקלות. יש שיפור
  1. carbon vs carbon fiber. מה ההבדל ביניהם?
    על ידי israel121 בפורום רחפנים מרובי להבים
    הודעה אחרונה: 17-07-2014, 13:20:47
  2. השרון למכירה רחפן Reptile 550 v2 - חדש בקופסה
    על ידי AvivT בפורום ציוד FPV ורחפנים
    הודעה אחרונה: 29-05-2013, 08:58:29
  3. חלקי שדרוג מ carbon fiber
    על ידי שמואל בפורום פורום מסוקים חשמליים
    הודעה אחרונה: 06-09-2012, 19:30:16
  4. Carbon Fiber - צריך עזרה..
    על ידי Nlackrif בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 11
    הודעה אחרונה: 23-01-2010, 12:01:22
  5. [מוצר חדש] להבי SWE Carbon Fiber 630DC
    על ידי lior_bar_ami בפורום פורום מסוקי דלק
    הודעה אחרונה: 16-11-2009, 20:33:14
