מאמר: Mystery™ 60A review
  1. תאריך הצטרפות
    Mar 2010
    זכרון יעקב
    הודה 7 פעמים ב 4 הודעות
    Jump to Comments
    Mystery™ 60A review
    1 Comments by FSK Published on 15-02-2012 17:57:36
    This is a review of Mystery™ 60A Out-BEC Brushless Motors Speed Controller ESC Yellow
    The ECS arived in a sealed package, without any conector solderd to it
    So you can solder yourself the right kind of connector you are useing
    I am useing the XT-60 for the battary conector, and 3.5 gold conector for the motor.
    the Mystery™ 60A spasafication is :
    • Safety Mode: The motor won't start no matter what the position of the control stick is when switch on the RC unit
    • Brake Setting: ON/OFF (factory setting is off)
    • Low Current Protection: Ignore / reduce power / shut off
    • Temperature Protection: Reduce power when the temperature reaches 120 degree C
    • PWM Frequency: 8KHZ / 16KHZ
    • Continuous Current: 60A
    • BEC Current (Max A): 3A
    • Input Voltage: Ni-Mh 6-18cells / Li-ion 2-7cells
    • This Mystery speed controller has three point battery type and low voltage selection
    • The motor speed controller provides software reversion of motor turning direction
    How to program your Mystery™60A is explaned in the PDF file atteched to this review.
    and also in the video I made.
ID:	62243Click image for larger version.
ID:	62244Click image for larger version.
ID:	62246Click image for larger version.
ID:	62247Click image for larger version.
ID:	62248Click image for larger version.
ID:	62249Click image for larger version.
    קבצים מצורפים
    איזיסטאר
    FunJet
    Phoenix 2000
  2. המשתמשים 3 הודו ל FSK על הודעתו:
    Hagay (15-02-2012),lesley (16-02-2012),OneLink (16-02-2012)
  3. Total Comments 1
    תגובות
  4. #2
    Mar 2010
    זכרון יעקב
    ברירת מחדל תגובה: Mystery™ 60A review
    How to program the Mystery 60A
    איזיסטאר
    FunJet
    Phoenix 2000
  5. המשתמשים הבאים אמרו תודה לFSK על הודעתו:
    lesley (16-02-2012)
