מציג תוצאות 1 עד 25 מתוך 34
נושא: 9xr pro הגיע
    May 2013
    הודה 31 פעמים ב 26 הודעות
    ברירת מחדל 9xr pro הגיע
    שלט במחיר 100$ שמחסל שלטים יקרים ממנו בהרבה... עולה במספר תחומים על היריב העיקר " הטראניס ".
    מפתה... נראה לי בשביל 100$ לא אעמוד יותר מדי בפתוי.
    http://www.hobbyking.com/hobbyking/s...t_module_.html
    להלן חלק מהפונקציות שלו (יאללה איזו התרגשות)
    9XR Pro Added Features:
    •*ARM version of er9x radio firmware with EESKYPE simulater GUI support
    • 24 channel support
    • 48 free mixes
    • Expo, Triple rates, Curves settings
    • Voice alerts
    • Telemetry display
    • Atmel SAM3S ARM Cortex M3 , 32 bit Micro-controller , 512K flash , 64Kb of SRAM
    • 4Mb EEprom for 30+ model storage*
    • Micro SD card (Included)**
    • Mini USB port, for access to SD card files and radio programing*
    • 1/2 Watt Audio Amplifier with digital control.*
    • RS232 Serial Port for External telemetry connection through Futaba trainer jack. (for DHT ,DXT)*
    • Logic level Serial Port for external Blue Tooth modules (HC-06,RN42)
    • Dimable LED Back light
    • Haptic Buzzer (pager vibrator) for trim center alert and alarm notifications
    • Real "Tact" switches on menu keys, give positive feedback indication
    • Built in bootloader. (Firmware can be updated in less than 15 seconds!)
    • Full built-in Telemetry support for the latest RF modules. New DSM modules coming soon.
    • Speaker and headphone outputs
    • Ball Bearing gimbals
    • Digital Trims
    • Assignable Switches
    • Freely Assignable Channel Mixes
    • Graphical Dual Rate, Sub trims, travel adjust and Exponential
    • Supports Heli/Aero/Glider and custom Model Types
    • Programming templates based on model type
    • Supports M1, M2, M3, M4 stick modes
    • 128 x 64 backlit Liquid Crystal Display
    • Built in JR & Futaba Trainer Ports
    • JR Form Factor RF Modules (ORX Dsm2, ORX Open LRS 433Mhz etc)
    • Programmable warnings
    • 1.5Amp, 5V main switching regulator, with wide input voltage (6.5 - 30V)* (uses 3S lipo connection same as 9XR)
    • Rotary encoder with push switch port (rotary encoder not included - user upgrade)
    • Support for 6-way switch and more 3 way switches. (User upgrade)
    • And so much more!
    Sent from my W200 using Tapatalk
    נערך לאחרונה על ידי josh_1972; 04-06-2014 בשעה 12:47:42.
    Oct 2013
    הודה 14 פעמים ב 8 הודעות
    ברירת מחדל תגובה: 9xr pro הגיע
    איך מוציאים לו אישור ממשרד התקשורת ?
    Sent from my GT-I9100T using Tapatalk
    Using Tapatalk
    May 2013
    ציטוט נכתב במקור על ידי koop צפיה בהודעה
    מכיוון שהוא ללא מודול שידור אז מספיק לשלוח המפרט למשרד התקשורת בכדי להוכיח שהוא ללא המודול אינו משדר.
    Aug 2011
    הודה 442 פעמים ב 327 הודעות
    מהנסיון של ה 9XR הקודם, כדאי לחכות קצת ולא לקבל את השלטים של מהסדרה הראשונה.
    וחוץ מזה דיברו הרבה על מודולים חדשים שהם מפתחים שכוללים טלמטריה ושימוש באנטנה הפנימית, מה קרה שעוד פעם הם מוציאים את השלט למכירה בלי מודול?
    הטראניס נמכר בהוביקינג ב 172 דולר עם מודול מובנה פנימי של 16 ערוצים , עם סוללה , עם מזוודה , עם כרטיס זיכרון עם רצועת שלט...
    ככה שההפרש לא כזה גדול...
    וחוץ מזה שה 9XR הרגיל נמכר ב 50 דולר , וייצור של לוח חדש בכמויות כאלה לא עולה יותר מ 10-20 דולר .
    אבל ... למי שלא צריך סוללה, מזוודה , מודול ורצועת צוואר זה באמת שלט מעולה (לפי הבטא טסטרים) וזול יחסית.
    Oct 2013
    הודה 104 פעמים ב 96 הודעות
    המחיר ירד בדיוק עוד חודשיים שה batch הראשון יגמר. אין מצב שהם ימשיכו למכור את זה במחיר הנוכחי.
