מציג תוצאות 1 עד 13 מתוך 13
מאמר: חניך-מדריך אל חוטי
  1. תאריך הצטרפות
    Sep 2009
    הודה 204 פעמים ב 169 הודעות
    Jump to Comments
    חניך-מדריך אל חוטי
    12 Comments by mixerfix Published on 16-03-2014 09:59:29
    Simple and Easy Wireless Student-Trainer Setup for Futaba Radios
    I never trained another to fly an RC model. This because I never learned in an orderly manner myself and because I never trusted myself to explain well. Thus, I never bothered with getting a student-trainer setup.
    One day, however, a friend asked to have a “go” with one of my models - a very nice flying wing. So we did the “bear-hug-dance-around-the-radio” - me holding the radio and him controlling the model while, so to speak, embracing me. With our height differences - it was not comfortable nor entirely safe.
    Thus deterred from further exploits of this nature, I decided to get a student-trainer setup.
    My then-radio was a Futaba 9CH with a TM8 module. My spare radio was a Futaba 8UA, 72MHz. Aha! All I needed was a DIN to Futaba Micro trainer cable - easy enough. But a trainer CABLE! 2013! Come on! Also, the 8UA was a dead end. After all, it would be replaced or traded away and I would probably get a modern Futaba radio instead, making the 9CH my backup.
    I decided to experiment. The Futaba Micro connector (pinout here). So there is PPM out/in on the port. What if….
    In perusing various after-market 2.4GHz receivers, I remembered noticing that FrSky had something resembling PPM out. Searched and found - the TFR4-B had the functionality. Not that it helped yet - the 8UA was a 72MHz, but it was modular. And my TM-8 was already in use. Maybe other module/receiver combos from FrSky had that functionality. And - so they did - the D4R-II also supported CPPM.
    So - I wagered a bit of money and ordered one D4R-II, the DF 2.4GHz combo, and - lucky I noticed - 6pin Trainer Port Plug. Lucky, indeed.
    Once they arrived, some three weeks later, I tested the setup and… it worked. Right off!
    Here’s what needs doing:
    Bind the D4R-II Rx to the DF module
    Short the SIGNAL pins on channels 3 and 4 on the D4R-II
    Plug the trainer port plug connector into channel 1 on D4R-II
    Plug the other end into the trainer port on your Futaba Tx
    The D4R becomes the student Rx
    Enable trainer on the model you want to test/use/train on
    And...
    The student’s Tx transmits to the student Rx
    The student’s Rx signals the trainer’s Tx via PPM in
    The trainer’s Tx transmits to the primary Rx on the RC model
    Voill! It works!
    To make things clean and tidy, I stuck a bit of male velcro to the back of my 9CH, stripped the D4R-II, shrink-wrapped it and velcroed it to the Tx. The antennae I hid in two tubes that are stuck directly to the shrink-wrapped Rx.
    The spare Rx I was left with - the D8R from the combo - I swapped with a friend for… ummm… I am not sure what. May be a couple of beers.
    Best of all - this will work with ANY transmitter can bind a FASST (TF4R and TF4R-B, the student Tx must be a FASST system) or an ACCST (D4R-II) Rx. I have tested the very same setup on friends’ Futaba 12FG, 8FG, 14SG and as soon as a Taranis radio arrives here - on that as well. And my 8UA? I still have it. It works. It is a nice radio. No need to replace.
    The D4R-II
    DF Module Combo
    The 6-pin trainer cable
    TF4R-B
    PS - I am _not_ associated with Hobby King, Futaba or FrSky. I am a customer and user of all of their products. This works for me - but test everything yourself.
  2. Total Comments 12
    תגובות
    ברירת מחדל תגובה: חניך-מדריך אל חוטי
    רעיון.. אבל נראה לי שכבל יותר פשוט
    Sep 2009
    פשוט זה יחסי. קבל קושר אותך לחניך. אתה לא יכול להחליף מיקום או אריינטאציה באותה קלות. והכי מצחיק - אם אתה לא חייב לקנות מודול - זה יותר זול מכבל...
