מציג תוצאות 1 עד 9 מתוך 9
נושא: עוד אחד...
    Herzliya, Israel, Israel
    הודה 61 פעמים ב 51 הודעות
    ברירת מחדל עוד אחד...
    עוד תוכנית מהאתר ...
    מצורפים מאמר ותוכנית..
    כנף 67 ס"מ
    גוף 52 ס"מ
    היה מיועד במקור למנוע 0.049 ובמקום מותקן מנוע 10 של טאנדר טייגר..
ID:	132636   Click image for larger version.
ID:	132637   Click image for larger version.
ID:	132638   Click image for larger version.
ID:	132639   Click image for larger version.
ID:	132641   Click image for larger version.
ID:	132642   Click image for larger version.
ID:	132643   Click image for larger version.
ID:	132644   Click image for larger version.
ID:	132646   Click image for larger version.
ID:	132647   Click image for larger version.
ID:	132648   Click image for larger version.
ID:	132649   Click image for larger version.
ID:	132651   Click image for larger version.
ID:	132652   Click image for larger version.
ID:	132653   Click image for larger version.
ID:	132654   Click image for larger version.
ID:	132656   Click image for larger version.
ID:	132657   Click image for larger version.
ID:	132658   Click image for larger version.
ID:	132659   Click image for larger version.
ID:	132661   Click image for larger version.
ID:	132662   Click image for larger version.
ID:	132663   Click image for larger version.
ID:	132664   Click image for larger version.
ID:	132666   Click image for larger version.
ID:	132667   Click image for larger version.
ID:	132668   Click image for larger version.
ID:	132669   Click image for larger version.
ID:	132671   Click image for larger version.
ID:	132672   Click image for larger version.
ID:	132673   Click image for larger version.
ID:	132674   Click image for larger version.
ID:	132676   Click image for larger version.
ID:	132677   Click image for larger version.
ID:	132678   Click image for larger version.
ID:	132679   Click image for larger version.
ID:	132681   Click image for larger version.
ID:	132682   Click image for larger version.
ID:	132683   Click image for larger version.
ID:	132684   Click image for larger version.
ID:	132686   Click image for larger version.
ID:	132687   Click image for larger version.
ID:	132688   Click image for larger version.
ID:	132689   Click image for larger version.
    קבצים מצורפים קבצים מצורפים
  2. המשתמשים הבאים אמרו תודה לAsaf197seven על הודעתו:
    רן ענבר (19-10-2015)
    שומרת
    הודה 291 פעמים ב 241 הודעות
    ברירת מחדל תגובה: עוד אחד...
    יפה מאד. אתה בדרך הנכונה. המשך בדרכך זו ותגיע רחוק.
    יישר כוחך.
    למה אתה מתכוון ?
    הי אסף,
    מה הסיבה מאחורי EZ בהגה כיוון ולא מזלג?
    מה מצב מרכז הכובד? נראה שתצטרך הרבה משקל בזנב בגלל המנוע הגדול. אא"כ בנית את הזנב מאד כבד.
    איזה מיכל שמת, 2oz? אם כן הוא טוב ל 0.049 אבל לדעתי ייתן דקות בודדות בלבד למנוע 0.10.
    ממה שאני מכיר, טיסני 1/2A משתדלים לבנות קל כולל המנוע ע"פ התכנון.
    אין הביישן למד, ואין הקפדן מלמד
    זה היה מהיר! תודה על השיתוף!
    בעניין ההיגוי ..הסיבה היא שימוש ברוד של מתכת בהגה כיווון וניילרוד בהגה גובה .
    הטיסן מאוזן למרות המנוע ...מיכל הדלק יתן בערך 8 דק טיסה.
    הסוללה למקלט נמצאת מתחת לסרוואים...גם לא יצא כבד
    נועד להיות קיצוני בתגובות בזמן טיסה..
  8. המשתמשים הבאים אמרו תודה לAsaf197seven על הודעתו:
    akajo (20-10-2015)
  9. #7
    שומרת
    ציטוט נכתב במקור על ידי asaf3031 צפיה בהודעה
    למה אתה מתכוון ?
    אני מתכוון בדיוק למה שכתבתי בעברית תיקנית ורהוטה.
    "יפה מאד. אתה בדרך הנכונה. המשך בדרכך זו ותגיע רחוק.
    יישר כוחך".
    לא ברור לי מה לא ברור לך.
  10. המשתמשים הבאים אמרו תודה לflatspin על הודעתו:
    Asaf197seven (20-10-2015)
  11. #8
    מוכן...
    משקל 600 גרם..
ID:	132696   Click image for larger version.
ID:	132697   Click image for larger version.
  12. #9
    את כני הנסע הראשיים הכנתי ממסגרת של רשת מנגל..
    עכשיו החלפתי במוט פלדה שמתאים למשימה..