  6. המשתמשים הבאים אמרו תודה לyuvalko על הודעתו:
    josh_1972 (04-06-2014)
    May 2013
    ציטוט נכתב במקור על ידי yuvalko צפיה בהודעה
    הלוואי. אבל מכיוון שהוסיפו לו תוספות פונקציונליות מעבר לטראניס ולאור ההתעניינות העצומה בפורומים. אני חושב לצערי שאתה טועה... להיפך ... תהיה דרישה גבוההה מאוד והם יתקשו השנה לעמוד בביקוש.
    Oct 2013
    ציטוט נכתב במקור על ידי josh_1972 צפיה בהודעה
    ההפרש בינו לטראניס לא מצדיק את המחיר. מודול של פרסקי עולה 30$, סוללה מתאימה באזור ה 10$ אז ב 30$ הפרש שנשאר אתה מקבל שלט מוכח בעל שם, מזוודה וגם רצועה.
  9. המשתמשים הבאים אמרו תודה לyuvalko על הודעתו:
    moshet (05-06-2014)
  10. #8
    May 2013
    הודה 16 פעמים ב 16 הודעות
    זה לא 30$ הפרש ,כי המזוודה עולה עוד 15$ והרצועה עוד 2$ בקיצור אין הפרש...
  11. #9
    Aug 2011
    ציטוט נכתב במקור על ידי ypython צפיה בהודעה
    והמודול XJT של ה 16 ערוצים לא עולה 30 דולר , ולכן אם מישהו קונה את כל הערכה המחיר זהה...
    היתרון שאפשר לקנות רק מה שצריך ולא חייבים לקנות הכל.. וכנראה שאם המלאי עדיין לא נגמר וזה 7 שעות אחרי ההכרזה
    אז המחיר בטוח ירד בעוד חודשיים.
    ה 9XR נגמר תוך חצי שעה מהכרזה.
  12. #10
    May 2013
    אבל מקבלים כמה פיצ'רים נחמדים לאללה שאין בטארניס.
  13. #11
    Aug 2011
    בכל מקרה למי שמזמין, תוסיפו לחבילה איזה פריט קטן (אפילו חבילת ברגים בכמה סנטים)
    כדי לקבל משלוח זול יותר
    International (Registered) Air Mail 1.5kg $24.59
    יש להם איזה באג באתר שרק השלט עולה יקר יותר למשלוח..
  14. #12
    Sep 2009
    הודה 204 פעמים ב 169 הודעות
    אני עדיין מנסה להבין במה הוא עולה על הטאראניס.
    השלטים מאוד דומים - התצוגה מכוערת באותה מידה, הפלסטיק מרגיש שביר ופריך, התנועה של הסטיקים ללא היזן חוזר מוחשי, האודיו (למי שזה חשוב) נשמע כמו סיני שלומד אנגלית בהתכתבות עם קלינגוני.
    אז כן -מקלטים זולים. זה בערך כל היתרון של הזבל הסיני הזה.
    ---MAV
    Marc A Volovic
    marc@bard.org.il
  15. המשתמשים 2 הודו ל mixerfix על הודעתו:
    eitan-ro (04-06-2014),merkur (05-06-2014)
  16. #13
    Feb 2011
    רחובותי
    הודה 62 פעמים ב 46 הודעות
    ---MAV
    Marc A Volovic
    marc@bard.org.il
    תיקון קטן מארק אם הקול של הסיני לא נשמע לך ..ניתן בעידכון פשוט להחליף את הדיבור יש קבצי קול מוכנים
    Sent from my XT910 using Tapatalk 2
    Mini 250 FPV
    F450+FPV
    BIXLER FPV
    9XR+DLII
    TRICOPTER 2.5-למכירה
    Naza-m lite upgrade to v2 project
    FUNCAB
    AXN
  17. #14
    May 2013
    מארק. מי שרוצה להוציא 2000-2500 שח על שלט עם 'שם' יכול. בעיני ראוי לבחון האם זה שווה.
    לגבי השוואה לטראניס.. אז יש לו כמה יתרונות לצד מספר חסרונות. יתרון נחמד זה ויברציה, יכולת לחבר בלותות' וכו.
    אגב איך אצה יכול לדעת מה רמת האודיו? לאף אחד עדיין אין אותו. אתה סתם אנטי.
    תן שלט במחיר שלו או מתקרב למחיר שלו ברמת השלט הזה והטארניס עם פונקציונליות דומה ...ואשמח להשכיל.
    תשווה אותו לשלט שעולה 3000 שח (ולא בטוח שתהיה לו את כל הפונקציונליות שלו ושל הטארניס אגב) זה לא ממש חכמה גדולה
    נערך לאחרונה על ידי josh_1972; 04-06-2014 בשעה 15:39:31.
