אהה נכון, כמו של הפסיכופט מBlack-Sheep...
http://www.ritewingrc.com/buy-cores/wing-cores
שאלתי את הבחור שמוכר את הזיפרים :
Hi.
How much for 1 Zypher ?
How much for 2 or 3 units ?
How much is shipping to israel for 1,2 or 3 kits ?
Is it trackable ? No EMS please
Thanks
וזה מה שהוא ענה לי :
Hi Sharon, if you do 3 they will drop to 145.00 ea,two are 150.00 one is 165.00
I can ship priority mail for 50.00 ea,I can not ship two in one box to your country due to shiping size restrictions.
I you do 3 I will hep you some on the shipping.
Sharron Here is the generic info on the zephyr.
Give me an idea of the items you need and we can work out a final list.
Ritewing Zephyr kit is 165.00 $,the zeph was designed specific for FPV AP and UAV in mind.
It has a super wide section over the CG for alot of gear.
The Kit comes with 6 fiberglass spars instead of CF ,this is to keep the radio issues at bay that happens with Carbon Fiber .
It comes with a flat cnc aluminum motor plate,it has custom trimmed trailing edges with custom angled balsa elevons for great handling.
It has the winglets and corplast for lids and bays.
I designed it to be able to haul some gear nicely while retaining great handling, in a utility type platform this is hard to find.
Some people take smaller sport wings and try to modify them to fly like the Zeph ,good luck doing it .
The Zeph is a big wing in a small package with over 4.5 sq ft of wing area,it makes for a good stable platform for setting her up the way you need.
The wing is 54'' ws it was 60 till I swept it back some more.
I did this to make it handle the way I wanted,plus cg was easier to atain with the gear people like.
Ea wing half has 31'' of LE.
The zeph usualy builds out to 30 to 38 oz with motor servos and esc , and will take up to 35 to 40 more oz of gear .
Most guys fly them between 55 to 70 oz flying weight.
I sell some nice 83 oz or 90 oz mg or nylon ball bearing ritewing brand digi servos , ,25.00 and 35,00$ .
I also sell the hacker motor and 55 amp esc combo for this wing for 180.00. Plus for 35.00 $ I offer a laminating film to cover the wing with for super strength and durability.
Let me know if you have any questions, you can see the zeph vids on my website.
Here are some great vids on builds and stuff.
http://www.youtube.com/user/TheRitewing1?feature=mhum
Chris klick
RitewingrcLLc
Ritewingrc.com
11429 E, Queensborough AVE
Mesa Az 85212
602 739 4524
480 854 0665
Or my skype name is ritewing if skype is prefered
יקר משהו...
אומרים שזה השקעה, פשוט אי אפשר להרוס כנף כזו אחרי שמניילנים אותה.
אני אנסה את זה "take smaller sport wings and try to modify them to fly like the Zeph" על הfalcon, ברגע שהבקר 40a של הסיני יחזור למלאי.
נערך לאחרונה על ידי KNO3; 19-12-2010 בשעה 23:02:01.
הנה עוד קצת מידע על שרשור בנייה שלי + פרוט על מנוע, זמנים, וסוללות :
http://www.efly.co.il/forums/showthr...ght=maxi+swift
http://www.efly.co.il/forums/showpos...&postcount=125
http://www.efly.co.il/forums/showpos...&postcount=141
קח בחשבון שtם תשים מנוע כבד מאחורה תצטרך המון משקל מקדימה בכדי לאזן (מעבר לציוד וידאו ו2 סוללות 3300 הכוונה)...
אתה יכול להשתמש גם במנוע 4240 ש טורניג'י - מנוע מעולה ל-3 ו-4 תאים.
אלכס.
נערך לאחרונה על ידי alexk; 20-12-2010 בשעה 07:55:46.
החלפת זכוכית בלבד
מעבדת תיקון גלקסי
מעבדת תיקון אייפון
כל מה שרצית לדעת על FPV
ליבות EPP אפשר לרכוש כאן :
http://www.mwcores.com/servlet/Categ...C+FLYING+WINGS
אומנם בלי אביזרים אבל עלות המשלוח מאוד מאוד נמוכה.
ומה יותר טוב בכנפיים אלו לעומת המקסי?
האם כנף ברוחב 84" תהיה מתאימה יותר או פחות לFPV?
לQueen Bee 100 inch של Windrider יש מבנה שמאפשר פירוק.
