I am following suggestions/question sent via private messages:
I am going to build the 16k at first go.
Since this is not my life-work, I intend to make them as simple as possible and sell them at around cost.
Cost - I need to check whether I can get the SL PCB built cheaply (and it is a VERY simple PCB)...
The 64K needs an MC according to all kinds of crap internet pages I came over. However, a cursory read of the datasheets of the 16k and 64k eeproms seem to suggest that this is not strictly correct - I will make a test. The two devices (in quantity one) are rather cheap.
The 64k IS more interesting in the longer run, but I do not expect to be over ~20 models in the VERY near future, and that should be covered by the 16k and another 16k :-)...
In any case, the EXPECTED BoM is NOT insane. I need to check how much work is involved in hand-soldering the thing and testing the thing. And - of course - I need my 8U to finally hfkjshf93ry9wuhiefnfs arrive from the US :-).
The question is - how many people want one? How many want a 16k? and how many people want a 64k?
BoM:
8-pin DIP socket
~7cm^2 board (I prefer NOT to use pre-perforated, but may have to)
3.3KO res
2mm pitch 7-pin L socket
ציטוט נכתב במקור על ידי Boogle
האם אתה הולך לבנות את גרסת ה16K או ה64K?
מה תהיה העלות?
