מציג תוצאות 1 עד 20 מתוך 20
נושא: שלטים חדשים לספקטרום DX8 ו- DX10t
    Ramat HaSharon, Israel
    הודה 1,100 פעמים ב 464 הודעות
    ברירת מחדל שלטים חדשים לספקטרום DX8 ו- DX10t
    אז גם ספקטרום משחררת שלטים חדשים לשוק:
    DX8
    ו-DX10t שמתאים יותר לשוק ה"גרמני" - שלט מגש כמו המולטיפלקס
ID:	19961   Click image for larger version.
    ברירת מחדל תגובה להודעה: שלטים חדשים לספקטרום DX8 ו- DX10t
    ציטוט נכתב במקור על ידי YORAM D צפיה בהודעה
    מה מהירות השידור של ה 8?
    יותר או כמו ה DX7SE?
    אמורה להיות זהה עם יכולות טלמטריה בזמן אמת
    נתונים על ה-DX8:
    SPM88001EU range DX8 Set, Mode 1
    SPM8800EU range DX8 Set, Mode 2
    What's inside:
    • Spectrum DX8 Channel
    • Spektrum 8 Channel Receiver
    • Spectrum telemetry transmitters
    • Sensors
    Description:
    The DX8 is a better range of hand-held transmitter for the aspiring model pilots. The investment follows a modern design with an impressive ergonomics. All controls are within comfortable reach,
    even if you have smaller hands. Course
    DX8 is the spectrum with the unique
    DSM2 transmission system facilities. It offers a fast and secure link to the model. Of course, this also includes remote control system
    in the range of equipment used to make Bind and Fly fly models of Horizon.
    The facility is equipped with telemetry. This permits real-time monitoring of flight log data and the power supply and
    Data from other external sensors. The facility has a modern and very ergonomic
    Software that is fast and intuitive. Extensive functions for area pilots,
    as well as for helicopter pilots from the software feature.
    Internally, the system stops at 30 model memories. The built-in SD card reader, however, allows an approximate
    unlimited number of model memories. In addition, software updates can be easily performed.
    The spectrum DX8 is supplied with 4 languages.
    It can be set to 3 service areas
    - EU, France and U.S.. Furthermore, the investment in Mode 1 can be flown to 4. DX8 The spectrum needs are met almost all of the dedicated model airplanes.
    Kit contents:
    Features:
    Real-time telemetry
    Strength
    Recipient or flight battery voltage
    Flight Log data
    Sensor data
    SD / MMC card for storage / software update
    30 model memories
    large backlit LCD
    Electronic Maximalwegbegrenzung
    8-channel receiver with telemetry interface
    Stopwatch on gas activated
    adjustable Language
    Alarm
    Examination of the transmission data
    Mode 1-4 selectable
    Special flight functions:
    Delayed flap
    Free switch allocation
    Alerting capabilities for selected joystick
    Special helicopter functions:
    Electronic E-Ring
    active attitude of the gyro gain
    Swashplate Timing
    selected alerting
    Required accessories:
    The facilities of other models, the telemetry modules and boards / Sesoren are also available separately.
    Each spectrum receiver with a data port is compatible with the telemetry module.
    SPM9548
    Telemetry Module
    SPM9560
    Air Speed Sensor Telemetry Board
    SPMA9569
    Air speed sensor
    SPM9561
    Aircraft telemetry battery power board
    SPMA9570 battery voltage
    Sensor
    SPM9562
    Aircraft Telemetry Temperature Sensor Board
    SPMA9571
    Aircraft
    Temperature Sensor
    Connecting in series of connected boards are available in lengths.
    6 "= 15.24 cm SPM9563
    9 "= 22.86 cm SPM9564
    12 "= 30.48 cm SPM9565
    Other Accessories:
    DX8 16MB SD card SPMA9649
    הודה 16 פעמים ב 16 הודעות
    נראה מוזר ש-Spektrum מוציאים שלטים חדשים על בסיס השלטים הקודמים שלהם, אבל יפה.
    תודה על הפירסום.
    ציטוט נכתב במקור על ידי MyHeartIsBeatinG צפיה בהודעה
    תודה על הפירסום.
    האמת שיש להם לא מעט חידושים שמופיעים בשלטים החדשים כמו ההייטק אורורה והמולטיפלקס,
    שליטה דינמית על יותר פרמטרים ומתגים , טלמטריה ועוד, לכל בעלי הספקטרום וה-JR זוהי אופציה טובה לשידרוג מבלי להחליף את צי המקלטים שלהם או להתרגל לתפריטים חדשים.
    Feb 2009
    IL
    שלטים מכוערים רצח!!!
    בסגנון של DX6/ DX6i - לא הייתי קונה אותם גם בחצי מחיר של DX7
    גרג
    נ.נ.
    שוב זה דעתי האישי שלי.
    ציטוט נכתב במקור על ידי bgrg צפיה בהודעה
    גרג
    נ.נ.
    על טעם וריח אין מה להתווכח ,גם הם וגם המולטיפלקס לדעתי האישית מכוערים,
    ה-11X החדש של JR נראה מיליון דולר, לדעתי, אבל הוא די גדול וכבד.
