היי חברים, מה אתם אומרים על זה כסרוו זנב? [מסוק 450]
http://www.readyheli.com/MKS-DS92-Hi...o_p_38633.html
MKS-DS92 High Speed Digital Servo
Specs:
Dead Band: 0.001ms (Default)
Control System: +Pulse Width Control
Working Frequency: 1500μs / 333hz data: 850μs~2150μs
(RX) Required Pulse: 3.0~5.0 Volt Peak to Peak Square Wave
Operating Voltage: 4.8~6.0 V DC Volts
Operating Temperature Range: -10 to + 60 Degree C
Operating Speed: (4.8V) 0.075 sec/60° degrees at no load
Operating Speed: (6V) 0.060 sec/60° dagrees at no load
Stall Torque: (4.8V) 2.30 kg-cm (31.94oz/in)
Stall Torque: (6V) 2.85 kg-cm (39.58oz/in)
360° Modifiable: YES
Motor Type: Coreless Motor
Potentiometer Drive: Direct Drive
Driver Type: FET
Bearing Type: Dual Ball Bearings
Gear Type: Chrome-Titanium alloy gear
Programmable: NO
Connector Wire Length: 20.0 cm (7.86 in)
Dimensions: 23X12X27.25 mm (0.9X0.47X1.07 in)
Weight: 17.45 g (0.61 oz)
