נושא: Humongous 70" & 78" by SegevDesign
    Nov 2011
    DownUnder
    הודה 9 פעמים ב 5 הודעות
    ברירת מחדל Humongous 70" & 78" by SegevDesign
    Hi guys,
    Its been awhile since I wrote here, and I apologize for the lack of hebrew keyboard on my pc
    I wanted to share with you all our new design, Myself, Yonatan Segev, and Frank Liu worked in partnership from across the globe to design and produce the next generation of freestyle RC models.
    Humongous by name and humungous by nature.
    Inspired by WW2 fighters with their large spinners and aggressive yet sleek look, the Segev Design Humongous stands tall and proud.
    Design and tested over a 12 month period, by leading Aeronautical engineer Yonatan Segev, the Humongous has been perfected to blend precision flight with extreme aerobatic capability.
    It’s gentle flight characteristics make the Humungous an easy to fly plane making it perfect for intermediate pilots honing their skills to all out freestyle aerobatics guns seeking an airframe that gives them a great platform to perform.
    Choose from three sizes including:
    70” – Electric powered
    78” – Electric or gas power
    92” – Electric or gas power
    Complementing the unique lines of the Humungous are a choice of three colour schemes that have been designed by specialised aircraft design guru Ray Younger.
    To achieve the sleek lines of the Humungous a combination of composite materials, balsa and ply have been utilised all covered in quality Oracover.
    When quality and performance are high on your list of attributes then you will not be disappointed in the Segev Design Humongous.
    SPECIFICATIONS - 70"
    Wing span 70in/1780mm
    Length 72in/1820mm
    Weight 3600-3800g (Battery not included)
    EQUIPMENT REQUIRED
    Motor 2000W, 450-500g, brushless outrunner
    ESC 100A
    Servo
    3 Standard (ailerons & rudder) 50-70g, 10kg/cm or above, metal gear
    2 Mini (Elevator) 5kg and above, metal gear
    Battery 6S 4500-5000mah
    Prop 19x10E, 19x12E, 20x8E, 20x10E
    Spinner 5in Alu spinner is included in the kit.
    On facebook
    https://www.facebook.com/SegevDesign
    URL
    http://segevdesign.com/Humongous
ID:	137353   Click image for larger version.
ID:	137352   Click image for larger version.
Name:	Humongous flyer 1.jpg‏
ID:	137354   Click image for larger version.
Name:	Humongous flyer 2.jpg‏
ID:	137355   Click image for larger version.
ID:	137357   Click image for larger version.
ID:	137358   Click image for larger version.
ID:	137359   Click image for larger version.
ID:	137360   Click image for larger version.
ID:	137362   Click image for larger version.
ID:	137363   Click image for larger version.
ID:	137364   Click image for larger version.
ID:	137365   Click image for larger version.
    נערך לאחרונה על ידי MDreamer; 25-03-2016 בשעה 12:29:35.
  2. המשתמשים 3 הודו ל 3dbuster על הודעתו:
    edgarfov (26-03-2016),guyro (25-03-2016),motti (25-03-2016)
  1. [חדשות] "עטלפים", "פנתרים", "תעתוע", "ארגמן"
    על ידי dror בפורום רחפנים מרובי להבים
    הודעה אחרונה: 02-02-2013, 01:16:01
  2. השרון למכירה דאון "ראפיד" איכותי ביותר 2.3 מטר של חברת "רייכרד" הצכית
    על ידי gillb בפורום דאונים וטיסנים חשמליים
    הודעה אחרונה: 06-12-2011, 20:42:51
  3. תל אביב והסביבה מחפש מתאם פרופ למנועי 35 מ"מ של turingy ...זה שמתלבש על """הרוטור""" עם 4 ברגים קטנים
    על ידי ofir181 בפורום רדיו, אלקטרוניקה וציוד נלווה
    הודעה אחרונה: 26-06-2011, 21:56:36
  4. לא עדיף לפרסם "גוף למסירה" בפורום "נותנים-מקבלים"...?
    הודעה אחרונה: 03-05-2010, 20:34:40
  5. [מדליק] מה עושים, ש"נגמר הדלק" והאצבעות "חמות" על הסטיקים???
    הודעה אחרונה: 04-09-2009, 17:58:38
