נושא: The HobbyKing.com 12hr SuperDeal has just begun
    Or Yehuda, Israel
    הודה 5 פעמים ב 3 הודעות
    ברירת מחדל The HobbyKing.com 12hr SuperDeal has just begun
    High Voltage Coreless Titanium HV-380 Servo
    Impressive coreless & titanium gear digital servo!
    This servo handles up to 12v DC and includes Titanium gears and
    large Korean bearings. Amazing Quality and performance
    For the next 12hrs only these will be available for $59.99!
    Standard retail price is above $129.99!
    Now just $59.99 for the next 12hrs.
    http://www.hobbyking.com/hobbyking/s...idProduct=9982
    Turnigy Super Brain 20A Brushless ESC
    The smartest ESC around with data logging and tonnes of features!
    Log voltage, current, RPM, temps and throttle movement in flight.
    FET's from USA and quality voltage regulators. Very reliable.
    For the next 12hrs only these will be available for $20.20!
    Standard retail price is above $39.99!
    Now just $20.20 for the next 12hrs.
    http://www.hobbyking.com/hobbyking/s...dProduct=10940
    10 Snap-Sharp knives
    Never run out of cutters again!
    HobbyKing 10pc snap knife set is an amazing bargain!
    10 Knives included in the set.
    For the next 12hrs only these will be available for 59cents!
    Standard retail price is above $4.95!
    Now just 59cents for the next 12hrs.
    http://www.hobbyking.com/hobbyking/s...idProduct=9334
    F-14 Fighter with twin 60mm EDF 1100mm
    Includes twin EDF units & folding wing mechanism.
    This is unheard of quality and value, never to be repeated!
    Standard retail price is above $249.99!
    http://www.hobbyking.com/hobbyking/s...dProduct=11033
    HobbyKing.com SuperDeal deep discounts are sold at below factory cost price.
    SuperDeals are not retroactive and only while stocks last.
    מי מזמין את הF-14?
    שי
    Futaba 10CHP
    Outrage Velocity 50, YS 56-SR
    ברירת מחדל תגובה להודעה: The HobbyKing.com 12hr SuperDeal has just begun
    לא במלאי
    RcWorks
    ניר בורשטיין
    Nir Burshtein
    בנייה, הרכבה והדרכה
    ייעוץ וליווי מתחילים
    054-245-7838
    Apr 2010
    ק.שמונה
    22/5/2010
    Turnigy 3mm Flat Head Screwdriver
    Light weight short shaft toolkit screwdriver. Hardened steel tip
    and hollow handle make this a very light weight yet strong
    item to carry around in any toolbox.
    For the next 12hrs only these will be available for 89cents!
    Standard retail price is over $2.99!
    Now just 89cents for the next 12hrs.
    http://www.hobbyking.com/hobbyking/s...dProduct=11042
    Super Light Wheel 25mm GFoam wheels (3pcs/bag)
    A very strong nylon hub with a light weight foam cushioned wheel.
    Width is 13mm and diameter 25mm, these suit most landing struts or
    make perfect tail wheels for larger planes.
    For the next 12hrs only these will be available for $1.49!
    Standard retail price is over $3.99!
    Now just $1.49 for the next 12hrs.
    http://www.hobbyking.com/hobbyking/s...dProduct=10887
    Hobby King S1 Servo Doctor w/ Gyro Sensor
    Hobby King S1 is the first integrated servo tester in the market which
    allows you to measure speed, duty cycle, travel linear & range also
    receiver output signal and frequency.
    For the next 12hrs only these will be available for $43.99!
    Standard retail price is over $59.99!
    Now just $43.99 for the next 12hrs
    http://www.hobbyking.com/hobbyking/s...dProduct=10572
    אגב הF-14 חזר למלאי(המחיר עלה ב10 דולר)
    נערך לאחרונה על ידי OneLink; 22-05-2010 בשעה 17:07:09.
  1. 4hr SuperDeal has just begun
    על ידי giladba בפורום פורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 16-05-2010, 19:41:35
  2. [שאלה] סרווים מ - hobbyking
    על ידי ronenvvv בפורום פורום טיסני דלק
    הודעה אחרונה: 05-04-2010, 22:57:22
  3. בקרוב - FPV מבית HobbyKing
    על ידי ZigiStar בפורום פורום FPV וצילום אווירי
    הודעה אחרונה: 15-01-2010, 19:59:22
  4. כבל לשלט של hobbyking
    הודעה אחרונה: 14-12-2009, 17:55:18
  5. מצלמה חדשה ב-HobbyKing
    הודעה אחרונה: 24-09-2009, 23:51:48
