חדש בתחום, החלטתי לבנות רחפן, אשתף כאן בתהליך הבנייה
פירוט החלקים:
Transmitter + Receiver: FrSky 2.4G ACCST Taranis X9D Plus Transmitter With X8R Receiver - 236$
Frame: FPV REPTILE-550 550mm Carbon Fiber Alien Four-axis Aircraft Quadcopter Frame - 126.60$
Arms: X55 Extended Aluminium Arm - 4 * 29.18$
Legs: X5L - Short Leg for X50 and X55 arms - 4 * 7.57$
Flight Controller: DJI NAZA-M V2 - 267.77$
DJI BTU Module Built-in Bluetooth for NAZA-M
ESC: Afro ESC 30Amp Multi-rotor Motor Speed Controller (SimonK Firmware) - 4 * 14$
Motors: Sunnysky X4108S 690KV High Efficiency Brushless Motor for Multicopter 4S - 4 * 39$
4X 1448 14*4.8 Carbon Fiber Propeller Prop CW/CCW For T-Motor
Propeller Quick Detach: Propeller Quick Detach CW&CCW - 2 pairs * 17.4$
New 14.8V 5000mAh 50C Max 55C 4S 4Cells 14.8 Volt RC LiPo Li-Poly Battery - 44$ *3
RC LiPO battery 4S 8000mAh 14.8V - 67$
14.8V 6000mAh 50C Max 60C 4S 4Cells Li-Polymer Battery
Voltage Regulator: Multi-rotor Power Distribution board - 13.29$
front LED Light: LED Corn Light - 1.63$
Cell Checker Low Voltage: Cell Checker with Low Voltage Alarm - 3.80$
Flight Controller Mounting Pad: Gyro / Flight Controller Mounting Pad - 1.99$
Thread Locker: TL-242 Thread Locker & Sealant Medium Strength - 0.99$
Gold Connectors: PolyMax 3.5mm Gold Connectors 10 PAIRS - 1.83$
wire mesh guard: 10 meter Snakeskin mesh guard wire mesh - 6.55$
GPS Folding Antenna mount: GPS Folding Antenna mount frame metal carbon - 7.90$
Charger: 2015 IMAX B6AC Digital LCD RC Lipo NiMh Professional Balance Charger /Discharge - 34.99$
Parallel Charging Board Charge Plate: Parallel Charging Board Charge Plate For IMAX B6 B6AC B8 Charger - 7.90$
gps tracker: TK102B 4 band gps tracker - 17.20$
gps tracker: GSM 850/900/1800/1900MHZ 4 frequency globally applicable
רשימת תדרים
** לא עובד על הרשתות בארץ לצערי **
Solutions for finding lost RC aircraft
fmkit RF beacon
דיון ב rcgroups
Screw Driver Tools: 4 in 1 Hex Screw Driver Tools Set Kit 1.5 / 2 / 2.5 / 3mm for RC Helicopter - 5.74$
Propeller Balancer: Multi-axis Aerial Carbon Fiber Magnetic Propeller Balancer Blade Prop Good - 6.5$
Heat Shrink Tubing: New 150pcs 2:1 Polyolefin Heat Shrink Tubing Tube Sleeving Wrap Wire Kit Cable - 5.63$
Hot Air Shrink Tubing Heat Gun: Gas Torch Hot Air Shrink Tubing Heat Gun K37 - 8.99$
M3x8 Round Hexagonal Screw: XAircraft X650 Value V4 M3004 M3x8 Round
Hexagonal Screw x8 - 2.56$
20pcs Black Thread M3 Alloy Steel Hex Socket Head Cap Screw Bolts 8mm
Battery Balance Charging Extension * 5: 4S Lipo Battery Balance Charging Extension Cable 20cm - 14$
New Frsky FLVSS Lipo Voltage upgrade Sensor & Display for 2-Way Telemetry System - 27$
הסבר 1 הסבר 2
Male XT60 connectors - 1.94$
4Pc Round Anti-vibration Rubber Damper Ball f/ Brushless Camera Gimbal FPV Black
DAL 2A Single Channel LED Light Controller Switch for RC Multicopter Night Flight
2CH Output Remote Controller Electronic Switch Module TDF Compatible for RC Airplanes
FPV SETUP
RCTimer IMP 3-Axis Gopro Brushless Gimbal w/Motors&AlexMos Controller - 150$
החלפתי את הגימבל שהגיע עם ה frame לגימבל הזה
Foxtech M800 8" monitor - 83$
YKS 11.1V 2200mah 25C Max 40C 3S Lipo Battery
Fatshark 600TVL CMOS V1 Fixed Mount FPV Camera NTSC PAL - 41.89$
FPV 5.8G 600mW 32CH A/V Transmitting (TX) Module TS832 RP-SMA - 34$
FPV 5.8G 32CH A/V Receiver (RX) W/ LED Channel Display RC832 RP-SMA - 39$
Fatshark ImmersionRC SpiroNet 5.8GHz RHCP Antenna TX RX Set
TS832 Telemetry Transmitter Special Gopro AV Cable Power Cable DJI Phantom Vision Compatible
Hobbyking 3-Channel FPV Video Switcher - 4.92$
DJI iOSD mini Module Naza-M Compatible - 58$
הדגמה
223mm FPV Video Transmitter Lead Cable with 5 Input for GoPro Hero 1/2/3/3+/4 - 1.5$
FPV Ground Station Aluminum Retractable Tripod
מארז קשיח לרחפן + שלט + מסך FPV
Pelican StormCase IM2875