    מרק
    Apr 2011
    הודה 91 פעמים ב 71 הודעות
    יתרונות נוספים:
    - אין סיכוי לקצר בחוט,
    - לא חייבים שלטים מאותו יצרן/תואמים
    - אין סכנה להפיל את השלט אם החניך רץ (למשל כי יש לו צרעה בפנים... כן, ראיתי כזה)
    Sep 2009
    שכחתי....! אכן!
    אוקיי
    Sep 2012
    הודה 84 פעמים ב 70 הודעות
    משום מה לא מצליח לי.
    יש לי את המודול ואת הכבל המחבר בין המודול לשלט הטריינר.
    עשיתי זיווג בין המאסטר Futaba 9CAP למקלט D4R-2 - רואים שהנורה ירוקה.
    הפעלתי פונקציית טריינר בשלט המדריך.
    משום מה אין שום פקודה שעוברת מהחניך למדריך (גם כשאני לוחץ על כפתור F).
    מה יכול להיות הסיבה?
    FUTABA 9CAP
  9. #8
    Apr 2011
    שמת את ה-Jumper ב-D4R ?
    רגע... ה-7 אמור להיות המדריך?
    כי את המקלט אתה מחבר לרדיו מדריך... אבל ה-7 שלך הוא 72מה״צ וללא מודול... אז הוא לא ישדר ל-D4R...
  10. #9
    Sep 2012
    אתה מתכוון אם קיצרתי את ערוץ 3 ל 4? כן.
    ה7 אמור להיות החניך,
    ה 9 אמור להיות המדריך.
    לפי מה שהבנתי בגלל שה 7 הוא 72 ללא מודול, אני מחבר לו מודול חיצוני, והוא אמור לשדר דרכו ל 9( המאסטר ).
    זו טעות?
    ניסיתי לחבר עכשיו את המקלט לשלט 7 החניך וההתנהגות זהה.
    הנורה של המקלט ירוקה אבל אין שום פקודה
    Sent from my SM-N900
    נערך לאחרונה על ידי rotemshan; 15-09-2014 בשעה 22:59:22.
    FUTABA 9CAP
    Apr 2011
    אין טעות... אבל ה-D4R הוא לא מודול (משדר) אלא מקלט (ואמור להתחבר ל-9 שלך)...
    אתה צריך משדר 2.4 בתוך ה-7...
    ממליץ על:
    http://www.hobbyking.com/hobbyking/s...er_module.html
    הנה הסבר איך להתקין אותו:
    http://flitetest.com/articles/diy-2-4ghz-radio-upgrade/
  12. #11
    Sep 2012
    קראתי שוב והבנתי שפספסתי את העובדה שהשלט שלו היה 72 אבל עם מודול שידור.
    אבצע הזמנה וארכיב שוב.
    תודה על העזרה
    FUTABA 9CAP
  13. #12
    Apr 2011
    אם תצטרך עזרה, בשמחה אתה מוזמן לבוא אלי (למודיעין)...
    פבלו
  14. #13
    Sep 2012
    תודה רבה
    FUTABA 9CAP
Similar Articles
  1. כבל חניך מדריך
    על ידי razgal בפורום פורום רדיו ואלקטרוניקה
    הודעה אחרונה: 05-08-2012, 22:06:25
  2. [עזרה!] כבל חניך מדריך
    על ידי sami בפורום פורום רדיו ואלקטרוניקה
    הודעה אחרונה: 24-02-2012, 11:27:26
  3. כבל חניך-מדריך
    תגובות: 19
    הודעה אחרונה: 23-04-2010, 08:29:19
  4. כבל חניך \ מדריך
    על ידי b1yossi בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 17-04-2009, 19:36:12
  5. [שאלה] מדריך חניך
    על ידי גבי א בפורום פורום טיסני דלק
    הודעה אחרונה: 12-04-2009, 14:20:24
