שלט במחיר 100$ שמחסל שלטים יקרים ממנו בהרבה... עולה במספר תחומים על היריב העיקר " הטראניס ".
מפתה... נראה לי בשביל 100$ לא אעמוד יותר מדי בפתוי.
http://www.hobbyking.com/hobbyking/s...t_module_.html
להלן חלק מהפונקציות שלו (יאללה איזו התרגשות)
9XR Pro Added Features:
•*ARM version of er9x radio firmware with EESKYPE simulater GUI support
• 24 channel support
• 48 free mixes
• Expo, Triple rates, Curves settings
• Voice alerts
• Telemetry display
• Atmel SAM3S ARM Cortex M3 , 32 bit Micro-controller , 512K flash , 64Kb of SRAM
• 4Mb EEprom for 30+ model storage*
• Micro SD card (Included)**
• Mini USB port, for access to SD card files and radio programing*
• 1/2 Watt Audio Amplifier with digital control.*
• RS232 Serial Port for External telemetry connection through Futaba trainer jack. (for DHT ,DXT)*
• Logic level Serial Port for external Blue Tooth modules (HC-06,RN42)
• Dimable LED Back light
• Haptic Buzzer (pager vibrator) for trim center alert and alarm notifications
• Real "Tact" switches on menu keys, give positive feedback indication
• Built in bootloader. (Firmware can be updated in less than 15 seconds!)
• Full built-in Telemetry support for the latest RF modules. New DSM modules coming soon.
• Speaker and headphone outputs
• Ball Bearing gimbals
• Digital Trims
• Assignable Switches
• Freely Assignable Channel Mixes
• Graphical Dual Rate, Sub trims, travel adjust and Exponential
• Supports Heli/Aero/Glider and custom Model Types
• Programming templates based on model type
• Supports M1, M2, M3, M4 stick modes
• 128 x 64 backlit Liquid Crystal Display
• Built in JR & Futaba Trainer Ports
• JR Form Factor RF Modules (ORX Dsm2, ORX Open LRS 433Mhz etc)
• Programmable warnings
• 1.5Amp, 5V main switching regulator, with wide input voltage (6.5 - 30V)* (uses 3S lipo connection same as 9XR)
• Rotary encoder with push switch port (rotary encoder not included - user upgrade)
• Support for 6-way switch and more 3 way switches. (User upgrade)
• And so much more!
Sent from my W200 using Tapatalk
