Nice !!!
זה מסוק 500, נכון?
נראה מרשים
במיוחד הגיר הראשי ומערכת הזנב.
אין לי מושג מה זה, חיפשתי בגוגל הסברים ולא מצאתי
חלק מההסברים אמרו שזה קיט שידרוג ולא מסוק בפני עצמו, אבל לא הצלחתי להבין בדיוק במה מדובר.
בכל אופן לא ראיתי מסוק כזה למכירה
מכנים אותו Gaui Hurricane 425 V2, אבל זה Gaui X4 וזה מסוק 500 חדש של Gaui, אחיו הקטן של ה-Gaui X5.
הפריים שלו מרשים וכך גם הגיר הראשי!
אני חם על המסוק הזה וחושב להזמין אחד כזה אם תהיה אפשרות לקנות אותו בתור קיט בלבד.
This is what google says
Hurricane 425 V2, this is really a high-end machine! Gaui's response to the popular 500 class. Hurricane 425 V2 is very easy and is designed with a box chassis in carbon fiber that is extremely rigid and durable. The tail is operated by torque tube (drive shaft) even with this generous drive. The whole mechanics of breathing quality and is fairly broad. This, together with a very stylish and sleek hood makes Hurricane 425 V2 to a beauty even to the eye. Pitch Up is first in the world to sell Hurricane 425 V2 and is honored by this. Much thanks to our personal relationships and long cooperation with the Gaui. We ourselves have tried hard this machine since August this year and can only congratulate Gaui to a very successful design!
Hurricane 425 is cheap, even when an accident occurs and spare parts needed. Everything is of course kullagrat, and blade holders are equipped with thrust bearing. Of course, part of autorotationsnav driven tail rotor for auto rotations.
The helicopter comes in ARF performance, 90% completed.
New leaves 1600W motor and is very potent, so an upgrade engine will probably not be needed. As you can imagine it is a very potent machine we are talking about. Course included a couple of nice 425mm carbon fiber blades! Hurricane 425 flies very stable, but is also extremely fast and reversible if you like. Suitable for both beginners, sport and 3D pilots. Hurricane 425 is simply a dream to fly. During the testing of that heli we flew in winds of between 8-12 m / s, although the size can handle the wind and weather very good! Our helicopters deliver with a Swedish setup manual, describing how everything linked together, as well as tips on settings, etc..
We can highly recommend the 425 V2, we stick our necks out and say this is probably the finest machine Gaui has done so far.
Hurricane 425 comes complete with motor and 60A SAE speed controller with integrated S-BEC.
And carbon fiber blades & carbon fiber paddles. 425 V2 launched in the rest of the world Q2 2010th
Hurricane using mini servos to save weight. Recommended acc package is 6S-2600-2800mA 35C.
Hurricane 425 Specifications:
• electric helicopter for 5-6 cell Lipo
• Length 900mm
• Rotor diameter 965mm
• tail rotor diameter 217mm
• Weight flight ready> 1375g (without acc)
Spektrum DX7 2.4
GAUI Hurricane 425
TREX 600 Nitro
ESKY King 3
Blade McpX
Mugi
F/A-18 Edf
Gaui X330 Quad
שרשור בנייה הוריקאן 425:
ואדים
Futaba 7C 2.4GHz
זה לא הוריקאן 425 משודרג, זה מסוק אחר לגמרי עם תיכנון שונה לחלוטין.
נראה טוב מאד ומכאן הביקורת
לפי איך שהמסוק נראה ובנוי אל תצפו לאותו תג מחיר כמו של אחיו הישן, לטעמי הוא הולך להיות יקר יותר וכאן תעלה שאלת הכדאיות.
ואדים
Futaba 7C 2.4GHz