מצד שני היא עולה 180$.
מצד שלישי היא כוללת הכל חוץ מאלקטרוניקה.
אני מכיר מישהו שמזמין מהם באופן קבוע
אין להם מנגנון משלוחים מתוחכם במיוחד ועד כה בעלי האתר ספגו את הפרשי המחיר.
הכנפיים האלה חתוכים מEPP באיכות מעולה.
המחיר שלהם מאוד מאוד אטרקיבי והן עמידות מאוד ושומרות על הציוד בריסוקים.
אבל דורש קצת עבודה אם כי מדובר בכנפים מעופפות כך שזה מינורי לחלוטין וזה לא הרבה יותר מאשר להרכיב SWIFT .
שירשור בניה של "Zephyr 60 למטרות FPV:
http://www.rcgroups.com/forums/showthread.php?t=1300049
דיברתי עם הבחור מהאתר MWC שפורסם למעלה והוא אמר שמשלוח של ה-84" יעלה 35$.
ז"א פחות מ-400 שקל.
הכנף מחולקת לארבעה חלקים.
יש לי מנוע AXI 4120/14 ובקר של FLYING 70A, המנוע שוקל בערך 360 גרם, האם הוא יתאים לכנף?
נערך לאחרונה על ידי tomer_inbar; 20-12-2010 בשעה 15:55:43.
בברכה,
תומר עינבר
תומר המנוע המדובר נראה חזק , גדול וכבד במיוחד - לא צריך אותו למקסי וגם לכלי של ה - 84" הוא נראה כבד וחזק מידי, כלי כזה אמור לטוס לאט והוא לא ישקול לך מעל 3 ק"ג, מוטת הכנפיים שלו גדולה מאוד והוא אמור לדאות ולרחף בקלות גם במצב הטלה ידנית קלה...
my 2 cents...
בכל מקרה אני מוכן להיכנס לקנייה משותפת של ה - 84" רק צריך לברר קודם כמה הכלי שוקל ?
אם זה מגיע ב4 חלקים איך הם מתחברים ? בזפיר יש קרבונים בין 3 החלקים ? האם מגיעים בערכה ?
לא ראיתי מייצבים ?
לא ראיתי מאזנות ?
החלפת זכוכית בלבד
מעבדת תיקון גלקסי
מעבדת תיקון אייפון
נערך לאחרונה על ידי tomer_inbar; 20-12-2010 בשעה 18:05:57.
בברכה,
תומר עינבר
MWC מוכר ליבות בלבד .
כל השאר צריך לארגן ולהחליט עצמאית.
הכנף שוקלת בערך 450 גרם.
והוא אמר לי שמדביקים את החלקים אחד לשני. (לההה).
אין כנפונים, אין כלום. זה רק הגוף, או הליבה כמו שקוראים לזה.
לגבי הזמנה משותפת, הוא לא כל כך הבין למה התכוונתי, איך כותבים הזמנה משותפת באנגלית?
בברכה,
תומר עינבר
Bulk Order, Quantity order, few items,
What would be the price for 3-5 wings?
אין אפשרות להזמנה משותפת, זה מה שהוא רשם לי:
"Sorry no on that size of wing, the boxes are large that is why the shipping is so much "
בברכה,
תומר עינבר
הזמנתי את ה-Maxi.
הסטאפ המתוכנן הוא:
מנוע:
E-Flite Park 480 Brushless Outrunner 1020kV
בקר:
Turnigy Super Brain 40A Brushless ESC
- Turnigy Program Box for Aqua-Star and Super-Brain
- Turnigy USB Linker for AquaStar/SuperBrain
סוללה:
Turnigy nano-tech 2650mah 3S 25~50C Lipo Pack
סרוואים:
HKS-9257 High Speed Servo 4.5kg/ 25g/ 0.07sec
מקלט:
Futaba R617FS
בברכה,
תומר עינבר
מה לגבי סט אפ ערסי?
חשבתי על כזה שילוב:
מנוע: http://www.rctimer.com/index.php?gOo...1&productname=
עם פרופ APC9X6
בקר: http://www.rctimer.com/index.php?gOo...1&productname=
וקומבו סרוואים: http://www.rctimer.com/index.php?gOo...9&productname=
או החזקים יותר (ולא כבדים בהרבה): http://www.rctimer.com/index.php?gOo...7&productname=