    בונקר
    הודה 37 פעמים ב 35 הודעות
    פשוט שיא הכיעור
    הודה 58 פעמים ב 42 הודעות
    במלה אחת...
    איכזבו.
    Dimona, Israel, Israel
    לא משהו בכלל !! לא השלטים ולא רמת היופי שלהם!!
    גיא יצא לך להחזיק את השלט של JR כבר ה11X ?
    הוא בהחלט נראה מליון דולר אך בעיינין הכבד והגדול אין לי מוסג!
    בכל זאת הכל אותו דבר הכול תלוי בנו
    באצבעות שלנו אך למה להתווכח שאלן זאבו מטיס עם ספקטרום DX 7 ? לא JR לא הייטק ולא המולטיפלקס
    בברכה
    גל אסולין....
    Trex 700
    Trex 250 se
    protos 500
    scaedu 50 evo
    katana
    cassna
    hitec Aurora 9
    rd 8000
    מספיק לא?
    אילת
    הודה 38 פעמים ב 29 הודעות
    בתור אוהד של ספקטרום פשוט אכזבה ה-DX8
    גם מבחינת העיצוב וגם מבחינת הלחצנים !
    מזכיר מאוד את ה-DX6 וזה זכרון לא טוב
    בכבוד רב,
    שגיא אדיר
    T-Rex 700N LE
    V-Bar SL Pro
    Ys 120 3D
    DX8
    הודה 142 פעמים ב 66 הודעות
    הם כנראה בכוח מחפשים לפשוט רגל... חבל שהם לא מבינים שה"לוק" החיצוני לא פחות חשוב מהתוכן, אני עדיין אאחל להם בהצלחה!
    ציטוט נכתב במקור על ידי gal15260 צפיה בהודעה
    יש השוואה בין ה-11X ל9303 ושם מראים שהוא גדול יותר וכבד יותר...אני פשוט לא זוכר באיזה אתר זה היה.
    נערך לאחרונה על ידי guyro; 07-02-2010 בשעה 06:34:29.
    Feb 2010
    קצת מבאס הרי הוא נראה כמו הDX6...
    הDX7 מדהים ולא משתווה ביופי לידם!
    ברסמי אם הם היו משנים ומשפרים את היופי זה היה עוזר להם מאוד.
    נערך לאחרונה על ידי Amir-Cosworth; 07-02-2010 בשעה 06:33:13.
    http://http://up197.siz.co.il/up3/lcgtdyy4hyjo.jpg
    מחפש מטען ליפו פשוט שיהיה סבבה לא משהו חללית אבל יפה ודיגיטלי(רצוי)
    ובמחיר טוב קנייה מיידית!
    לפנות לפרטי!
    הודה 331 פעמים ב 222 הודעות
    כולם מתרכזים בקנקן ולא במה שיש בתוכו.
    חכו קצת, יתכן שתג המחיר ואיכות השלט ישנו את דעתכם.
    סוף סוף קצת מילות ניסיון ..., איפה נעלמת מאתמול ?
    ציקי
    ברור שאתה צודק אבל מי יקנה שלט מכוער .... אז מה אם הוא טוב והוא מציע מספר שיפורים מעניינים אך זה לא תמיד ימשוך אנשים לקנוות אותו !(אותי בכל אופן ...)
    אני לא היייתי קונה כזה שלט גם אם הוא היה הכי טוב !~ לא בהכרח צריכים לקנות את הכי טוב !
    אני עכשיו צריך לקנות שלט ואחת החשיבות שלי (שברור שהחשובה ביותר היא הפונקציות שיש בתוכו והנוחיות ) אך הייתי הולך גם טיפה על היופי !
    כי אם שלט לא יפה אין די "בהנאה" להטיס איתו !
    ציקי שלא תבין אותי לא נכון זו דעתי ומקווה שלא תעלב או תפגע
    בברכה
    גל אסולין....
    Trex 700
    Trex 250 se
    protos 500
    scaedu 50 evo
    katana
    cassna
    hitec Aurora 9
    rd 8000
    מספיק לא?
    ולגבי תג המחיר יתכן שאתה צודק יכול להיות שזה ימשוך אנשים
    כמו שקודמו ה DX 6 וה DX6I משכו אנשים לקנייתם ...
    בברכה
    גל אסולין....
    Trex 700
    Trex 250 se
    protos 500
    scaedu 50 evo
    katana
    cassna
    hitec Aurora 9
    rd 8000
    מספיק לא?
    עסוק עם הילדים, גם הם דורשים תחזוקה
    ציקי
    אני נוהג להטיס את המסוק ולא את השלט לכן היופי צריך להתמקד לדעתי במסוק ולא בשלט.
    אם שלט מכוער,נוח לי פונקציונלית, ארגונומית, בעל תג מחיר טוב ובנוסף יגרום למסוק שלי לטוס בטוח יותר מאחד אחר אטיס איתו גם אם הוא לא יהיה היפה ביותר
    חכו בסבלנות, לא הייתי מספיד כל כך מהר את ספקטרום.
תגיות בנושא זה