  18. #15
    Feb 2014
    הודה 23 פעמים ב 16 הודעות
    שמעו איזה שלט משוגע, מישהו רוצה לקנות 9XR יד שנייה??? סתם...
    אבל אין ספק שדרוג משמעותי...
  19. #16
    Sep 2009
    עודד - ללא קשר למלחמה (שאין לי ספק שהולכת לפרוץ) - איני מכיר את ה- 9XR PRO.
    אני כן מכיר את ה- TARANIS.
    מעבר לזה שהוא מכוער (גם חיצונית וגם הממשק) - שזו גחמה שלי - החסרון שלו זה המבנה הפלסטיקי שלו והסטיקים שעדיין לא הוכיחו את עצמם - מביחינת תוכנה השלט הזה עולה על כל שלט שיש היום בשוק. עולה על פוטאבה (כל הדגמים - כולל 18MZ). עולה על JR. עולה על SPEKTRUM.
    גם שיטת השידור שלו טובה.
    אולי סדרת השלטים היחידה שעולה על הטאראניס הם שלטי מולטיפלקס.
    מרק
  20. המשתמשים הבאים אמרו תודה לmixerfix על הודעתו:
    merkur (05-06-2014)
  21. #17
    מרק
    נתת מספיק סיבות לא לגעת בזה לעולם ובשום מחיר
  22. #18
    Apr 2011
    הודה 91 פעמים ב 71 הודעות
    ועל הדרך גם מוותרים על סליידרים וארגונומיה... מי יכול להפעיל את המפסקים האלה בלי לעזוב את הסטיקים ?
    ולגבי העיצוב ״הרובוטריקי״ לא אתייחס... לא שהטראניס מלכת יופי
  23. #19
    Sep 2009
    טוב -יש סקירה של 9xr pro בערוץ של Bruce.
    הסיכום שלו - עולה כמו הטאראניס, חרא פלסטיק, זבל סטיקים, צואה כפתורים - קנו טאראניס.
    אין סליידרים, מפסקים לא במקום וקשים לתפעול. פלסטיק נחות. כפתורים לא נלחצים. רק מפסק תלת מצבי אחד. לא שומעים את האודיו. הלחמות לא טובות. אין כבל טלמטריה - צריך לרכוש בנפרד. הנדסה מכנית נחותה - הכל זז ומשקשק.
    איכס.
    ---MAV
    Marc A Volovic
    marc@bard.org.il
  24. #20
    Sep 2009
    עודד - אני חולק עליך. במחיר של טאראניס אין שום רדיו הים. הכי קרוב (אאל״ט) הוא פוטאבה 7cg ורשימת היכולות שלו - ממממ איך לומר - לא דומה.
    לפני כשבוע תכנתתי את הרדיו לחבר - ממצב אפס יצא מהקופסה לטסט פלייט של טריינר - תוך בערך 10 דקות.
    מאוד אהבתי אותו. אם לא הייתי ״ מושקע״ בערימת מקלטים, הרדיו היה כבר אצלי על השולחן.
    ---MAV
    Marc A Volovic
    marc@bard.org.il
  25. #21
    May 2013
    מה הקישור לסקירה ?
  26. #22
    Sep 2009
  27. #23
    Apr 2011
    ולזה מתכוונים כשאומרים ״זבל סיני״...
    מי קרא לזה "Taranis Killer" ???
    ורק יכול לדמיין כמה טוב יעשה הרטט להלחמות שרואים בסקירה
    אהבתי איך שסיים את הסקירה ״תקנו את הטראניס״... Infinitely superior
  28. #24
    May 2013
    כנראה שאכן הפונקציונליות שיש לו מעבר לטארניס עדיין לא מצדיק להעדיף אותו לאור הביקורת הלא מחמיאה.
  29. #25
    Aug 2010
    הודה 52 פעמים ב 31 הודעות
    עדיין לא הצלחתי להבין איפה היתרון שלו על הטראניס
  1. [מוצר חדש] סוף סוף הגיע
    על ידי Roiko1009 בפורום רכבי שטח
    תגובות: 24
    הודעה אחרונה: 22-05-2014, 09:30:28
  2. [מדליק] מה הגיע הבוקר...?
    תגובות: 24
    הודעה אחרונה: 04-11-2012, 20:22:20
  3. סוף סוף הגיע ה- 4G6!!!!
    על ידי szangvil בפורום פורום מסוקים חשמליים
    תגובות: 32
    הודעה אחרונה: 28-03-2010, 07:52:12
  4. סוף סוף זה הגיע
    על ידי leetal בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 43
    הודעה אחרונה: 18-07-2009, 10:08:20
  5. HK 450 שלי הגיע
    על ידי ללו בפורום פורום מסוקים חשמליים
    תגובות: 16
    הודעה אחרונה: 10-04-2009, 19:19:11
