עמוד 1 מתוך 6 123 ... אחרוןאחרון
מציג תוצאות 1 עד 25 מתוך 178
נושא: שרשור בניה של F/A-18 1/7 של חברת YELLOW AIRCRAFT
    Dec 2009
    הודה 46 פעמים ב 44 הודעות
    Smile שרשור בניה של F/A-18 1/7 של חברת YELLOW AIRCRAFT
    מכובדיי.
    אני פותח כאן שרשור בניה של קיט של טיסן 18- F/A של חברת YELLOW AIRCRAFT
    בקנ''מ של 1/7 ....
    השרשור ילווה בהסברים בשפה האנגלית עמכם הסליחה.
Name:	Chippy ho 2.jpg‏
    Dec 2009
    ברירת מחדל תגובה להודעה: שרשור בניה של F/A-18 1/7 של חברת YELLOW AIRCRAFT
    Hello everybody I'm starting here a thread build of the Y/A F/A-18 Twin "BUG" .....This kit has been on and off my desk in the past 4,5 years and I've decided to bring it to completion ....
    enjoy...above is a picture of the full scale and here is a 1/32 scale plastic model that I've built for my purposes the model will be painted according to it..
    Dec 2009
ID:	25742   Click image for larger version.
ID:	25743   Click image for larger version.
    Dec 2009
    At this stage the "BUG" is more or less built i.e all formers in the fuse are installed , wings are glassed including fins and stabs. . Also all gear doors are done too.
    The wings control surfaces have been altered from the original plans to a state where they more or less have resemblance to the ones on the full size.
    Following are some pictures which describe the various parts done. A more spesific picture gallery will follow.Starting with the wings
Name:	All sorts of pics F-4E and other 072.jpg‏
ID:	25822   Click image for larger version.
Name:	All sorts of pics F-4E and other 071.jpg‏
ID:	25823   Click image for larger version.
Name:	All sorts of pics F-4E and other 067.jpg‏
    Dec 2009
    Seen above are the wings with control surfaces in their advanced preparation stage where the wings have been sheeted and ailerons together with the flaps have been removed from the core , trimmed and boxed also is seen the aileron servo housing been reveiled
    Dec 2009
    Next are pictures of the special offset hinges that were made for the scale actuation of the flaps and ailerons...
Name:	F-18 build pics.jpg‏
ID:	25829   Click image for larger version.
Name:	All sorts of pics F-4E and other 068.jpg‏
ID:	25830   Click image for larger version.
Name:	All sorts of pics F-4E and other 070.jpg‏
    Dec 2009
    The offset hinges are being produced by Dr.Charles Tsee
    and can be purchased separately they are not made specially for the F/A-18
    back then...(2006~7) today they are used in numerous kits. Observe the different sizes to match the mechanical geometry of movement.
    Dec 2009
    Some more pictures of various parts of the airframe ... gear doors and air cylinders
Name:	Fuga & F-18 build progress 010.jpg‏
ID:	25923   Click image for larger version.
Name:	Fuga & F-18 build progress 011.jpg‏
    Dec 2009
    Early stages of work on the inlets splitter plates...inlet liner has already been installed and two more pic's of geardoors..
Name:	Fuga & F-18 build progress 016.jpg‏
ID:	25925   Click image for larger version.
Name:	Fuga & F-18 build progress 017.jpg‏
ID:	25926   Click image for larger version.
Name:	Fuga & F-18 build progress 013.jpg‏
    Dec 2009
    Speed brake
Name:	Fuga & F-18 build progress 015.jpg‏
ID:	25928   Click image for larger version.
Name:	Fuga & F-18 build progress 014.jpg‏
    Dec 2009
    Assembled
Name:	family pic's Noas birthday and Hanucah party in kinder garden 126.jpg‏
ID:	25930   Click image for larger version.
Name:	family pic's Noas birthday and Hanucah party in kinder garden 125.jpg‏
    הודה 47 פעמים ב 31 הודעות
    MCMF , מה עם ה - f-14 היה טסטפלייט ולא סיפרת לנו,
    Dec 2009
    Smile תגובה להודעה: שרשור בניה של F/A-18 1/7 של חברת YELLOW AIRCRAFT
    Not yet......
    Dec 2009
    More work on the wings control surfaces...
    glassing and sanding..
Name:	Yellow Aircraft  F-18C twin build  project 002.jpg‏
ID:	26006   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 001.jpg‏
ID:	26007   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 003.jpg‏
ID:	26008   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 004.jpg‏
    Dec 2009
    creating the scale wing folding hump on the top surface of the wing
Name:	Yellow Aircraft  F-18C twin build  project 007.jpg‏
ID:	26010   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 006.jpg‏
ID:	26011   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 008.jpg‏
ID:	26012   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 005.jpg‏
    Dec 2009
    more gear doors
Name:	F-18 build pics 003.jpg‏
ID:	26014   Click image for larger version.
Name:	F-18 build pics 004.jpg‏
ID:	26015   Click image for larger version.
Name:	F-18 build pics 005.jpg‏
ID:	26016   Click image for larger version.
Name:	F-18 build pics 001.jpg‏
ID:	26017   Click image for larger version.
Name:	F-18 build pics 010.jpg‏
    למה לא בעברית?
    Dec 2009
    It's also for fellow R/C members who don't speak our language
    זה נחמד אבל מעניין כמה כאילו יש שניכנסים לאתר הזה ואינם דוברים כלל עברית.מבלי לזלזל באתר מי שלאדובר עברית רק אנגלית יכנס לאתרים עולמיים .
    Mar 2010
    מעולה טוב לראות אבודה נהדרת
    Dec 2009
    main port strut
Name:	F-18 build pics part II + gear and gear door stance 006.jpg‏
    Dec 2009
    Main starboard strut
Name:	F-18 build pics part II 010.jpg‏
    Dec 2009
    Preparation of aileron servo covers on the wing...
ID:	27028   Click image for larger version.
ID:	27029   Click image for larger version.
ID:	27030   Click image for larger version.
    Dec 2009
    Flaps and Ailerons after primer been applied
Name:	Yellow Aircraft  F-18C twin build  project 010.jpg‏
ID:	27269   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 011.jpg‏
ID:	27270   Click image for larger version.
Name:	Yellow Aircraft  F-18C twin build  project 012.jpg‏
    Dec 2009
    hardly seen are panel lines engraved in the surface....
  1. שרשור בניה של F-15 של חברת FLY EAGLE JET
    על ידי MCMF בפורום פורום JET-ים
    תגובות: 50
    הודעה אחרונה: 08-06-2010, 14:46:34
  2. שרשור בניה
    הודעה אחרונה: 09-05-2010, 21:07:44
  3. סוייפטאלי שרשור בניה
    על ידי mus בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 19-04-2010, 00:59:43
  4. [שרשור בניה] שרשור בניה - Jetlegend T-45
    על ידי ליאור זהבי בפורום פורום JET-ים
    הודעה אחרונה: 10-01-2010, 13:51:57
  5. [שרשור בניה] אני פותח שרשור בניה חדש שלי...
    על ידי zahi101 בפורום פורום דאונים וטיסנים חשמליים
    תגובות: 106
    הודעה אחרונה: 10-08-2009, 16:41:20
