EMP N3542-900KV 2-4S 495W Brushless Multi copter Motor w/prop saver adapter
Brand: EMP
Specifications:
l KV (rpm/v): 900
l Motor Diameter (mm): 35
l Motor Length (mm): 32.7
l Shaft Diameter (mm): 4
l Shaft Length (mm): 19
l Weight (g): 142
l Power (W): 630
l Wire Winds: 5
l Resistance (Ω): 0.048
l No-load Current (A): 1.7
l No-load Speed: 9300-10600rpm/min
l No-load Voltage: 10V
l Load Voltage: 14.8V
l Load Current: 34.1A
l Load Power: 500W
Recommended Equipments (need to buy separately):
l ESC (A): 45
l Cells Ni-Cd/Ni-MH: 6S-12S
l Cells Li-Po: 2S-4S
l Prop: 10*6/ 11*5/ 13*8
Package Contents 1 x Brushless motor (soldered the 3.5MM connector plug)
1 X prop adapter
1 x prop saver
80 ש"ח
0543984604 שגיא
