Step 1,
Define channel 5 as Aux 1 channel switch NULL
Step 2.
Menu (FLT.COND)
Assign Flight Cond
1.Normal (default) Stabilised (E,0)
2.Simple (E,1)
3.Alt Hold (E,2)
4.Loiter (F,1)
5.Auto (G,1)
6.RTL (H, 1)
Assign to the switches you prefer (I used E,F,G,H)
I use T.Link: ACT on all.
Step 3.
Menu (P.Mixes)
Assign Programmable Mixes 1
1. ->Aux1
Programmable Mix-1 ON
Aux1 (Normal, Simple, Alt hold, Loiter, Auto, RTL) S
Rate:0% ACC:0%
o:0% OST
-100, -56, -23, +9, +41, +100)
Switch NULL
Flip the switches you assign the flight cond to.
The flight cond shows up enter the correct OST value each flightmode on the copter
this may vary from mine.
Make sure you select S not C type off mixer for every flight
cond.
הגדרתי כנראה לא בדיוק כפי שרשום --- כיוון שזה לא עובד אשמח לעזרה בנושא
